MediaInfo on an XDCAM-EX file that won't open in PrPro6 due to "missing codecs"
davidbeisner2010 Jun 26, 2012 11:23 AMHad a friend do the edit on a video for me in PP5.5 on the Mac. I'm doing the final grading and audio master in PP6 on the PC. All the footage was shot with my JVC GY-HM700u in XDCAM-EX and has worked just fine for me on my system... I gave him .mp4 files, and they've all come back to me as .mov files, and PrPro says it doesn't have the required codec. I'm not willing to do the final work on his systems cause they're old iMacs... my PC has multiple RAID arrays, 24GB ram, good CPU, etc and screams on the audio mastering and grading.
Here's the MediaInfo on one of the files:
General
Complete name : E:\Academics\Majors Videos\Biology\Copied_Biology Promo\BIOL0240_01.mov
Format : QuickTime
Format/Info : Original Apple specifications
Format_Commercial_IfAny : XDCAM EX 35
File size : 286 MiB
Duration : 1mn 7s
Overall bit rate mode : Variable
Overall bit rate : 35.6 Mbps
Movie name/More : 060a2b340101010501010d43130000007c18c1c7965505c00080884f85010a03
Encoded date : UTC 2012-04-21 21:14:05
Tagged date : UTC 2012-04-23 12:04:14
Writing library : Apple QuickTime
Original source medium : Eisenbach
com.apple.quicktime.information : 060a2b340101010501010d43130000007c18c1c7965505c00080884f85010a03
com.sony.bprl.mxf.nrtmetadata : <?xml version="1.0" encoding="UTF-8" standalone="yes"?><NonRealTimeMeta xmlns="urn:schemas-professionalDisc:nonRealTimeMeta:ver.1.30" xmlns:lib="urn:schemas-professionalDisc:lib:ver.1.30" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" lastUpdate="2011-02-04T12:44:59-06:00"><TargetMaterial umidRef="060A2B340101010501010D43130000007C18C1C7965505C00080884F85010A03"></TargetMateri al><Duration value="2025"></Duration><LtcChangeTable tcFps="30" halfStep="false"><LtcChange frameCount="0" value="54462102" status="increment"></LtcChange><LtcChange frameCount="2024" value="40542202" status="end"></LtcChange></LtcChangeTable><CreationDate value="2011-02-04T12:43:51-06:00"></CreationDate><TypicalUbit value="0000000000000000"></TypicalUbit><BodyUmidBasicChangeTable><BodyUmidBasicChange frameCount="0" value="060A2B340101010501010D43330000007C18C1C7965505C00080884F85010A03" status="start"></BodyUmidBasicChange></BodyUmidBasicChangeTable><KlvPacketTable><KlvPacke t key="060E2B34010101050301020A02000000" frameCount="0" lengthValue="095F5265635374617274" status="spot"></KlvPacket></KlvPacketTable><VideoFormat><VideoRecPort port="DIRECT"></VideoRecPort><VideoFrame videoCodec="MPEG2HD35_1920_1080_MP@HL" captureFps="29.97p" recFps="29.97" formatFps="29.97p"></VideoFrame><VideoLayout pixel="1920" numOfVerticalLine="1080" aspectRatio="16:9"></VideoLayout></VideoFormat><AudioFormat numOfChannel="2"><AudioRecPort port="ANALOG" audioCodec="LPCM16" trackDst="CH1"></AudioRecPort><AudioRecPort port="ANALOG" audioCodec="LPCM16" trackDst="CH2"></AudioRecPort></AudioFormat><Device manufacturer="JVC" modelName="GY-HM700" serialNo="105V0780"></Device><RecordingMode type="normal" cacheRec="true"></RecordingMode></NonRealTimeMeta>
com.sony.bprl.mxf.umid : 060a2b340101010501010d43130000007c18c1c7965505c00080884f85010a03
org.smpte.mxf.package.material.p : 0x060a2b340101010501010d43130000007c18c1c7965505c00080884f85010a03
com.sony.professionaldisc.nonrea : 2011-02-04 12:44:59 -0600
com.sony.bprl.xdcamtransfer.vers : 2.13.0.650
com.apple.proapps.reel : Eisenbach
com.apple.proapps.clipID : 060A2B340101010501010D43130000007C18C1C7965505C00080884F85010A03
com.apple.proapps.originalFormat : XDCAM EX 1080p30 (35 Mb/s VBR)
Origin : MPEG HD
©TSC : 2997
©TSZ : 100
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Codec ID : xdvf
Duration : 1mn 7s
Bit rate mode : Variable
Bit rate : 34.0 Mbps
Maximum bit rate : 35.0 Mbps
Width : 1 888 pixels
Original width : 1 920 pixels
Height : 1 062 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.566
Stream size : 274 MiB (96%)
Language : English
Tagged date : UTC 2012-04-21 21:20:58
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Unsigned
Codec ID : lpcm
Duration : 1mn 7s
Bit rate mode : Constant
Bit rate : 768 Kbps
Channel(s) : 1 channel
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 6.19 MiB (2%)
Language : English
Audio #2
Format : PCM
Codec ID : lpcm
Duration : 1mn 7s
Bit rate : 768 Kbps
Bit depth : 16 bits
Language : English
Menu
Language : English
Bit rate mode : CBR
