12 Replies Latest reply on Aug 1, 2018 8:55 AM by Thom Parker
    File Name Stamper
    Joe Sacramento Level 1
      Hello All,
      I am using: http://acrobatusers.com/assets/uploads/actions/File_Name_Stamper.pdf
      It works great for one file. But for multiple files, a popup dialog box keeps showing up. Our small non-profit organization is processing 1000+ files and pressing the enter key is cumbersome.
      The actual JavaScript code is below. Is there a way to disable the popup dialog box?
      Many thanks...
      //   File Name Stamper Action Script
      //   by Thom Parker, WindJack Solutions, Inc.
      //      www.windjack.com, www.pdfscripting.com
      //   for Adobe Systems Inc. www.adobe.com
      //       NOTE: Only for use in an Action Script
      //       Requires:  Acrobat 10 or later
      //   Stamps the PDF file Name/Title/Date onto a PDF
      //   A popup dialog for entering stamping parameters
      //   is displayed for each PDF processed by the Action
      //   Parameters include Position, Text Size, Font, Text Color
      //   The stamp is created watermark
      //   Version 1.2 - 11/5/2020
      //Acrobat JavaScript Dialog
      //Created by DialogDesigner from WindJack Solutions
      //<CodeAbove>
      var aFontNames = [
      "Helvetica",
      "Times",
      "Courier",
      var aDateFmts = [
                  "mm/dd/yyyy",
                  "yyyy-mm-dd",
                  "mmmm d, yyyy",
                  "ddd mmm d, yyyy",
                  "dddd mmmm d, yyyy"
      function SetLabelText(dialog, dlg)
           var strLab = "";
           var oRslt = dialog.store();
           strLab = oRslt["FlNm"]?dlg.strDocFileName:dlg.strDocTitle;
           if(oRslt["HDat"])
              var path = new Array();
               strLab += " - " + ( (dlg.GetListSel(oRslt["DFmt"],path))?path.reverse():"").toString();
           dialog.load({"DcSt":strLab});
      //</CodeAbove>
      if(typeof(global.FileNameStamp) == "undefined")
      global.FileNameStamp =
          result:"cancel",
          DoDialog: function(){return app.execDialog(this);},
          strLabSource:"FlNm",
          strDocStamp:"",
          bUseDate:false,
          strDateFormat:"",
          strFontName:["Helvetica"],
          strFontSize:"12",
          strFontColor:"000000",
          strHorzPos:"PosR",
          nMarginX:"0.5",
          strVertPos:"PosT",
          nMarginY:"0.5",
          strPgRangeSel:"rAll",
          strStrtPg:"",
          strEndPg:"",
          GetRadioSel:function(oRslts,aCtrls){
            for(var strRtn=aCtrls[0];aCtrls.length>0;strRtn=aCtrls.pop()){
              if(oRslts[strRtn] == true)
                return strRtn;
            return "";
          SetListSel:function(list,path){if(path.length == 0) return;
          eval("list[\""+ ((typeof path.join != "function")?path:path.join("\"][\"")) + "\"] = 1")},
          GetListSel:function(oLstRslts,path){
             for(var item in oLstRslts){
                if( ((typeof oLstRslts[item]=="number")&&(oLstRslts[item]>0))
                   || this.GetListSel(oLstRslts[item],path) )
                 {path.push(item);return true;}
             return false;
          bHidden:true,
          nNumPages:1,
          nCurPage:0,
          strDocTitle:"My Title",
          strDocFileName:"mytestdoc.pdf",
          SetTheLabel:SetLabelText,
          initialize: function(dialog)
              var listDFmt = new Object();
              this.SetListSel(listDFmt, this.strDateFormat);
              var listFont =
                  "Helvetica": -1,
              this.SetListSel(listFont, this.strFontName);
              var dlgInit =
                  "Font": listFont,
                  "FtSz": this.strFontSize,
                  "FtCl": this.strFontColor,
                  "MrgH": this.nMarginX,
                  "MrgV": this.nMarginY,
                      "DcSt": this.strDocStamp,
                      "HDat": this.bUseDate,
                      "tFPg": this.strStrtPg,
                      "tTPg": this.strEndPg,
              dlgInit[this.strLabSource] = true;
              dlgInit[this.strHorzPos] = true;
              dlgInit[this.strVertPos] = true;
              dlgInit[this.strPgRangeSel] = true;
              dialog.load(dlgInit);
              dialog.enable(
                      "tTPg": false,
                      "tFPg": false,
                      "DFmt": false,
              if( (this.strStrtPg == "")|| isNaN(this.strStrtPg) || (Number(this.strStrtPg) > this.nNumPages) )
                 if(this.bHidden)
                     this.strStrtPg = "1";
                 else
                     this.strStrtPg = (this.nCurPage+1).toString();
              if((this.strEndPg == "") || isNaN(this.strEndPg) || (Number(this.strEndPg) > this.nNumPages) )
                 this.strEndPg = this.nNumPages.toString();
              var flist = {};
              for(var i=0;i<aFontNames.length;i++)
              for(var nm in font)
                 flist[font[nm]] = -1;
              flist[this.strFontName] = 1;
              var dlist = {};
              var oDt = new Date();
              for(var i=0;i<aDateFmts.length;i++)
                 dlist[util.printd(aDateFmts[i],oDt)] = (i==0)?1:-1;
              var exInit ={"tFPg": this.strStrtPg,"tTPg":this.strEndPg, "sOfN":"of (" + this.nNumPages+")",
                                   "DcSt":(this.strLabSource == "FlNm")?this.strDocFileName:this.strDocTitle,
                                   "TopL":"Working on File: " + this.strDocFileName, "Font":flist, "DFmt":dlist };
              if(this.bHidden && this.strPgRangeSel == "rCur")
                    this.strPgRangeSel = "rAll";
                    exInit["rCur"] = false;
                    exInit[this.strPgRangeSel] = true;
              dialog.load(exInit);
              var exInit = {"ExPg":this.strPgRangeSel =="rFro", "MrgH":this.strHorzPos!="PosC", "MrgV":this.strVertPos!="PosM",
                                      "tFPg":this.strPgRangeSel =="rFro", "tTPg":this.strPgRangeSel == "rFro", "rCur":!this.bHidden,
                                      "DcSt":(this.strLabSource == "Titl"), "DFmt":this.bUseDate};
              dialog.enable(exInit);
              this.SetTheLabel(dialog,this);
          validate: function(dialog)
              if(isNaN(oRslt["FtSz"]) || (Number(oRslt["FtSz"]) < 0))
                   app.alert("Font Size must be a positive number");
                   return false;
              var rg = /([\dabcdef]{2})([\dabcdef]{2})([\dabcdef]{2})/i;
              if(!rg.test(oRslt["FtCl"]))
                   app.alert("The Font Color must be a series of 3 pairs of Hexadecimal numbers,"
                                 + " where each pair represents one 8 bit color component, Red Green Blue\n"
                                 + "For Example:\n   Black = 000000,  Red = FF0000, Green = 00FF00, Blue = 0000FF");
                   return false;
              if(isNaN(oRslt["MrgH"]) || (Number(oRslt["MrgH"]) < 0))
                   app.alert("The Horizontal Margin must be a positive number");
                   return false;
              if(isNaN(oRslt["MrgV"]) || (Number(oRslt["MrgV"]) < 0))
                   app.alert("The Vertical Margin must be a positive number");
                   return false;
              return true;
          commit: function(dialog)
              this.strLabSource = this.GetRadioSel(oRslt,["FlNm","Titl"]);
              this.strDocStamp = oRslt["DcSt"];
              this.bUseDate = oRslt["HDat"];
              this.strDateFormat = (this.GetListSel(oRslt["DFmt"],path))?path.reverse():"";
              this.strFontName = (this.GetListSel(oRslt["Font"],path))?path.reverse():"";
              this.strFontSize = oRslt["FtSz"];
              this.strFontColor = oRslt["FtCl"];
              this.strHorzPos = this.GetRadioSel(oRslt,["PosL","PosC","PosR"]);
              this.nMarginX = oRslt["MrgH"];
              this.strVertPos = this.GetRadioSel(oRslt,["PosT","PosM","PosB"]);
              this.nMarginY = oRslt["MrgV"];
              this.strPgRangeSel = this.GetRadioSel(oRslt,["rAll","rCur","rFro"]);
              this.strStrtPg = oRslt["tFPg"];
              this.strEndPg = oRslt["tTPg"];
          "But1": function(dialog)
              dialog.end("Abrt");
          "tTPg": function(dialog)
              var x;
          "rFro": function(dialog)
              dialog.enable({tFPg:true, tTPg:true, "ExPg":true});
          "rCur": function(dialog)
              dialog.enable({tFPg:false, tTPg:false,"ExPg":false});
          "rAll": function(dialog)
              dialog.enable({tFPg:false, tTPg:false, "ExPg":false});
          "PosB": function(dialog)
              dialog.enable({"MrgV":true});
          "PosM": function(dialog)
              dialog.enable({"MrgV":false});
          "PosT": function(dialog)
          "PosR": function(dialog)
              dialog.enable({"MrgH":true});
          "PosC": function(dialog)
              dialog.enable({"MrgH":false});
          "PosL": function(dialog)
          "DFmt": function(dialog)
          "HDat": function(dialog)
              dialog.enable({"DFmt":dialog.store()["HDat"]});
          "DcSt": function(dialog)
              if(oRslt["Titl"])
                this.strDocTitle = oRslt["DcSt"];
          "Titl": function(dialog)
              dialog.enable({"DcSt":true});
          "FlNm": function(dialog)
              dialog.enable({"DcSt":false});
          description:
              name: "File Name Stamper",
              elements:
                      type: "view",
                      elements:
                              type: "view",
                              char_height: 10,
                              elements:
                                      type: "static_text",
                                      item_id: "TopL",
                                      name: "Put Dialog Controls Here",
                                      char_width: 15,
                                      alignment: "align_fill",
                                      font: "palette",
                                      bold: true,
                                      type: "cluster",
                                      item_id: "cls1",
                                      name: "Label Options",
                                      elements:
                                              type: "view",
                                              align_children: "align_row",
                                              elements:
                                                      type: "radio",
                                                      item_id: "FlNm",
                                                      group_id: "FUse",
                                                      name: "Use File Name",
                                                      variable_Name: "strLabSource",
                                                      type: "radio",
                                                      item_id: "Titl",
                                                      group_id: "FUse",
                                                      name: "Use Document Title (or custom)",
                                                      type: "edit_text",
                                                      item_id: "DcSt",
                                                      variable_Name: "strDocStamp",
                                                      width: 200,
                                                      height: 23,
                                              type: "view",
                                              elements:
                                                      type: "check_box",
                                                      item_id: "HDat",
                                                      variable_Name: "bUseDate",
                                                      item_id: "sta2",
                                                      type: "popup",
                                                      item_id: "DFmt",
                                                      variable_Name: "strDateFormat",
                                                      width: 180,
                                                      height: 23,
                                                      char_width: 8,
                                              type: "view",
                                              elements:
                                                      item_id: "sta1",
                                                      type: "popup",
                                                      item_id: "Font",
                                                      variable_Name: "strFontName",
                                                      width: 111,
                                                      height: 23,
                                                      char_width: 8,
                                                      item_id: "sta0",
                                                      alignment: "align_right",
                                                      font: "dialog",
                                                      type: "edit_text",
                                                      item_id: "FtSz",
                                                      variable_Name: "strFontSize",
                                                      width: 29,
                                                      height: 23,
                                                      item_id: "sta3",
                                                      name: "Color(8bit Hex RGB):",
                                                      font: "dialog",
                                                      type: "edit_text",
                                                      item_id: "FtCl",
                                                      variable_Name: "strFontColor",
                                                      width: 80,
                                                      height: 23,
                                                      char_width: 8,
                                      type: "cluster",
                                      item_id: "cls1",
                                      width: 188,
                                      height: 80,
                                      char_width: 8,
                                      char_height: 8,
                                      elements:
                                              type: "view",
                                              align_children: "align_top",
                                              elements:
                                                      type: "radio",
                                                      item_id: "PosL",
                                                      group_id: "PosH",
                                                      variable_Name: "strHorzPos",
                                                      type: "radio",
                                                      item_id: "PosC",
                                                      group_id: "PosH",
                                                      type: "radio",
                                                      item_id: "PosR",
                                                      group_id: "PosH",
                                                      item_id: "sta2",
                                                      name: " Margin (inches):",
                                                      type: "edit_text",
                                                      item_id: "MrgH",
                                                      variable_Name: "nMarginX",
                                                      char_width: 8,
                                              type: "view",
                                              elements:
                                                      type: "radio",
                                                      item_id: "PosT",
                                                      group_id: "PosV",
                                                      variable_Name: "strVertPos",
                                                      type: "radio",
                                                      item_id: "PosM",
                                                      group_id: "PosV",
                                                      type: "radio",
                                                      item_id: "PosB",
                                                      group_id: "PosV",
                                                      item_id: "sta2",
                                                      name: "Margin (inches):",
                                                      type: "edit_text",
                                                      item_id: "MrgV",
                                                      variable_Name: "nMarginY",
                                                      char_width: 8,
                                      type: "cluster",
                                      item_id: "cls3",
                                      elements:
                                              type: "radio",
                                              item_id: "rAll",
                                              group_id: "GRP1",
                                              variable_Name: "strPgRangeSel",
                                              height: 20,
                                              type: "radio",
                                              item_id: "rCur",
                                              group_id: "GRP1",
                                              name: "Current (Applies only to Open Document)",
                                              height: 20,
                                              type: "radio",
                                              item_id: "rFro",
                                              group_id: "GRP1",
                                              width: 12,
                                              height: 24,
                                              type: "edit_text",
                                              item_id: "tFPg",
                                              variable_Name: "strStrtPg",
                                              height: 24,
                                              char_width: 6,
                                              item_id: "sta1",
                                              height: 24,
                                              type: "edit_text",
                                              item_id: "tTPg",
                                              variable_Name: "strEndPg",
                                              height: 24,
                                              char_width: 6,
                                              item_id: "sOfN",
                                              name: "of (N)          ",
                                              height: 24,
                              type: "view",
                              elements:
                                      type: "ok_cancel",
                                      ok_name: "Apply",
                                      cancel_name: "Skip",
                                      type: "button",
                                      item_id: "But1",
                                      name: "Abort Process",
                                      type: "gap",
                                      item_id: "gap1",
                                      width: 210,
                                      height: 10,
                                      item_id: "sta1",
                                      name: "version 1.2  11/5/2010",
      var oDoc = event.target;
      if(typeof(oDoc.xfa) == "undefined")
          global.FileNameStamp.bHidden = oDoc.hidden;
          global.FileNameStamp.nNumPages = oDoc.numPages;
          if(!oDoc.hidden)
             global.FileNameStamp.nCurPage = oDoc.pageNum;
          global.FileNameStamp.strDocTitle = oDoc.info.title;
          global.FileNameStamp.strDocFileName = oDoc.documentFileName;
          var cRtn = global.FileNameStamp.DoDialog();
          if("ok" == cRtn)
              // Setup starting parameters
              var nPgStart, nPgEnd;
              var nTextSize = Number(global.FileNameStamp.strFontSize);
              var strLabel = global.FileNameStamp.strDocStamp.replace(/\n/g,"\r");
              // Get Font Color
              rgCol = /([\dabcdef]{2})([\dabcdef]{2})([\dabcdef]{2})/i;
              rgCol.test(global.FileNameStamp.strFontColor);
              var aFontCol = ["RGB", parseInt(RegExp.$1,16)/255,
                              parseInt(RegExp.$2,16)/255, parseInt(RegExp.$3,16)/255];
              switch(global.FileNameStamp.strPgRangeSel)
                case "rAll":
                  nPgStart = 0;
                  nPgEnd = oDoc.numPages -1;
                  break;
                case "rCur":
                  nPgEnd = nPgStart = oDoc.hidden?0:oDoc.pageNum;
                  break;
                case "rFro":
                  nPgStart = Number(global.FileNameStamp.strStrtPg)-1;
                  if(nPgStart > (oDoc.numPages -1))
                    nPgStart = oDoc.numPages -1;
                  nPgEnd = Number(global.FileNameStamp.strEndPg)-1;
                  if(nPgEnd > (oDoc.numPages -1))
                  break;
                 var nTextAlign,nHAlign,nVAlign;
                 var nHMarg, nVMarg;
                 var nMargX = Number(global.FileNameStamp.nMarginX) * 72;
                 switch(global.FileNameStamp.strHorzPos)
                    case"PosL":
                      nTextAlign = app.constants.align.left; // Left Aligned Text
                      nHAlign = app.constants.align.left;
                      nHMarg = nMargX;
                      break;
                    case"PosC":
                      nTextAlign = app.constants.align.center;
                      nHAlign = app.constants.align.center;
                      nHMarg = 0;
                      break;
                    case"PosR":
                      nTextAlign = app.constants.align.right;
                      nHAlign = app.constants.align.right;
                      nHMarg = -nMargX;
                      break;
                 var nMargY = Number(global.FileNameStamp.nMarginY) * 72;
                 switch(global.FileNameStamp.strVertPos)
                    case"PosT":
                      nVAlign = app.constants.align.top;
                      nVMarg = -nMargY;
                      break;
                    case"PosM":
                      nVAlign = app.constants.align.center;
                      nVMarg = 0;
                      break;
                    case"PosB":
                      nVAlign = app.constants.align.bottom;
                      nVMarg = nMargY;
                      break;
               // Find and rename watermark;
               var aGs = oDoc.getOCGs();
               for(var i=0;aGs && (i<aGs.length);i++)
                  if(aGs[i].name == "Watermark");
                     aGs[i].name = "Old_Watermark";
               try{
                //  Create watermark
                oDoc.addWatermarkFromText({cText:strLabel, nTextAlign:nTextAlign, cFont:global.FileNameStamp.strFontName,
                      nFontSize:nTextSize, aColor:aFontCol, nStart:nPgStart, nEnd:nPgEnd,
                      nHorizAlign:nHAlign, nHorizValue:nHMarg,
                      nVertAlign:nVAlign, nVertValue:nVMarg});
               }catch(e){
                  app.alert("Error applying Label:\n" + e);
                     aGs[i].name = "DocumentLabel";
                     break;
          else if(cRtn == "Abrt")
            event.rc = false;
      else
         if(3 == app.alert(oDoc.documentFileName + ": is a LiveCycle Form, which cannot be labeled\n\n Do you want to continue processing files? (Pressing No will Abort the file processing)",1,2))
           event.rc = false;
        • 1. Re: File Name Stamper
          George_Johnson MVP & Adobe Community Professional
          It would be possible to do what you want, but it would involve considerable reprogramming. Maybe Thom willl do it for you.
          1 person found this helpful
          • 2. Re: File Name Stamper
            George,
            Many thanks for trying.
            Would you know if I could find a code that would do something similar?
            I simply want to insert the actual filename of the PDF inside the document, preferably on the header of the document.
            • 3. Re: File Name Stamper
              There are a number of simpler ways to do this. Thom's Action is great, but sounds like it might be overkill for this. Text can be added a numer of ways, including a form field, text annotation, layer (aka Watermark, as with Thom's script), and stamp. It can also then be flattened so it gets converted to regular page contents, preventing the user from interacting with it and perhaps changing it. Which you choose depends on you needs. If you provide a bit more description, I could suggest a simpler script you can use.
              Also, please clarify exactly what you want included. Do you want just the file name (example.pdf), the file name without the extension (example), or the complete path (c:\dir1\dir2\example.pdf)?
              • 4. Re: File Name Stamper
                1. I have 1000+ PDF files that need the filenames stamped on the header of the document. Only the filename, without the extension (example).
                2. I would like to be able to change the font type, size and header margins, because the filenames are long.
                3. I would like to output the files to a folder.
                George, thank you very much.
                • 5. Re: File Name Stamper
                  One more thing, do you need it to be dynamic so that if the file name changes, the display of the file name is automatically updated whenever it is opened? If you use a form field for this, this is possible, and it's also possible to set the field to automatically adjust the size of the font in an ettempt to display the entire file name, down to a minimum size of 4.
                  • 6. Re: File Name Stamper
                    Hi George, the PDF files don't need to be dynamic.
                    • 7. Re: File Name Stamper
                      gkaiseril MVP & Adobe Community Professional
                      Have you considered rethinking about using the annotation stamp for this. Annotations do not always print and by default they do not print. Then there is the issue that your file name stamp will print in an annotation/comments summary.
                      You can can add the file name when adding a header or footer or even in a form field. Header and footers will always print but fields could be set not to print.
                      You also should consider that a file could be renamed and you might need to allow for this action.
                      • 8. Re: File Name Stamper
                        Thanks. However, we need to print the PDFs for shipment production, and the filename will be needed to print...
                        • 9. Re: File Name Stamper
                          Then I would go with a form field or adding a header or footer. These actions would need to be scripted and could be added as a menu item, toolbar button, batch process, or a will print action.
                          If you use Acrobat to add the field, then you could use a will print action to insert the field name before the PDF is printed. This would update the field name just before printing. You could even use a Will Save action to update the field name before the PDF is saved.
                          • 10. Re: File Name Stamper
                            Appreciate the advice. Do you have any suggestions on how to script the action? I am a doctor with zero expertise on programming.
                            Thank you kindly.
                            • 11. Re: File Name Stamper
                              grandsportvette Level 1
                              Good morning.
                              I have the exact same question and anxiously awaiting for the miracle cure! How to file name stamp multiple documents at the same time without that screen to press enter appearing after every file that has been processed. I noticed that the bates numbering works well with a whole bunch of files automatically so is there any way to get the file name stamper to work the same as the bates numbering.
                              • 12. Re: File Name Stamper
                                Thom Parker Adobe Community Professional
                                You will find a version of the File Name Stamper that does not popup the dialog with every PDF, and with more options here: pdfscripting.com
                                This is a membership site chuck full of examples, articles, and tools.
