Locked
SCUP/SCCM install of 11.3.300.257 fails
Guest
Jun 19, 2012 Jun 19, 2012
I'm having trouble deploying the new combined 32/64bit version of Flash published through the SCUP cab catalog and SCCM Software Updates deployment. On every one of my machines the update fails with the same error. I have a mixed environment of Win XP 32bit and Win 7 64 bit machines.
I've previously had no trouble at all deploing Flash (and other Adobe updates) updates using the SCUP catalog and SCCM. It is first with 11.3.300.257, where the msi contains binaries for both 32 and 64 bit, that i experiece issues.
The error i get in the WindowsUpdate.log is:
WUAHandler.log (SCCM related log) gives the error:
Installation job encountered some failures: Error = 0x80240022.
UpdatesHandler.log (SCCM related log) gives the error:
Update execution failed.
The Windows Application Event Log displays nothing in relation to the msi, so no usefull info there.
Anyone else out there with the same issues, or with some guidance?
Br,
David
8.3K
Guest
Is anyone out there deploying the new 11.3.300.257 version of Flash using SCUP and SCCM Software Updates successfully??
Guest
Jun 26, 2012 Jun 26, 2012
I have been deploying 11.3 via SCUP to both XP and Win7 clients without issues (so far!).
Alex
Guest
Hi Alex,
Thanks for the info. And you didn't modify the installed/installable rules for the msi packages in any way before deploying them? Did you create a manual update, or import from the official Adobe CAB catalog?
Guest
Jun 27, 2012 Jun 27, 2012
No modifications and imported from the Adobe catalog using SCUP 2011 and SCCM 2007 R2.
Cheers
Adobe Employee ,
Jul 16, 2012 Jul 16, 2012
I know that the response is really late. Did you solve this issue?
If not, could you please do the following:
- Right-click and see if the installer is blocked.
- Try installing Flash Player using the command that you use in SCCM and see if it installs.
Sunil
Oct 16, 2012 Oct 16, 2012
Have, I am having the exact same problem. But 90% of my machines are fine. It is the about 30 machines, about 10% of the total, which fail with this error message. I cant see anything wrong with these machines, or anything in common thats different from the machines that patch ok.
This has occurred with all Flash ActiveX updates for Internet Explorer since I began using SCUP with SCCM.
any other advice that could be of use? Thanks!
Nov 20, 2012 Nov 20, 2012
One requirement is that IE must be closed to succeed.
Just a thought.
