Adobe Acrobat will not open any documents, it tells me it is a trial, I click on license product and get a thank you for your Adobe Cloud subscription... but then when I try to open a pdf I get the same message it just keeps looping from trial will run out in 7 days to trial will run out in 13 days and I can never open a pdf. I am going to try and uninstall and reinstall. For most of us, not being able to open a pdf is comparable to not being able to work. This is totally UNacceptable. Clients and bosses are counting on my being able to do my job, I can't say to them, "Oh well the dog "Adobe" ate my homework." PLEASE fix this Adobe! Thank you.
Here is a screen shot of the messages...
I uninstalled, rebooted, reinstalled from Adobe Application Manager, thought all was great when it asked for my user name and password, then when I clicked Launch... same issue. FRUSTRATING! Any one have a fix? I even created a pdf using InDesign, made sure I had View PDF after exporting checked and still got that awful Trial box. The pdf did show up in my documents, but I can not open it.
Any help would be greatly appreciated. Thank you!
http://forums.adobe.com/message/4496723
Check the above link , try the steps it may help.
Gigi C I would recommend you try removing Adobe Acrobat and then reinstall utilizing the Adobe Application Manager. You will want to remove Acrobat using the Program and Features control panel.
Thank you Jeff, but I am pretty sure that is how I uninstalled it the first time.
This is how I launched it. Thank you for taking time to check it out.
If anyone has an answer, I would really really appreciate it! Have uninstalled through Programs and Features just as suggested and reinstalled through Adobe Application Manager several times. Still can not open a PDF. I have not found any work around, except to use another computer that has CS5.5 installed, but this is the computer that I need to use and this is the computer that I paid for the CS6 Suite (I deleted CS5.5 when I upgraded to CS6). Customer Support says they are available 24/7 yet there is no technical support on the weekends and suggested to use the forums... In looking at other forum threads I see this is a fairly common issue with CS6 but not many answers. Please Adobe this is seriously affecting my ability to work.
Thanks in advance!
Thank you Manish-Sharma, I followed the instruction in the thread, and for the first time in a week I can actually open a PDF. I am not sure if this will be a permanant fix, we will see on the 30 day mark. I really appreciate that you read my question and gave me an answer that allowed me to open Acrobat. I also opened Photoshop, InDesign, Illustrator and AfterEffects. They all opened with the exception of a small glitch when I opened Illustrator which was cleared up in moments. See screetshot.
Thank you again! Much appreciated!
For you Illustrator error ,
Right click on the Adobe "Illustartor.exe" file then select "Run as administrator"
your problem will be solved.
