Photoshop CS6 Extended Slow Load ("Measuring Memory...")
Jul 13, 2012 Jul 13, 2012
Hi guys!
Sorry English is not my native language.
I am run Photoshop CS6 Extended 64-bit (from design premium) on Windows 7, 64-bit with 8GB RAM.
When I first start PS, it looks like it freeze on the text "Measuring Memory". If I wait for about 30 seconds, it will eventually load and everything works fine. No issues with Save for Web or anything.
I have read the other threads on this and tried all of these solutions:
  • Checked my ram in memtest (15 passes, no error)
  • Trash preferences and open again
  • Un-install and re-install (tried twice)
  • Updated PS to latest with Adobe Update
  • Reboot machine
This happen when I first run Windows, so lack of RAM is not the issue. I have no printers, other hard drive, or remote network drive attached to machine. Scratched disk is set to the boot disk (C:\)
If it help, Illustrator CS6 and InDesign CS6 load normally.
Do you have any suggestions to fix this? Thank you!
Richard Montouchet
21.2K
Adobe
Congratulations on having such a huge amount of memory that it takes 30 seconds to measure it all!    Just kidding - sorry.
You've done all the things a reasonable person would do...  Some other things I might suggest are:
1.  Check to ensure your display driver is up to date - go to the web site of the maker of your video card, not Microsoft.
2.  Try disabling the Use Graphics Processor setting in Edit - Preferences - Performance, and restart Photoshop.
3.  Remove any 3rd party plug-ins (reinstall won't remove plug-ins, so I thought I'd mention it).
4.  Check to see if you have the same behavior with the 32 bit Photoshop as the 64 bit Photoshop.
-Noel
Sep 17, 2012 Sep 17, 2012
I'm having the same problem as OP describes, which started occurring after I put a new, additional hard drive into the computer.  I tried 64bit vs 32bit and found that the latter didn't have the same problem - any thoughts as to what that might imply, and what would be good to troubleshoot from there?..
Measuring memory gets the installed RAM, and checks all mounted hard drives to see how much space is available (to see if the app can continue booting).
If something is wrong with your hard drives, an extern drive, or a network drive - it could take a while.
Normally, it takes under a second.
Longer than that means that something is wrong with your drives.
Chris - can you recommend a next step for me to try?  I have not experienced any other issues since installing the new drive.
Sep 18, 2012 Sep 18, 2012
Unmount the drive, launch Photoshop - if it's faster, then the drive was the problem.
Alright - I can try that, but ultimately I don't want to simply get rid of the drive.  What exactly is the problem that the drive could be causing, and how might I remedy that without removing it?
Is it just spinning down to save power, and now it's having to spin up when you start Photoshop?  That does take time.
You can change your system settings to keep it from spinning down in the first place, or to remain on a lot longer before spinning down.
-Noel
Noel - I checked that, but I don't think it's the problem.  The drive is not set to spin down for power saving; as well, even if I let Photoshop open (wait for the "measuring memory" to complete), close it, then open it again, the same problem persists.
For the record, I'm on Windows 7 64 bit with 8 GB RAM; my primary HD is solid state, where both Windows and Photoshop reside.  I originally had one other HD, at which point Photoshop had no issues: it opened very quickly.  The problems started showing up after I put in a second additional drive.
If spinning up isn't the problem, then there's something else making a simple OS call run slowly for that drive (assuming you verified that drive was the issue).
Sep 22, 2012 Sep 22, 2012
I found my issue!  It wasn't the new drive; it was actually an over-zealous firewall blocking a connection that Photoshop was attempting to make to 127.0.0.1 during the "measuring memory" phase.  As mentioned, this wasn't a problem in the past - maybe it came with a recent update?
So there's a thing to check, for anyone else experiencing this issue.
Sep 23, 2012 Sep 23, 2012
127.0.0.1 is localhost (a loopback to the same machine, for communicating with other applications).
If a firewall is blocking that, the firewall has some serious problems.
But thanks for letting us know, now we can do some additional investigation.
Aug 21, 2012 Aug 21, 2012
its a security issue, by me was the problem with eset smart security... i reinstalled the firewall and now its ok
I have this same "measuring memory" 1-2min hangup when opening Photoshop CS6 (win7 64), but only if Premiere is already open.
Not sure if this helps the overall issue or not, but there you go!
OK, that's odd.  Premiere being open shouldn't have any impact - even if Premiere was actively using the disks.
Any chance the two together are somehow chewing up GPU memory?
I've found GPU-Z to be handy for monitoring GPU memory usage:  http://www.techpowerup.com/gpuz/
-Noel
Hm-m. With PrPro, as of CS 5, depending on the settings, and the GPU, it CAN chew up a lot of video memory with MPE in a CUDA enabled card, or, as of CS 6, OpenGL in certain Mac's.
Interesting observation, and one that I would not have immediately thought about.
Hunt
One question, that I would pose, would be how much memory is allocated to PS in Edit>Preferences?
Premiere IS a memory hog, but only when working. It is also usually good at releasing memory, when not working.
On my laptop, with XP-Pro, and a fixed Page File of about 10GB on a separate HDD, and only 4GB of installed RAM, I constantly run PrPro, PS, Encore, and maybe even AE. Not one memory issue. Obviously, only one Adobe program is up and running, and the others are minimized.
Hunt
Guest
Jan 11, 2013 Jan 11, 2013
Hey rmontouchet, did you even get Photoshop CS6 meausing memory issue fixed?  I just installed it on my new machine and I am having the same issues.
Jan 13, 2013 Jan 13, 2013
That measuring memory issue happens whenever something is blocking Photoshops abillity to connect to the internet - most probably a result of a Firewall blocking that access.
But for whatever reasons Photoshop needs to connect to the internet to measure the memory , it just works fine if you adjust your Firewall settings ...
Cheers,
eve
Another possibility is that some Adobe sites have been added to your local hosts file, which is consulted to resolve names to addresses.
-Noel
Guest
Thanks Noel for the tip, but I didn't see any Adobe sites in my local host file.
And Eve, I will keep messing around with my firewall to see if that's the case.
Nov 30, 2013 Nov 30, 2013
Had the same issue with CS6 64-bit on Windows 8.1. Resolved it by going to Control Panel > Windows Firewall > Allow an app or feature through Windows Firewall > Change Settings > Allow another app..., then browsed to Adobe Photoshop CS6 (C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe). Made sure Domain, Private and Public was checked.
Nov 01, 2015 Nov 01, 2015
HI..
I am having the same problem.
how can i check the firewall blocking on a MAC?
here is my configuration
Adobe Photoshop Version: 13.0.6 (13.0.6 20131025.r.54 2013/10/25:21:00:00) x64
Operating System: Mac OS 10.10.5
System architecture: Intel CPU Family:6, Model:70, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2000 MHz
Built-in memory: 8192 MB
Free memory: 4566 MB
Memory available to Photoshop: 6884 MB
Memory used by Photoshop: 70 %
Image tile size: 1024K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Basic
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenCL Version: 2.1
OpenGL Version: 2.1
Video Rect Texture Size: 16384
OpenGL Memory: 1536 MB
Video Card Vendor: Intel Inc.
Video Card Renderer: Intel Iris Pro OpenGL Engine
Display: 2
High DPI Monitor
Display Depth: 32
Display Bounds: top=22, left=1600, bottom=900, right=3040
Video Renderer ID: 16925954
Video Card Memory: 1536 MB
Display: 1
Main Display
Display Depth: 32
Display Bounds: top=0, left=0, bottom=900, right=1600
Serial number: 92299177697724506256
Application folder: /Applications/Adobe Photoshop CS6/
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Macintosh HD, 232.6G, 47.9G free
Required Plug-ins folder: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/
Primary Plug-ins folder: /Applications/Adobe Photoshop CS6/Plug-ins/
Additional Plug-ins folder: /Applications/
Installed components:
   adbeape.framework   adbeape   3.3.8.19346   66.1025012
   AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
   adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
   AdobeACE.framework   AdobeACE   2.19.18.20743   66.507768
   AdobeAGM.framework   AdobeAGM   4.26.20.20743   66.507768
   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
   AdobeBIB.framework   AdobeBIB   1.2.02.20743   66.507768
   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.507768
   AdobeCoolType.framework   AdobeCoolType   5.10.33.20743   66.507768
   AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120720
   AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
   AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
   AdobeLinguistic.framework      17206
   AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
   AdobeOwl.framework   AdobeOwl   5.0.4   79.517869
   AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
   AdobePDFSettings.framework   AdobePDFSettings   1.4
   AdobePIP.framework   AdobePIP   7.0.0.1686
   AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
   AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
   AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
   AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
   ahclient.framework   ahclient   1.7.0.56
   aif_core.framework   AdobeAIF   3.0.00   62.490293
   aif_ocl.framework   AdobeAIF   3.0.00   62.490293
   aif_ogl.framework   AdobeAIF   3.0.00   62.490293
   AlignmentLib.framework   xcode   1.0.0.1
   amtlib.framework   amtlib   6.0.0.75
   boost_date_time.framework   boost_date_time   6.0.0.0
   boost_signals.framework   boost_signals   6.0.0.0
   boost_system.framework   boost_system   6.0.0.0
   boost_threads.framework   boost_threads   6.0.0.0
   Cg.framework   NVIDIA Cg
   CIT.framework   CIT   2.1.0.20577   146758
   data_flow.framework   AdobeAIF   3.0.00   62.490293
   dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
   dvacore.framework   dvacore   6.0.0.0
   dvamarshal.framework   dvamarshal   6.0.0.0
   dvamediatypes.framework   dvamediatypes   6.0.0.0
   dvaplayer.framework   dvaplayer   6.0.0.0
   dvatransport.framework   dvatransport   6.0.0.0
   dvaunittesting.framework   dvaunittesting   6.0.0.0
   dynamiclink.framework   dynamiclink   6.0.0.0
   FileInfo.framework   FileInfo   66.145433   66.145433
   filter_graph.framework   AdobeAIF   3.0.00   62.490293
   hydra_filters.framework   AdobeAIF   3.0.00   62.490293
   ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
   ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
   image_compiler.framework   AdobeAIF   3.0.00   62.490293
   image_flow.framework   AdobeAIF   3.0.00   62.490293
   image_runtime.framework   AdobeAIF   3.0.00   62.490293
   LogSession.framework   LogSession   2.1.2.1681
   mediacoreif.framework   mediacoreif   6.0.0.0
   PlugPlug.framework   PlugPlug   3.0.0.383
   UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
   wrservices.framework
Required plug-ins:
   3D Studio 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
   Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
   Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Average 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Average.plugin”
   Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Camera Raw 9.1.1 (461), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Camera Raw Filter 9.1.1 (461), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Cineon 13.0.6 x001  ©2002-2013 Adobe Systems Incorporated - from the file “Cineon.plugin”
   Clouds 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Collada DAE 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
   Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crop and Straighten Photos 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
   Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
   Difference Clouds 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Eazel Acquire 13.0.6 x001  ©1997-2013 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
   Embed Watermark NO VERSION - from the file “DigiSign.plugin”
   Entropy 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   FastCore Routines 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “FastCore.plugin”
   Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Flash 3D 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
   Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Google Earth 4 KMZ 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
   Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
   IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   JPEG 2000 13.0.6 x001  ©2001-2013 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
   Kurtosis 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
   Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
   Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
   Matlab Operation 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Maximum 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mean 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Measurement Core 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
   Median 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Minimum 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   MMXCore Routines 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MMXCore.plugin”
   Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Multiprocessor Support 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
   Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   NTSC Colors 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
   Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
   OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   PCX 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PCX.plugin”
   Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Photoshop 3D Engine 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
   Picture Package Filter 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pixar 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “Pixar.plugin”
   Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Portable Bit Map 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PBM.plugin”
   Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Radiance 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - from the file “Radiance.plugin”
   Range 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Read Watermark NO VERSION - from the file “DigiRead.plugin”
   Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
   ScriptingSupport 13.0, Copyright © 2013 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
   Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Skewness 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Solarize 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Solarize.plugin”
   Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Standard Deviation 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   STL 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
   Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Summation 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
   Variance 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
   Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wavefront|OBJ 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
   Wireless Bitmap 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “WBMP.plugin”
   ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins:
   BMP 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Cineon 13.0 20120207.m.379 2012/02/07:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
   Color Halftone 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   CompuServe GIF 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Crop and Straighten Photos Filter 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Crystallize 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   De-Interlace 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Dicom 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “dicom.plugin”
   Displace 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Extrude 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Fibers 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   IFF Format 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   IFF NO VERSION - from the file “AIFF.plugin”
   JPEG 2000 13.0 20120207.m.379 2012/02/07:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
   JPEG NO VERSION - from the file “JPEG.plugin”
   Legacy Gaussian Blur Gaussian Blur version 16.0.3, Copyright © 1987-2012 Adobe Systems Inc. All rights reserved. - from the file “Gaussian Blur.aip”
   Lens Flare 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Mezzotint 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   NTSC Colors 13.0 20120312.r.425 2012/03/12:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
   OpenEXR 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Paths to Illustrator 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   PCX 13.0 20120207.m.379 2012/02/07:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
   PCX 13.0 20120312.r.425 2012/03/12:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
   Pinch 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Pixar 13.0 20120207.m.379 2012/02/07:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
   Pixar 13.0 20120312.r.425 2012/03/12:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
   PNG 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Pointillize 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Polar Coordinates 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Portable Bit Map 13.0 20120207.m.379 2012/02/07:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
   Radial Blur 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Radiance 13.0 20111108.m.287 2011/11/08:21:00:00  ©2003-2010 Adobe Systems Incorporated - from the file “Radiance.plugin”
   Radiance 13.0 20120207.m.379 2012/02/07:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
   Ripple 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   SGI NO VERSION - from the file “SGI.plugin”
   Shear 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Smart Blur 13.0, Copyright © 2003-2011 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
   Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard MultiPlugin.plugin”
