4 Replies Latest reply on Jul 7, 2012 1:24 PM by Peter Spier
    Keep actual image size when rotating and exporting to PDF
    Peroyomas Level 1
      When one rotates an image in a non-right angle in InDesign, the resulting image in the PDF, even if looks the same size of the original image when compared save for being rotated, actually shrink in size. That's noticieable when one saves the image from the PDF as the rotated image appears rotated inside the same size of the original, rather than being larger. I fear it may cause some quality loss at print. Is there any workaround around it?
      Or it is just a previsualization glitch and the file prints normal? (as while importing the PDF in Illustrator seems to keep the original resolution of the image)
