1. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
lybarrondo Jun 25, 2012 3:18 PM (in response to Silverarrow23)Jonathan,
I had the same problem a month ago. Here is the post:
http://forums.adobe.com/message/4472028#4472028
I haven't been able to find a solution and never got a response from Adobe.
- Loren
2. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
AllDayDevJun 25, 2012 11:06 PM (in response to Silverarrow23)
Be sure you have installed the latest updates for your Adobe CS6 software. Go to Help > Updates to ensure you have the latest. One in particular that you need to install is for CSXS, although I do not recall the exact name of it.
After updating, restart your computer to ensure the associated background services are refreshed.
If it's still not working then, there are a couple of log files we would want to check what is going on at your end. These are called "init_status.txt" and "auth_status.txt" and are found in a folder called "PGB" in /Users/<YOUR USER NAME>/Library/Application Support/Adobe on Mac OS, or C:\Users\<YOUR USER NAME>\AppData\Roaming\Adobe on Windows 7.
3. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
lybarrondo Jun 29, 2012 12:29 PM (in response to AllDayDev)Carey,
I checked on updates and there were two:
Speed Grade CS6 6.0.1
DPS Desktop Tools CS6 2.0.2
I've updated CS6, restarted, but had the same error.
I've searched for the two files you mention and I do not have the PGB folder or the files on my computer.
What should I try next?
Thanks for trying to help out with this. I have notice that I am not the only one experiencing this.
4. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
bwroberts Jul 10, 2012 4:12 PM (in response to lybarrondo)I have the same problem, very frustrating.
5. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
lybarrondo Jul 11, 2012 2:59 AM (in response to bwroberts)What is the size of the build? Mine is over the 10 meg limit set by phonegap. I was going to try a smaller build size to see if that was the problem.
6. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Silverarrow23 Jul 12, 2012 3:23 AM (in response to lybarrondo)its about 9meg but i started using phonegap build by syncing my dreamweaver folder to a github repository
7. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
AllDayDevJul 13, 2012 1:06 PM (in response to lybarrondo)
If you're not able to connect from within Dreamweaver, have you tried logging into PBG directly?
8. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Silverarrow23 Jul 13, 2012 1:27 PM (in response to AllDayDev)I can login to build just fine, but whenever i try in dreamweaver i always get: "we are currently having server problems"
9. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
lybarrondo Jul 13, 2012 1:36 PM (in response to Silverarrow23)I can build using github and PGB directly (i.e., not using CS6). That's not really a solution though as a major consideration in upgrading to CS6 was this feature.
10. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
AllDayDevJul 13, 2012 2:42 PM (in response to lybarrondo)
Thanks for confirming that you can log in directly.
Can you check for the log files I mentioned above?
The logs should help us identify why it's failing for you.
Let me know if you have any difficulty locating these files.
11. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
bepongchris Jul 19, 2012 6:44 AM (in response to Silverarrow23)I too am having this problem.
My dreamweaver is up to date and I have checked for those txt files and only have "auth_token.txt".
It says "{error:'Authentication Failure. Could not connect to server.'}"
Thanks for any help.
12. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
mwolsten1 Aug 20, 2012 3:05 PM (in response to Silverarrow23)Having the same problem - no solution found so far...
13. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
mwolsten1 Aug 20, 2012 9:08 PM (in response to lybarrondo)did u check that your files were not hidden?
14. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
dustinwilson80 Aug 21, 2012 9:29 AM (in response to mwolsten1)Hello guys,
Not sure if this will help anyone else, but it helped me move along with my project.
I was having the issue "Looks like we are having some server issues... etc.".
I read that there is a size limit of 10 mb. Which could be tough to work with for some people. This includes EVERYTHING in your site directory, so if you're keeping some photoshop files in an "images" directory or something, it will try to upload those as well, and fail. I removed everything except the necessaties from my site directory, and it created a new Phonegap project without any problems.
Hope that helps someone.
15. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
onFacepalm Aug 21, 2012 11:03 PM (in response to AllDayDev)I am having exactly the same problem.
Can manually login at the PGB-website but not with DW CS6.
The files init_status.txt and auth_status.txt doesn't exist on my system, just the file auth_token.txt with the same content as bepongchris reported.
The size limit is not the problem as this already happens when trying to login not when uploading a build. And of course I tested with a tiny test site.
I am still stuck.
16. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Misi Aug 22, 2012 8:54 AM (in response to AllDayDev)Same problem here. So please, ADOBE, help!
17. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
jhodgski Aug 24, 2012 5:48 PM (in response to Silverarrow23)I was having this same problem. I ran the CS6 updates (Help > Updates...) then deleted all the chaff from my source directory (inc. a lot of unused videos) and then build completed fairly quickly.
An informative error message wouldn't have gone amiss though...
18. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
kamal kant jangra Sep 21, 2012 5:22 AM (in response to AllDayDev)m facing same problom after login please help ????
look @ this issues
We're sorry, but something went wrong.
We've been notified about this issue and we'll take a look at it shortly.
19. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
sudarshan.t Sep 22, 2012 6:28 AM (in response to Silverarrow23)Can you post a screenshot of your folder hierarchy here - your main site folder and the subfolder where you're trying to use the PhoneGap Build for your app/ site.
The 10MB limit is not only for the mobile site. If your mobile site folder resides within a main site folder, PhoneGap Builder calculates the 10MB limit for your parent folder. This may be the culprit?
20. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
kamal kant jangra Sep 22, 2012 6:53 AM (in response to sudarshan.t)I have already resolved this problem......thanx
21. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
sudarshan.t Sep 22, 2012 6:55 AM (in response to kamal kant jangra)Can you share how you did? Maybe that could help the other users who may be looking for a solution.
22. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
kamal kant jangra Sep 22, 2012 7:00 AM (in response to sudarshan.t)my adobe ID is not linked in phonegap. so i have linked my ID with phonegap and its working fine....
23. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Misi Sep 23, 2012 2:47 AM (in response to kamal kant jangra)@kamalkant: what do you mean by "link the adobe ID"? how did you do that?
24. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
kamal kant jangra Sep 23, 2012 5:03 AM (in response to Misi)hi misi
go to this link https://build.phonegap.com/people/edit
and linked your ADOBE ID and Github Account.
25. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
kamal kant jangra Sep 23, 2012 5:24 AM (in response to kamal kant jangra)any one please help.... how to access ios signing key
26. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
sudarshan.t Sep 23, 2012 6:55 AM (in response to kamal kant jangra)kamal kant jangra wrote:
Please create a new thread here: http://forums.adobe.com/community/dreamweaver/dreamweaver_general
This thread is going out of the scope of the OP's original question.
27. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
varun r ramani Oct 17, 2012 11:04 AM (in response to Silverarrow23)it is may be because a free phonegap service account allows you to upload only one app. you have to delete the old app before uploading another one.
28. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
varun r ramani Oct 17, 2012 11:07 AM (in response to kamal kant jangra)i have my adobe id linked with PGB but am still having the same problem.
29. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
kamal kant jangra Oct 17, 2012 11:18 AM (in response to varun r ramani)that's not true. I have checked at all... you can build more than one with multiple app. are you using dreamweaver with build service or through phonegap website???
30. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Arcanelight Mar 28, 2013 11:21 PM (in response to AllDayDev)- I have a phonegap account and it's linked to the Adobe account;
- Logging in phonegap.com and compiling my apps in their website, works just fine;
- I have always Dreamweaver signed in to the Adobe account;
- Here are the content of my files:
init_status.txt: {"message": "Failed to upload application. Unable to create zip file. Reason: null","error": 404}
auth_status.txt: {"statusCode": 200,"statusMessage": "Authenticated"}
Hope this helps you help us.
I just want to say that this was THE feature that made me buy CS6 in the first place, and it's not working as intended.
31. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Suraj_25Apr 1, 2013 1:59 AM (in response to Arcanelight)
What version of Dreamweaver are you using? Go to Help – About Dreamweaver and provide us the Dw version and build number.
If you are not on latest version please click on “Help – Updates” and update Dw to latest version. (12.0.3 or 12.2 are must for PGB)
login to https://build.phonegap.com/ and try to build an app directly here. Let us know if you are able to do so.
32. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Juanster Oct 15, 2013 4:38 AM (in response to Suraj_25)I have the same problem. I have done everything and still can't connect.
I was about to purchase Dreamweaver CC but if this is not working I'm not doing it.
Also a support team guy has redirect me to this forum, but no luck solving the problem.
I can't connect to Phonegap Builder, when I indicate email and password it keeps thinking for a couple of minutes and then "temporary errors on the servers"...
33. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
elyazalee Feb 9, 2014 11:17 PM (in response to Juanster)Same problem with Dreamweaver CC
Login to PhoneGap website : https://build.phonegap.com : ok
Login PhoneGap with Dreamweaver : not ok
I have same error message : "temporary errors on the servers"
34. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
PreranFeb 12, 2014 9:32 AM (in response to elyazalee)
Hi all,
I am asking around. Stay tuned.
Preran
35. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Divya_b_cFeb 13, 2014 8:25 PM (in response to Preran)
Folks, you cannot build apps using phonegap if your root folder name contains high ASCII or double byte characters. On trying to use such folders, phonegap throws the error "Looks like we are having server trouble. Please try again".
36. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
elyazalee Feb 13, 2014 10:43 PM (in response to Divya_b_c)I tried on c:\test
Same bug..........
37. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Divya_b_cFeb 17, 2014 6:26 AM (in response to elyazalee)
Can someone please share your "PGB" folder which is present in the below location ?
38. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
elyazalee Feb 17, 2014 6:28 AM (in response to Divya_b_c)This folder is empty...
39. Re: PhoneGap Build:Cannot Connect to Server Dreamweaver CS6
Divya_b_cFeb 17, 2014 9:10 PM (in response to elyazalee)
@elyazalee ,which version of dreamweaver are you on? Also are you able to login to PGB from DW?
