1. Re: redact - pattern
George_Johnson Jul 8, 2012 5:52 PM (in response to drop box)Have you tried editing the SearchRedactPatterns.xml file, using the existing entries as a guide? What patterns would you like to add?
2. Re: redact - pattern
drop box Jul 9, 2012 6:22 AM (in response to George_Johnson)I have found the file named SearchRedactPatterns.xml (thank you) and I just started trying to make sense the code defining text pattern. (I also need to get rights to modify this file - it's locked.)
I want to add a pattern that fits a pair of numbers (latitude and longitude). The pattern is always a pair, comma and space separate the pair, second number preceeded by negative sign. There are two digits before the decimal point. The number of digits after the decimal points will change - so I guess I define more than one pattern - but even with a single, new pattern fitting the example below, I would have saved myself work and saved myself time.
Example pattern:
36.63, -82.551
3. Re: redact - pattern
George_Johnson Jul 9, 2012 10:01 AM (in response to drop box)I haven't tried adding a new pattern yet, but it looks like you should be able to just create a single regular expression for that pattern. If you need more help, and I try it later today.
4. Re: redact - pattern
drop box Jul 9, 2012 11:03 AM (in response to drop box)I found a website that explains text searches usin regular expressions (RegEx) -
http://www.Regular-Expressions.info/
Looks like the RegEx code at this "info" website is similar to the text pattern code in the Adobe xml file (SearchRedactPatterns.xml).
I need to match and redact a Lat. and Long. coordinate pair such as:
36.63, -82.551 (fixed length)
36.6nnn, -82.5nnnnn (variable length)
I want to try my code (untested code - don't know if it is correct), first matching a fixed length pair, second matching variable-length :
<val>(\d\d.\d\d\,\ \-\d\d\.\d\d\d\)</val>
<val>(\d\d\.\[0-9][0-9]{0,4}\,\ \-\d\d\.\[0-9][0-9]{0,6})</val>
5. Re: redact - pattern
George_Johnson Jul 9, 2012 11:57 AM (in response to drop box)That second one should be:
<val>(\d{2}\.\d{0,4}, \-\d{2}\.\d{0,6})</val>
Go ahead and try it out.
Edit: fixed mistake
