Hi All,
I have a problem wiith first proect that I'm trying to make in Flash Builder 4.6. I would like to complete this tutorial:
http://www.adobe.com/devnet/flashplayer/articles/creating-games-away3d.html
I followed exactly all steps, but when I run the aplication it doesn't show anything in the browser. For a second just popout a black screen. One thing that is different then tutorial is that I have a Flash Builder 4.6 and in the tutoral they recomend Flash Builder 4.5.
Do you have any idea what can be wrong?
regards,
Spontan
Do you have a link to your work? Are you receiving any debug/error messages? Can you post the code?
I will show you a screen from my project. If you would like to see something more just tell me.
Not really sure the example is operational.
I downloaded the files, followed the instructions, corrected the null object reference error in the ParserBase.as file, but never saw the vase load either, only the background of the base. I suspect something may be amiss with the parser package as the vase file never loaded, but do not have the time to keep digging.
If any consolation, I do not believe the issue is with anything you are doing. Though I also do not believe an individual would purposefully post a bad example. Possible a change to his code base, made after he posted the example, inadvertently broke his example.
thanks for help. I won't be digging also.
