Hi there,
i had a form in flash builder that sends variables in GET to a php-script. This script generates a document dat is downloaded to the client by the following php-code :
header('Content-Description: File Transfer');
header("Content-type: text/csv");
header('Content-Length: ' . filesize($file));
header('Content-Disposition: attachment; filename=' . basename($file));
readfile($file);
Now i wanted to change my flashbuilder-file so it sends the file to php by POST-vars. It still generates the correct file, but it isn't downloaded to the client (i use the same code as above). Can anybody give me a hint on what i'm doing wrong?
The code that i'm using for sending my params to php :
In the mxml i have :
<fx:Declarations>
<fx:String id="phpFile">./amfphp/services/persdb/rapport_post.php</fx:String>
<mx:HTTPService id="form1"
url="{phpFile}"
method="POST"
result="handleResult(event)"
fault="handleFault(event)"
resultFormat="text">
<mx:request>
<type>tmp</type>
<rapport>tmp</rapport>
<params>tmp</params>
</mx:request> </mx:HTTPService>
</fx:Declarations>
And my .as file contains this :
public function sendCsvForm():void{
var param:Object = new Object;
param.type = "Persoon.Rapport";
param.rapport = "CSVCode";
param.params = query3 + "~" + filterQuery + "~csvbestand";
form1.send(param);
Thanks in advance for having a look on it
Dzjoepken
It s will be nice to change your url string to something like http:// So that you invoque executing your php script instead of reading its content.
All in all, just change:
with this:
<fx:String id="phpFile">http://localhost/amfphp/services/persdb/rapport_post.php</fx:String>
