Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Printing button in PDF fillable form.
Avatar
Level 2
Dear All,
I have created a PDF fillable form with a button which save & print the pdf.
The code for is as fallow:
Formular1.#pageSet[0].Seite1.Bildfeld1::click - (JavaScript, client)
var Mailto = "info@stell.de";
var Betreff = Textfeld1.rawValue;
var Nachricht = "Dies ist eine Telefonnotiz\r2.Zeile Hier";
var CC = "info@stell.de";
var BCC = "info@stell.de";
var Mail = "mailto:" + Mailto + "?Subject=" + Betreff + "&Body=" + Nachricht + "&cc=" + CC + "&bcc=" + BCC;
  1. event.target.submitForm({
cURL: Mail,
bEmpty: false,
cSubmitAs: "PDF"
  1. event.target.closeDoc(true); (FormClac)
Formular1.#pageSet[0].Seite1.DruckenSchaltfläche1::click - (JavaScript, client)
  1. xfa.host.print(1, "0", (xfa.host.numPages -1).toString(), 0, 0, 0, 0, 0);
my problem now is that with this script I can print and save the file even though all required fields are not filled!! I donot anyone to have the possibility to print the file or save it unless he fill all required fileds.
  1. Any Idea, coz Iam new in the Adobe Livecycle world
1 Accepted Solution
Avatar
Correct answer by
Level 10
HI,
you can use the validate element to prevent users from printing a form.
See: http://forms.stefcameron.com/2008/04/13/prevent-printing-pdf-forms-in-acrobat-8/
But you never can prevent users from saving a form.
Avatar
Correct answer by
Level 10
HI,
Avatar
Level 2
I just wanted to allow the users to print the PDF or save it ONLY when they have filled the entir document. this is not possible at all?
Avatar
Level 2
can I send you the document to know what I mean?
I canot upload it over here?
Avatar
Level 10
Please read the article under the link I posted before.
There you'll get all details of how to prevent the printing and a sample form you can work with.
Keep in mind that it isn't possible to prevent the saving, this only works for printing, submitting and data connections.
Avatar
Level 2
Thanks a lot for your reply
I sow the article, but the only problem is that the source code for the print button is exactly what I write and I cannot integrate the element code in it. Since in the article is says change the source code and look for
XML Source in Designer and find the following mark-up about 2/3 way down:
<config xmlns="http://www.xfa.org/schema/xci/1.0/">
<agent name="designer">
   </agent>
   <present>
      <!--  [0..n] -->
I don’t have this part in my script!
Avatar
Level 10
What version of Designer do you use?
Avatar
Level 10
Ok,
than you need to add the validate element under the <config> tag as it doesn't exist by default.
Before:
<config xmlns="http://www.xfa.org/schema/xci/3.0/">
      <!--  [0..n]  -->
      <destination>pdf</destination>
      <pdf>
         <!--  [0..n]  -->
         <fontInfo/>
      </pdf>
   </agent>
   <present>
      <!--  [0..n]  -->
      <pdf>
         <!--  [0..n]  -->
         <fontInfo/>
         <version>1.7</version>
         <adobeExtensionLevel>5</adobeExtensionLevel>
      </pdf>
      <xdp>
         <packets>*</packets>
      </xdp>
   </present>
</config>
After:
      <!--  [0..n]  -->
      <pdf>
         <!--  [0..n]  -->
         <fontInfo/>
      </pdf>
   </agent>
   <present>
      <!--  [0..n]  -->
      <pdf>
         <!--  [0..n]  -->
         <fontInfo/>
      </pdf>
      <xdp>
      </xdp>
   </present>
   <!-- This is the validate element to prevent printing, when mandatory fields are empty -->
   <acrobat>
      <validate>prePrint</validate>
   </acrobat>
</config>
Avatar
Level 2
and where should I insert this code?
Avatar
Level 10
Go to the XML-Source and look for the <config> tag and add this snippet.
<acrobat>
</acrobat>
Avatar
Level 2
I donot want to ask silly questions , but really I canot find the XML source code. all what I can find is this:
cURL: Mail,
bEmpty: true,
cSubmitAs: "PDF"
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1.#subform[1].#subform[2].Teilformularschaltfläche1entfernen::click - (JavaScript, client)
   This button will Remove the current instance of the repeating subform or table row.
   bCalc: Flag - true if the removed instance might be referenced by other calculations, otherwise false.
   message: The error message displayed.
var bCalc = true;
var message = "Sie haben die Mindestanzahl zulässiger Objekte erreicht.";
// DO NOT MODIFY THE CODE BEYOND THIS POINT - 9.0.0.2.20101008.1.725030.725025 - Subform_Instance_Controls_IRM.xfo.p4
var oWrapper = this.parent.parent;          // The outer subform built in to the object, enclosing the button group.
var oTargetSubform = oWrapper.parent;          // The subform or table row the controls are intended to manipulate.
var oManager = oTargetSubform.instanceManager;          // Get the instance manager.
var nMinCount = oManager.occur.min;                              // Get the minimum number of subform occurrences allowed.
var nSubCount = oManager.count;                                        // Get the current number of instances.
// Proceed if the minimum number of subform occurrences has not been reached.
if (nSubCount > nMinCount) {
          // Invoke the Instance Manager.
          oManager.removeInstance(oTargetSubform.index);
          // Fire the form calculations.
          if (bCalc == true) {
          // Execute all the form calculations.
          xfa.form.recalculate(1);
} else {
          xfa.host.messageBox(message,"Remove Item", 3);
// END OF DO NOT MODIFY
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1.#subform[1].#subform[2].Teilformularschaltfläche1hinzufügen::click - (JavaScript, client)
   This button will insert one instance of the repeating subform or table row.
   bCalc: Flag - true if the new instance might be referenced by other calculations, otherwise false.
var bCalc = true;
var message = "Sie haben die maximale Anzahl zulässiger Objekte erreicht.";
// DO NOT MODIFY THE CODE BEYOND THIS POINT - 9.0.0.2.20101008.1.725030.725025 - Subform_Instance_Controls_IRM.xfo.p2
var nMaxCount = oManager.occur.max;                     // Get the maximum number of subform occurrences allowed.
// Proceed if the maximum number of subform occurrences has not been reached.
if ((nMaxCount == "-1") || (nSubCount < nMaxCount)) {
          var oNewInstance = oManager.addInstance(1);
          // Move the new subform below the current one.
          var nIndexFrom = oNewInstance.index;
          var nIndexTo = oTargetSubform.index + 1;
          oManager.moveInstance(nIndexFrom, nIndexTo);
} else {
          xfa.host.messageBox(message,"Insert Item", 3);
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1.#subform[1].#subform[2].TeilformularschaltflächeNachOben1::click - (JavaScript, client)
   This button will move the current instance of the repeating subform or table row up one position.
   bCalc: Flag - true if the moved instance might be referenced by other calculations, otherwise false.
var bCalc = true;
var message = "Das aktuelle Objekt kann nicht nach oben verschoben werden, da es sich bereits an erster Stelle befindet.";
// DO NOT MODIFY THE CODE BEYOND THIS POINT - 9.0.0.2.20101008.1.725030.725025 - Subform_Instance_Controls_IRM.xfo.p1
var nIndex = oTargetSubform.index                    // Get the index number of the current subform or table row.
// Proceed if the current subform is not the first instance.
if (nIndex != 0) {
          // Move the current subform.
          var nIndexFrom = nIndex;
          var nIndexTo = nIndex - 1;
} else {
          xfa.host.messageBox(message,"Move Item", 3);
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1.#subform[1].#subform[2].TeilformularschaltflächeNachUnten1::click - (JavaScript, client)
   This button will move the current instance of the repeating subform or table row down one position.
var bCalc = true;
var message = "Das aktuelle Objekt kann nicht nach unten verschoben werden, da es sich bereits an letzter Stelle befindet.";
// DO NOT MODIFY THE CODE BEYOND THIS POINT - 9.0.0.2.20101008.1.725030.725025 - Subform_Instance_Controls_IRM.xfo.p3
// Proceed if the current subform is not the last instance.
if ((nIndex + 1) < nSubCount)  {
          var nIndexTo = nIndex + 1;
} else {
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1::indexChange - (JavaScript, both)
//{{Adobe LiveCycle Designer Generated Code Begin}} - row shading script. Don't modify it!
var Freqs=[1,1];
var Colors=["255,255,255","255,255,255"];
var nFreqSize = 0;
for (var i=0; i<Freqs.length; i++)
  nFreqSize += Freqs[i];
var nRelIndex = this.index % nFreqSize + 1;
for (var nRun=0; nRun<Freqs.length; nRun++)
   if (nRelIndex>Freqs[nRun])
        nRelIndex -= Freqs[nRun];
   else
      this.border.fill.color.value = Colors[nRun];
      break;
//{{Adobe LiveCycle Designer Generated Code End}} - row shading script.
Formular1.TABELLEN1.#subform[2].Tabelle4.Zeile1::indexChange - (JavaScript, both)
var Freqs=[1,1];
var nFreqSize = 0;
   else
      break;
Avatar
Level 2
would you like to take alook with team viewer ... only If you have time?
Avatar
Level 2
<config xmlns="http://www.xfa.org/schema/xci/2.8/">
      <!--  [0..n]  -->
      <pdf>
         <!--  [0..n]  -->
         <fontInfo/>
      </pdf>
   </agent>
   <present>
      <!--  [0..n]  -->
      <pdf>
         <!--  [0..n]  -->
         <adobeExtensionLevel>3</adobeExtensionLevel>
      </pdf>
      <common/>
      <script>
         <runScripts>server</runScripts>
      </script>
      <cache>
         <macroCache/>
      </cache>
      <xdp>
      </xdp>
   <psMap>
      <font typeface="NewsGoth BT" psName="NewsGothicBT-Roman" weight="normal" posture="normal"/>
      <font typeface="NewsGothic LT" psName="NewsGothicLT" weight="normal" posture="normal"/>
      <font typeface="NewsGothic LT" psName="NewsGothicLT-Bold" weight="bold" posture="normal"/>
      <font typeface="NewsGothic LT" psName="NewsGothicLT-BoldOblique" weight="bold" posture="italic"/>
      <font typeface="NewsGothic LT" psName="NewsGothicLT-Oblique" weight="normal" posture="italic"/>
   </psMap>
<acrobat>
</acrobat>
</config>
** I found it & i have inserted the code! but its not working?
Avatar
Level 10
TeamViewer is ok, but not at the moment.
Do you have time this evening at around 19:00?
Or can you share your form somewhere and post a link here?
Avatar
Level 2
the problem is iam working in a company from 7:00 till 17:00 (Germany time)
and all the programes & the sheets at my desktop computer , but if you have time tomorrow it will be perfect. sorry for all this mess, I have been trying to solve this issues but iam new in the field of java scrptiing
Avatar
Level 10
Keine Ursache.
Bis morgen dann!
