Full error log at <http://pastebin.com/r208XaqY>
Short error message below
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF027, DW063 ... WARNING: DW065 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 4 error(s), 1 warning(s)
WARNING: DW065: Display requirements not met for {8ACD4814-788B-11E1-AC70-A860A781E0D9} Adobe Dreamweaver CS6 12.0.0.0
----------- Payload: {8ACD4814-788B-11E1-AC70-A860A781E0D9} Adobe Dreamweaver CS6 12.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirarpAhfff/Assets1/Adobe Dreamweaver CS6.app/Contents/Resources/SharedImages/904.png" to "/Applications/ThirdParty/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Resources/SharedImages/904.png" (Seq 1746)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 1746)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Dreamweaver CS6_AdobeDreamweaver12en_USLanguagePack: Install failed
ERROR: DW050: - Adobe Dreamweaver CS6: Failed due to Language Pack installation failure
I have tried installing both from a standard account and from an admin account. The same error occurs each time.
Hi Michael,
The final issue I mentioned is not with the installation but with the first launch.
My solution was to:
Have you checked in the root user account ?
I downloaded the standalone installer for DW CS6, and used my Master Collection serial number to authorize it. Dreamweaver is now installed but it fails to run if it is not run from an account with Admin privileges.
When first launched after rebooting my MacBook, it bounces in the dock for a few minutes, and then vanishes with no warning. Attempting to launch it a second time leads to the icon zooming out, as if it were about to launch, followed by nothing. No bouncing in the dock, no alerts, nothing.
You can find here a screenshot showing the System Requirements for Dreamweaver, plus evidence that my MacBook conforms to these requirements.
It runs from an account with Admin rights, but not from a standard account. Always running from an account with admin privileges is not an option.
Three options.
Option 1 use the cs cleaner tool:
http://www.adobe.com/support/contact/cscleanertool.html
Then try to re-install.
Option 2
Create a new admin user and try installing from that
Option 3
Try installing as the root user.
Hi Michael,
My solution was to:
I imagine that it would not take a whole morning to fix Dreamweaver CS6 so that it throws up a "Please give me temporary Admin privileges" dialog on first launch. It might also not take that much longer to do whatever it is that it has to do on first launch in a folder where admin privileges are not required.
This would save hours of frustration on the part each of the thousands of end users who are likely to encounter these symptoms.
