"Show" appears multiple times in FlashHelp. Each "Show" opens the correct TOC, but we only need one of them. Is there a way I can remove the extras?
Hi there
From what you have described, it would seem that you may have managed to overwrite your source files with output files. Are you seeing red squares in the editor? If so, that's one sign.
Can you insert some screen shots for us to see? Shots of both the output as well as the source?
Cheers... Rick
Hi Rick,
I have taken over this project from a previous tech writer and I did
remove the red squares from several of the pages. So it's probable that
the source files were overwritten. I updated the files then compiled the
files to a new folder, When I view after compiling, the help displays with
just one "Show". When the developer puts in into the program, that's when
the multiple "Show" links appear.
Thanks loads!
Mary Jo Pilch
Technical Writer
New Development Center
972- 766-3421
Hi Rick,
Any thoughts on the multiple "Show" TOC links appearing when the developer hooks up the program? Is this a RoboHelp issue or a programming issue?
Mary Jo
Hi there,
Is this happened after you generate the Flashhelp??
Or if you're Dev team integrate it with your Application?
Any screenshot would be help ful with Multiple "Show".
Regards
Priyank
It happens when the Dev team integrates it with the application. It looks
OK after it has been compiled and viewed. I already sent a screen shot.
Hi there
Sorry, but there are noscreen shots in this thread. If you replied via email and attached them, things don't work that way as the forum doesn't allow attachments. You must use the Camera icon while replying via the browser if you have screen shots to show us.
Cheers... Rick
