Hello all,
On 3 July I purchased and attempted to install the digital version of CS6 Design and Web Premium for Windows. ( I have Windows 7 Professional). Some of the programs didn't install, and I've copied and pasted the error and warning messages below. The progams that didn't install are: Flash, Dreamweaver, InDesign, and Fireworks.
Should I uninstall and reinstall the whole thing? I've always purchased Creative Suite on disk before. Is there a way to run the download in repair mode?
Pixella
______________________________________________
Here's the Error Report:
Exit Code: 6 Please see specific errors and warnings below for troubleshooting. For example, ERROR: DW050 ... WARNING: DS013, DW022 ...-------------------------------------- Summary -------------------------------------- - 0 fatal error(s),
1 error(s), 7 warning(s)WARNING:
DW022: AdobeCode {AC76BA86-1033-F400-7760-000000000005} NonAdobePayload Acrobat Professional 10.0.0.0 with version (2012-03-05 04:03:46.684000) already installed with incompatible version (2011-03-06 22:43:17.708000)WARNING: DS013: Payload {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0 is already installed and the session payload {D38116C8-C472-4BB0-AD6F-0C1DD1320D1D} AdobeHelp 4.0.0.0 has no upgrade/conflict relationship with it.WARNING: DS013: Payload {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport 5.5.0.0 is already installed and the session payload {DE88AA40-6766-43D3-A755-8FC374B3D2C3} DynamiclinkSupport 6.0.0.0 has no upgrade/conflict relationship with it.WARNING: DS013: Checking payloads upgrade/conflict relationships : Failed with code 1----------- Payload: {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 -----------WARNING: DW029: Custom Action for payload {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 wants to skip this payload. Skipping this payload.----------- Payload: {CA7C485C-7A89-11E1-B2C8-CD54B377BC52} Adobe Fireworks CS6 12.0.0.0 -----------WARNING: DF012: File/Folder does not exist at C:\Users\Pixella\My Documents\Adobe CS6\payloads\AdobeFireworks12-mul\OEM(Seq 2141)----------- Payload: {05E1E278-7A8D-11E1-A0B9-FC0245DB7244} Adobe Fireworks CS6_AdobeFireworks12en_USLanguagePack 12.0.0.0 -----------WARNING: DF012: File/Folder does not exist at C:\Users\Pixella\My Documents\Adobe CS6\payloads\AdobeFireworks12en_USLanguagePack\OEM(Seq 76)ERROR: DW050: The following payload errors were found during install:ERROR: DW050: - AdobeHelp: Install failed-----------------
I have similar symptoms when installing Dreamweaver CS6 on Mac OS 10.7.1:
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF027, DW063 ... WARNING: DW065 ...
- 0 fatal error(s), 4 error(s), 1 warning(s)
WARNING: DW065: Display requirements not met for {8ACD4814-788B-11E1-AC70-A860A781E0D9} Adobe Dreamweaver CS6 12.0.0.0
----------- Payload: {8ACD4814-788B-11E1-AC70-A860A781E0D9} Adobe Dreamweaver CS6 12.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirarpAhfff/Assets1/Adobe Dreamweaver CS6.app/Contents/Resources/SharedImages/904.png" to "/Applications/ThirdParty/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Resources/SharedImages/904.png" (Seq 1746)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 1746)
ERROR: DW050: - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
ERROR: DW050: - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
I have tried installing both from a standard account and from an admin account. The same error occurs each time.
@ Pixella2 I would be needing the complete Install logs , hence please place it on Pastebin.com and then put the link here.
@Lexogram First of all both the situations are different , even the OS's so I would suggest to create a new thread wherein we can help you.
Also you can try installing in the Root user account , it may help.
Uninstall everything Adobe on your system, run the Creative Suite Cleaner Tool, try again.
Mylenium
Thanks for your suggestions. I'm still having problems with the download version installing, so I am awaiting a disk.
