35 Replies Latest reply on Aug 17, 2012 5:04 PM by StrongBeaver
    Looping for a Layer Name ?
    StrongBeaver Level 3
      I want to create a loop that checks if a layer with a set name is within a group, then save the layer group, if not, look outside any and all layer groups for a layer with a set name, if not, ignore and save the selected layer group ?
        • 1. Re: Looping for a Layer Name ?
          c.pfaffenbichler Level 8
          What is that even supposed to mean?
          • 2. Re: Looping for a Layer Name ?
            I want my script to check the composition if there is a layer with a set name, first in the group, then outside of any, and all groups, then finally if no layer with a set name is found within the selected layer group and in the composition, excluding other layer groups, just save the layer group, understand ?
            • 3. Re: Looping for a Layer Name ?
              Photoshop can save documents, but not groups.
              Do you mean »save a new document with just the layer group«?
              • 4. Re: Looping for a Layer Name ?
                Yes, I have the script completed that can do this, it is the issue with template layers that I want to get working. I'll post a part of the script code.
                • 5. Re: Looping for a Layer Name ?
                  ////// function to find layers of a name //////
                  var templateLayer;
                  var myLayerSet = app.activeDocument.activeLayer;
                  // make sure myLayerSet is a layerSet.
                  if( myLayerSet.typename == 'LayerSet' ){
                     // search the layerset for the layer name 'template'
                     for( var l = 0; l < myLayerSet.artLayers.length; l++ ) {
                        if( myLayerSet.artLayers[l].name == 'template' ){
                           templateLayer = myLayerSet.artLayers[l];
                           break;
                     // check to see if it was found
                     if( templateLayer != undefined ){
                        // it was found so do whatever
                        // call function doWhatever
                     }else{
                        // not found in expected layerset so check next level
                        for( var l = 0; l < myLayerSet.parent.artLayers.length; l++ ) {
                           if( myLayerSet.parent.artLayers[l].name == 'template' ){
                              templateLayer = myLayerSet.parent.artLayers[l];
                              break;
                     // check again to see if found
                        // found at the next level up so do whatever
                     }else{
                        // either keep searching until parent == doc
                        // then if still not found bail or just bail now
                        throw( 'Layer not found' );
                     // function doWhatever(){ return 'done';}
                  Snippt of the scripts code, I can send you the entire script to analyze.
                  • 6. Re: Looping for a Layer Name ?
                    Maybe this arrangement can help, it uses a function that can be run on a LayerSet or a Document.
                    // 2012, use it at your own risk;
                    #target photoshop
                    var myDocument = app.activeDocument;
                    var theLayerGroup = myDocument.activeLayer;
                    if (theLayerGroup.typename == "LayerSet") {
                    var theName = "name";
                    var theLayers = searchForLayers(theName, theLayerGroup, []);
                    if (theLayers.length > 0) {alert ("the layerset contains the layer/s")}
                    else {
                              var theLayers = searchForLayers(theName, myDocument, []);
                              switch (theLayers.length) {
                                        case 0:
                                        alert ("the document contains no layer of that name");
                                        break;
                                        case 1:
                                        alert ("the document contains the layer");
                                        break;
                                        default:
                                        alert ("the document contains more than one layer of that name");
                                        break;
                    ////// function collect all layers //////
                    function searchForLayers (theName, theParent, allLayers) {
                              if (!allLayers) {var allLayers = new Array}
                              else {};
                              for (var m = theParent.layers.length - 1; m >= 0;m--) {
                                        var theLayer = theParent.layers[m];
                                        if (theLayer.typename == "ArtLayer") {
                    // check name;
                                                  if (theLayer.name == theName) {allLayers.push(theLayer)}
                    // apply the function to layersets;
                                        else {
                                                  allLayers = (searchForLayers(theName, theLayer, allLayers))
                              return allLayers
                    • 7. Re: Looping for a Layer Name ?
                      Changed
                      if (theLayers.length == 1) {alert ("the layerset contains the layer")}
                      to
                      to account for cases when the set may contain more than one layer of the name.
                      • 8. Re: Looping for a Layer Name ?
                        Hi, I was going to update, I was getting an error in the script, then I came across your change in the previous post.  Except, I can't find the first part of the code to change it to the second part ?
                        • 9. Re: Looping for a Layer Name ?
                          What error specifically?
                          On which line?
                          • 10. Re: Looping for a Layer Name ?
                            To execute the error; I created three layer groups.  One layer group labelled 'Group 3' with a red square, another layer group with a green hexegon labelled 'Group 2' and finally a third layer group with a black circle, labelled 'Group 1'. I have a layer that is outside of all of these groups called 'template'.
                            Selecting the layergroup 'Group 3' that contains the red square, I ran the script, I get an error 'ReferenceError:findTemplate is not a function'. What I was expecting was the layer group would be saved with an option to save to any image format, and including the template layer that exists outside of all of the layergroups.  Lets not forgot, what if the 'template' layer is within a layergroup, and not 'outside' of all the layergroups, it must be included in that layer group and saved specifically with that layer group to a image format. I decided to post the entire script; maybe you will find fault somewhere.
                            // Custom Saving LayerGroup Productivity Tool
                            // 2012 - csMotion_Design
                            #target photoshop
                            if (app.documents.length > 0) {
                            // get document-path and -title;
                            #target photoshop
                            else {
                                                case 0:
                                                break;
                                                case 1:
                                                break;
                                                default:
                                                break;
                                      else {};
                            // check name;
                                                else {
                                      return allLayers
                            // get template;
                            var theTemplateName = "template";
                            var theResults = findTemplate(myDocument, theTemplateName);
                            switch (theResults.length) {
                            case 0:
                            alert ("no layer named »template«");
                            var myReturn = 1;
                            break;
                            case 1:
                            theTemplate = theResults[0];
                            var dlg = new Window("dialog", "put template at", [500,300,920,370]);
                            // buttons for rounded points;
                            dlg.position = dlg.add('panel', [15,10,105,60], '');
                            dlg.position.top = dlg.position.add('radiobutton', [13,0,185,25], 'top');
                            dlg.position.top.value = true;
                            dlg.position.bottom = dlg.position.add('radiobutton', [13,20,185,50], 'bottom');
                            // buttons for ok and cancel;
                            dlg.buttons = dlg.add('panel', [115,10,405,60], '');
                            dlg.buttons.buildBtn = dlg.buttons.add('button', [145,12,270,34], 'OK', {name:'ok'});
                            dlg.buttons.cancelBtn = dlg.buttons.add('button', [13,12,135,34], 'Cancel', {name:'cancel'});
                            // show the dialog;
                            dlg.center();
                            var myReturn = dlg.show ();
                            break;
                            default:
                            alert ("more than one layer named »template«")
                            break;
                            if (myReturn == 1) {
                            // psd options;
                            psdOpts = new PhotoshopSaveOptions();
                            psdOpts.embedColorProfile = true;
                            psdOpts.alphaChannels = false;
                            psdOpts.layers = true;
                            psdOpts.spotColors = true;
                            // create a history state to return to later;
                            myDocument.quickmaskMode = true;
                            myDocument.quickmaskMode = false;
                            var historyState = myDocument.activeHistoryState;
                            // do the operation;
                            for (var m = selectedLayerSets.length - 1; m >= 0; m--) {
                            var theRemove = myDocument.artLayers.add();
                            theRemove.remove();
                            // get the layername for the file-name;
                            var thisSet = selectedLayerSets[m];
                            hideOthers (thisSet, myDocument);
                            var aLayerName = thisSet.name;
                            // remove »/« and »:«;
                            while (aLayerName.indexOf("/") != -1) {
                            aLayerName = aLayerName.replace("/", "_")
                            while (aLayerName.indexOf(":") != -1) {
                            aLayerName = aLayerName.replace(":", "_")
                            // show template;
                            if (theResults.length == 1) {theTemplate.visible = true};
                            // duplicate;
                            var theCopy = myDocument.duplicate ("thecopy", false);
                            // delete hidden layers;
                            ////// delete hidden layers //////
                            function deleteHiddenLayers () {
                            try {
                            var id26 = charIDToTypeID( "Dlt " );
                            var desc6 = new ActionDescriptor();
                            var id27 = charIDToTypeID( "null" );
                            var ref6 = new ActionReference();
                            var id28 = charIDToTypeID( "Lyr " );
                            var id29 = charIDToTypeID( "Ordn" );
                            var id30 = stringIDToTypeID( "hidden" );
                            ref6.putEnumerated( id28, id29, id30 );
                            desc6.putReference( id27, ref6 );
                            executeAction( id26, desc6, DialogModes.NO );
                            } catch (e) {}
                            /// save and close;
                            theCopy.saveAs((new File(myPath+"/"+myDocName+"_"+aLayerName+".psd")),psdOpts,true);
                            theCopy.close(SaveOptions.DONOTSAVECHANGES)
                            // return in history;
                            myDocument.activeHistoryState = historyState;
                            else {alert ("no document open")};
                            ////// buffer number with zeros //////
                            function bufferNumberWithZeros (number, places) {
                            var theNumberString = String(number);
                            for (var o = 0; o < (places - String(number).length); o++) {
                            theNumberString = String("0" + theNumberString)
                            return theNumberString
                            ////// toggle visibility of others //////
                            function hideOthers (theLayer, myDocument) {
                            myDocument.activeLayer = theLayer;
                            var idShw = charIDToTypeID( "Shw " );
                                var desc10 = new ActionDescriptor();
                                var idnull = charIDToTypeID( "null" );
                                    var list4 = new ActionList();
                                        var ref7 = new ActionReference();
                                        var idLyr = charIDToTypeID( "Lyr " );
                                        var idOrdn = charIDToTypeID( "Ordn" );
                                        var idTrgt = charIDToTypeID( "Trgt" );
                                        ref7.putEnumerated( idLyr, idOrdn, idTrgt );
                                    list4.putReference( ref7 );
                                desc10.putList( idnull, list4 );
                                var idTglO = charIDToTypeID( "TglO" );
                                desc10.putBoolean( idTglO, true );
                            executeAction( idShw, desc10, DialogModes.NO );
                            ////// by paul mr //////
                            function GetSelectedLayers() {
                            var A=[];
                                var desc11 = new ActionDescriptor();
                                    var ref9 = new ActionReference();
                                    ref9.putClass( stringIDToTypeID('layerSection') );
                                desc11.putReference( charIDToTypeID('null'), ref9 );
                                    var ref10 = new ActionReference();
                                    ref10.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                                desc11.putReference( charIDToTypeID('From'), ref10 );
                                executeAction( charIDToTypeID('Mk  '), desc11, DialogModes.NO );
                            var gL = activeDocument.activeLayer.layers;
                            for(var i=0;i<gL.length;i++){
                            A.push(gL[i]);
                            executeAction( charIDToTypeID('undo'), undefined, DialogModes.NO );
                            return A;
                            function findTemplate (theParent, theTemplateName) {
                            else {};
                                 if (theLayer.name == theTemplateName) {
                            else {
                                 allLayers = allLayers.concat(findTemplate(theLayer, theTemplateName))
                            return allLayers
                            • 11. Re: Looping for a Layer Name ?
                              I have no intention of trouble-shooting your lengthy script.
                              With the Script I provided earlier a case like you described (template layer at top level) results in the alert »the document contains the layer«, so I see no issue there.
                              »ReferenceError:findTemplate is not a function« sounds like there might be an issue with the function findTemplate (though I can’t reproduce the issue) – why you use that function at all I don’t know.
                              • 12. Re: Looping for a Layer Name ?
                                I mentioned that I was going to be posting a part of my script related to the problem, I never said I needed a entire new script to solve the issue I need find an fix what the problem is with my script with regards to the layer groups not saving the template layers. You posted a entirly new script, I thought I could take the script you posted and blend it with my complete script to solve the problem, argggh.
                                • 13. Re: Looping for a Layer Name ?
                                  The Script I posted was supposed to serve as an example of how the task can be achieved.
                                  If it is helpful then amending your larger Script is up to you.
                                  • 14. Re: Looping for a Layer Name ?
                                    Can you verify something for me, the script you posted, did the task I was after ? I just copied and pasted it within my code.  I would greatly appreciate if, even though you are busy, if you could aid in solving this.  The script as it stands is perfect, it is only the template issue that is plaqing me.
                                    • 15. Re: Looping for a Layer Name ?
                                      The script solves the problem, that I was encountering.  It's up to me to take it, or change it and add it to my complete script ? There is no newbie forum to help with situations as this, what part of the script needs to be removed to add a change etc.  Everyone knows programming is not easy, remembering a programs syntax is a step in the right direction, but making something work not so much.
                                      • 16. Re: Looping for a Layer Name ?
                                        The snippet I provided provides alerts for the various situations, that is where you could insert the corresponding procedures you want to trigger.
                                        And the array theLayers lists the respectively corresponding template-Layer/s, so that can be used to address them or their parents.
                                        • 17. Re: Looping for a Layer Name ?
                                          Hopefully I figure out how to take your code snippet and add it to my script.
                                          • 18. Re: Looping for a Layer Name ?
                                            c.pfaffenbichler.  I'll pay you if you can explain to me where I went wrong in inserting your code snippet into my script ? I haven't come to grips with scripting, as in how to make it come together logically.
                                            • 19. Re: Looping for a Layer Name ?
                                              I’m busy currently but I will try to give a more thorough explanation later.
                                              • 21. Re: Looping for a Layer Name ?
                                                In the code I posted the alerts mark the various places you could use as jumping off points for the different operations you want to perform depending on the situation (template-layer in the layerSet or not etc.).
                                                If you wrap your operation(s) in function(s) you can insert those instead of the alerts.
                                                If the function takes the template layer and the selected layerSet as arguments you can feed them into the functions there.
                                                • 22. Re: Looping for a Layer Name ?
                                                  I'm not quite understanding, do I take your script and incorporate it into mine ? As I mentioned my script works as it currently stands, the problem is it doesn't take into account any layer within the layergroup or outside of the layergroup named 'template', remember I'm a newbie at scripting with Ps, if you don't mind ?
                                                  • 23. Re: Looping for a Layer Name ?
                                                    This would be an example of how to use a function to jump off from the various points – don’t consider this as a final Script but as an illustration of one possible way.
                                                    I frankly did not see what the dialog was for as the input did not seem to be used later on so I dropped it.
                                                    #target photoshop
                                                    #target photoshop
                                                    var theName = "template";
                                                              doStuff (myDocument, theLayerGroup, undefined);
                                                    else {
        case 0:
        break;
        case 1:
        doStuff (myDocument, theLayerGroup, theLayers[0]);
        break;
        default:
        break;
                                                              else {};
                                                    // check name;
        else {
                                                              return allLayers
                                                    var A=[];
                                                    A.push(gL[i]);
                                                    return A;
                                                    else {};
                                                    else {
                                                    return allLayers
                                                    ////// the operation //////
                                                    function doStuff (myDocument, thisSet, theTemplate) {
                                                    var myPath = myDocument.path;
                                                    var myDocName = myDocument.name;
                                                    // psd options;
                                                    // hide other layers;
                                                    while (aLayerName.indexOf("/") != -1) {aLayerName = aLayerName.replace("/", "_")};
                                                    while (aLayerName.indexOf(":") != -1) {aLayerName = aLayerName.replace(":", "_")};
                                                    // show template;
                                                    try {
                                                              theTemplate.move(myDocument, ElementPlacement.PLACEATBEGINNING);
                                                              theTemplate.visible = true;
                                                    catch (e) {};
                                                    // duplicate;
                                                    deleteHiddenLayers ();
                                                    /// save and close;
                                                    theCopy.saveAs((new File(myPath+"/"+myDocName+"_"+aLayerName+".psd")), psdOpts, false);
                                                    • 24. Re: Looping for a Layer Name ?
                                                      When I export a layergroup which the template layer resides outside of any and all layergroups, the script does what it should be doing, except when I load the layergroup that was exported from the script, the template layer is above the exported layergroup of the composition instead of within it, at the very bottom of all other layers, that is the only final bug.
                                                      • 25. Re: Looping for a Layer Name ?
                                                        Currently the function uses a try-clause to move a template outside of the selected LayerSet to the top of the file and make it visible.
                                                        You can change the line
                                                        to instead move it to the end of the LayerSet instead.
                                                        And if you want to treat template Layers differently according to whether they are top level or inside another LayerSet you could add an if-clause that checks for the template Layer’s parent.
                                                        if (theTemplate.parent == myDocument) {/*do one thing*/}
                                                        else {/*do another*/}
                                                        • 26. Re: Looping for a Layer Name ?
                                                          What do I change;
                                                          theTemplate.move(myDocument,ElementPlacement.PLACEATBEGINNING) to ? I can't find the function to change in the scripting guide ?
                                                          • 27. Re: Looping for a Layer Name ?
                                                            You should be able to figure it out.
                                                            »Photoshop JavaScript Ref.pdf« lists the ElementPlacement values.
                                                            • 28. Re: Looping for a Layer Name ?
                                                              if (theTemplate.parent == myDocument) {/*do one thing*/} else {/*do another*/}
                                                              Correct me if I'm wrong, if the template layer is outside of the layer group I can have it "pulled" into the layerGroup upon exporting the specific layerGroup or not, with a dialog ?
                                                              • 29. Re: Looping for a Layer Name ?
        Yes, a confirm-dialog should suffice for the task.
        • 30. Re: Looping for a Layer Name ?
        How do I do this, just as long as as it always remains at the end of the layergroup or at the end of all the layers in the composition.
        • 31. Re: Looping for a Layer Name ?
        So what good is a dialog?
        • 32. Re: Looping for a Layer Name ?
        I understand, well if I can have that option with a dialog, then why not.  I'd want to see it in practice, although I probably wouldn't be disappointed.
        • 33. Re: Looping for a Layer Name ?
        If you always want the template in back then just move it into the back – why complicate the operation?
        • 34. Re: Looping for a Layer Name ?
        Having a Dialog would be helpful upon exporting the layergroup.
        • 35. Re: Looping for a Layer Name ?
        I want to streamline the export process, by having dialog ask me to keep the 'template' in the layergroup or outside and regardless of which option choosen it always places the 'template' layer at the buttom of either the layergroup outside of the exported layergroup,  I hope someone can help ?
