7 Replies Latest reply on Jul 2, 2012 8:16 AM by RBLindley
    Cs6 does not regiser in my Win 7 Registry
    RBLindley Level 1
      I tryed to change my .JPG files to default to CS6, I go thru all the procedures but CS6 does not show up in my sysem default program list.  The answer from Microsoft  is the CS6 did not register in the system registry when I installed it.  How do I accomplish this?
      Ruben
        • 1. Re: Cs6 does not regiser in my Win 7 Registry
          Arpit Kapoor Adobe Employee
          Due you mean, you want to associate your .JPG files with the adobe application on win 7 machine?
          Which adobe application are your trying to or want to set as default?
          Please ellaborate the issue properly.
          • 2. Re: Cs6 does not regiser in my Win 7 Registry
            RBLindley Level 1
            I want to default association for .JPEG, .JPG files to CS6.  CS6 will not
            show up in the system default program list.  I tried to go to properties of
            a .JPG file then "browse" for a default, I select photoshop CS6 as my
            default program, but, it does not accept.  Microsoft tells me that when CS6
            was installed (recently) it did not register properly in my systems
            registry.  How can I get CS6 registered into my system registry so it shows
            up in the default program list???
            Thanks for your help
            Ruben
            • 3. Re: Cs6 does not regiser in my Win 7 Registry
              What do you mean by, it does not accept?
              There are 2 ways to do this,
              1. Right click on a Jpeg -> Properties -> General Tab -> Change -> Browse to "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe" -> Open -> OK
              2. Control Panel -> Default Programs -> "Associate a file type or protocol with a specific program" -> Find and Select .JPEG -> Change Program -> Browse to "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe" -> Open -> OK
              Ideally that should work. If it does not, tell us exactly whats happening when you try to do so.
              • 4. Re: Cs6 does not regiser in my Win 7 Registry
                Mylenium Most Valuable Participant
                You have too many file handlers. Clean them out using your Windows Explorers File --> Organize --> File Types and then manually re-associate them with Photoshop using the Open with... method. And make sure the file associations are not reinstated by any other programs liek virus scanners, image viewers, packer tools and so on...
                Mylenium
                • 5. Re: Cs6 does not regiser in my Win 7 Registry
                  RBLindley Level 1
                  Yes, I understand what you are saying and I have been following these
                  procedures for many years.  I know very well how to associate a file type
                  with an application. I'm so sorry my question is not understood.  According
                  to Microsoft when I installed CS6, it did not update my system registry
                  properly so it will not show up as a program in the associate file list.  I
                  even went to browse and clicked on the CS6 Photoshop.exe file to associate
                  an open .JPG file.  This failed.
                  I guess I probably should uninstall CS6 and re-install it to see if it
                  registers properly to Windows 7.
                  RBlindley
                  • 6. Re: Cs6 does not regiser in my Win 7 Registry
                    Manish-Sharma Employee Moderator
                    Microsoft people are correct ...it is the registry issue because of which the problem is coming up.
                    NOTE:- Please create a system restore point and do the registry Back up before making any changes , as playing with the registry could be fatal for your computer.
                    Navigate to Computer\HKEY_CLASSES_ROOT\Applications and find your .exe name ex:- Photoshop.exe
                    Navigate under its name to shell>open>command.
                    In the Default change its location to the actual location of the executable, Ex:- "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe" "%1" ( at my end)
                    hit okay and then try and reassociate the file type as you normally would.
                    • 7. Re: Cs6 does not regiser in my Win 7 Registry
                      RBLindley Level 1
                      You are 100% correct, thank you; this saves me a lot of effort.  CS6 now
                      works as it should.
                      RBLindley
