An internal error occurred during: "Removing compiler problem markers...".
java.lang.NullPointerException
FB 4.5. I know the old FB has a file .markers you could delete, but where does 4.5 keep these?
Sometimes the markers will disappear with "clean", but not always.
Richard
I created a new workspace, imported all my projects, and the problem removing errors has disappeared, for now.
Do you sometimes see two copies of all your errors? If so, I think you might have a project that's created in a different location than your source code http://flexdiary.blogspot.com/2012/07/when-good-flash-builderflash-pro.html
No doubled errors. And my source code (src) is below the project folder. The errors are "orphans"- that is, they were valid errors once, but after correcting and rebuilding, they do not go away. Sometimes a "clean" will remove some of the them.
