Simple text field
Nov 13, 2006 Nov 13, 2006
I want to call a javascript if User clicks on a button and the text field is empty.
here is the button and the text field:
<cfinput type="file" name="custCartFile">
<cfinput type="submit" name="submit" value="Add Image">
Trint
Advanced techniques
742
Participant , Nov 14, 2006 Nov 14, 2006
The easiest way is to return the javascript function from the onSubmit event of your form. onSubmit = "return your_function()". That way, when your user clicks your submit button, your script can check whatever you want to check *before* the form is actually submitted.
Like this:
<script type="text/javascript" language="javascript">
function check_file_field()
var file_field = document.getElementById("flFileField");
if(file_field.value.length == 0)
alert("Select a file first!");
ret...
required="yes" is easier
I tried that and got "error in submit text"
Can you give me the exact context?
Guest
You don't have a text field. You have a type="file" and a type="submit".
My mistake. You have to check it on your action page.
form page
<form action="actionpage.cfm" enctype="multipart/form-data" method="post">
<input type="file" name="inputFile" size="45">
action page
<cfif len(InputFile) is 0>
no file, write code to handle it
</cfif>
How do I present the "custCartFile" and "custCartThumb" which are the input file entry boxes?
Ok, do I put it like this?
<cfif len(custCartFile) is 0>
noImage(); <<<this is a java function. displays message to add imagefile
</cfif>
<cfif len(custCartThumb) is 0>
noThumbnail(); <<<this is a java function. displays message to add thumbfile
</cfif>
All I want is for a message box to pop up and remind if no imagefile or thumbnailfile were selected.
Trint
Advocate ,
Coldfusion runs on the server. Javascript runs on the browser. If you want a popup warning _before_ they submit it, it needs to be written in javascript (both the testing and the popup). If you want them to submit it, then get back a popup, you can do the testing in coldfusion and write the popup in javascript.
Ok, but I'm new to Coldfusion and don't know the syntax for doing the cfif correctly. I get an error message "custCartFile" not defined when I do this:
</cfif
How can I use that test correctly (syntax) so that I don't get an error message?
Trint
Advocate ,
Until the form is submitted, custCartFile isn't defined.
Also, noImage() is a Javascript function, not a java function.
So, you can do:
<cfif isDefined("FORM.custCartFile") and len(custCartFile) is 0>
Participant ,
Like this:
return false;
else
return true;
</script>
<cfform action="#cgi.script_name#" method="post" name="frmTest" preloader="no" onsubmit="return check_file_field()">
<cfinput type="file" id="flFileField" name="flFileField">
<cfinput type="submit" name="btnSubmit" value="Go">
</cfform>
Nov 15, 2006 Nov 15, 2006
MrBonk,
Since this <cfinput type="file" is already within a <cfform action, I used "onClick="return check_file_field()" at the end of this:
<cfinput type="submit" name="submit" value="Add Image" onClick="return check_file_field()">
and gives me the message "Select a file first!" whether I select a file or not!
Please help.
Trint
Advocate ,
Did you happen to change the name of the file field that is being checked in the check_file_field() function?
Yes, it looks like this now:
var file_field = document.getElementById("custCartFile");
alert("You are required to select an Image");
return false;
else
return true;
Trint
Advocate ,
You need to give the custCartFile input field an id of custCartFile in order for that javascript code to work.
<cfinput type="file" name="custCartFile" id="custCartFile">
it's the id value that the javascript function "document.getElementById()" is checking for.
Documentation
