How do I uninstall Robohelp 3? I am running Windows XP and this program does not appear in the list when I am running Add/Remove programs. I don't have the install CD either.
The normal way?
Is there a problem? A little more detail may help us to help you ;>)
I am a new employee and have a new laptop running Windows XP. RH3 was installed on my PC in error. I could not open any of the .xpj files so tech support installed RH7 without uninstalling RH3. Every time I double click an .xpj or .hhp file, RH3 tries to open it and gives the following error message: "Open project was cancelled or the application was unable to load database for xxx.xpj". The file association is set for RH7. I can open the files after I open RH7 and they open normally.
I think if we can uninstall RH3 things would work correctly. However RH3 is not listed in Add/Remove Programs in the Control Panel and no one in the company has the original install CD.
Try revouninstaller – it can often scrub away traces of a bad install.
@Jeff - Revouninstaller does not work if the program to be uninstalled is not listed in Add/Remove.
@MJPVCBS - If no one has the CD, how was it installed? I am guessing from an image. Two options, there is something on Microsoft's site about cleaning up a bad install that does not appear in Add/Remove but I cannot recall its name right now. However, I think the better option is for IT to build your machine from a different image.
I seem to remember that it has the ability to search out fragments in the registry even after the program has been removed.
@Jeff
From RevoUninstaller's FAQs.
If the program is not listed in Revo Uninstaller Pro you can use Forced Uninstall feature of Revo Uninstaller Pro, which does not require a program to be installed or listed properly - just browse to its folder/file and enter its name.
I was thinking of the free version, maybe you are thinking of the pro version.
