How to Add a Text Anchor
Jun 29, 2012 Jun 29, 2012
I've just discovered the Cross References feature in InDesign but I want my cross reference to point to a Text Anchor but for the life of me I cant work out how to add a Text Anchor.
So how do you add a text anchor?
Thanks.
How to , Type
115.0K
Community Expert , Jun 29, 2012 Jun 29, 2012
Highlight the text you want to be the anchor. Open the Hyperlinks panel. From the panel munu choose New Hyperlink Destination and the dialog should come up with Text Anchor and your highlighted text filled in. Click OK.
Insert your cursor where you want the text anchor.
Open the hyperlinks panel menu and select New Hyperlink Destination.
Select text anchor from the Type” dropdown.
Bob
Apr 19, 2018 Apr 19, 2018
Today I was struggling with this feature too! Thank you so much for your answer - most helpful one today. Thank you!!
May 01, 2020 May 01, 2020
For anyone else trying to do this and not able to find New Hyperlink Destination... Go to the Window menu and the Interactive window. That's where you'll find the Hyperlink panel referenced above.
Jun 16, 2020 Jun 16, 2020
Thank you, I thought I was losing my mind on the "Links" window.
Feb 16, 2021 Feb 16, 2021
Thank you for the clarification. It was driving me crazy!
Mar 29, 2021 Mar 29, 2021
Yes, the lack of clarification was driving me crazy too! Thanks so much, I can finally finish this task!!
May 18, 2021 May 18, 2021
Thank you!!
Aug 04, 2021 Aug 04, 2021
Thank you!!! I spent about 15 minutes trying every way possible to find that.
Aug 13, 2021 Aug 13, 2021
Ooof help! My hyperlinks panel does not show a "New Hyperlink Destination" option anywhere. I'm stuck!
Sep 26, 2021 Sep 26, 2021
On the right top corner of your Hyperlinks -panel, there is "3-lines" -button (more options). Click that and the 5th option is "New Hyperlink Destination...".
Mar 16, 2024 Mar 16, 2024
THANK YOU
Aug 12, 2022 Aug 12, 2022
This is all well and good but I would like to see text anchors added to the Hyperlinks panel. I am running ID 17.3 on a PC and only true hyperlinks (in my case to URLs) in my document are listed in the panel. This might improve use of this feature when the text anchor is used multiple times in a document. It would be a great new feature.
Marie
May 03, 2013 May 03, 2013
Create the hypelink destination first then the cross reference.  Go to the text you want to refer to, select the text that you are referencing (the destination) then Create a new hyperlink destination the selected text will be the name of the destination link. This make life much easier later when creating the cross reference.
Dec 22, 2019 Dec 22, 2019
Dear Sir,
I have done text anchor cross-references. But there two questions left for me: 1. How is this possible to have a mutual cross-back on the two words crossed link together and the second question: why the blue links which are cross-refernced are not clickable in pdf (interactive) on smart devices?
What version of InDesign are you using?
|    Bevi Chagnon   |  Designer & Technologist for Accessible Documents
|    Classes & Books for Accessible InDesign, PDFs & MS Office |
Jan 13, 2022 Jan 13, 2022
Hi I recently upgraded to the Creative Cloud vwrsion of  InDesign so if not the most current then pretty close...the issue is that I can make the Anchor and then I can create the link to it (they are in different documents) but when I print the Interactive PDF nothing happens when I click the link (I do get the hand pointer, so it knows it is 'supposed' to be a link, it just doesn't go anywhere).
Any suggestions?
Wendy
Aug 25, 2022 Aug 25, 2022
To make the hyperlinks work in the PDF, go to File > Export to make the PDF, then you have to check "Include Hyperlinks".
