How do I pass a string variable from a movieclip timeline to a url request inside of a class?
Jul 17, 2012 Jul 17, 2012
Hello,
I've coded an audio player class I'd like to be able to reuse throughout my project to play a different sound in each movieclip. The audio player works great and the sound loads when I request the url from within the class but I'm having trouble requesting the url coded on the parent movieclip's timeline.
I have an instance of a movieclip named musicPlayer in 4 different parent movieclips that is linked to a class named MusicPlayer which contains my audio player code.
To test, in one of the parent movieclips, I've placed the following code to set the url path to a string variable:
var mp3url = "tuba.mp3";
Then, in my class I've declared the same variable as a string:
public var mp3url:String;
and tried passing it to my url request:
mp3File.load(new URLRequest(mp3url));
I'm then receiving an error: "1151: A conflict exists with definition mp3url in namespace internal."
As mentioned above, the sound is loaded perfectly when I set the url path to a string variable within my class like so:
public var mp3url:String = "tuba.mp3";
Thank you in advance!
ActionScript
1.4K
Community Expert , Jul 17, 2012 Jul 17, 2012
use a function to pass that variable or you'll have a timing issue:
in your class:
private function urlF(urlS:String):void{
// declare mp3url in your class
mp3url=urlS;
// you can now use mp3url
// on your timeline:
varF("tuba.mp3");
in your class:
mp3url=urlS;
varF("tuba.mp3");
Jul 18, 2012 Jul 18, 2012
I changed "varF" to "urlF" on the timeline to match the function. It works perfectly! Thanks!
you're welcome.
Oct 01, 2012 Oct 01, 2012
Hello,
I'm having some trouble with passing a variable from a movieclip timeline to a child movieclip's class.
I've created 7 movieclips on the main timeline and within each of these moviecilps I've create a movieclip named "moreInfo" with the class MoreInfo.as assigned to it. This class simply opens a web url when the movieclip is clicked. I'm trying to reuse this movieclip in each of the 7 parent movieclips by setting the url on the parent movieclip timeline and passing it to the instance of moreInfo. I've followed the thread above and I'm receiving the following error when the instance of moreInfo shows up:
"TypeError: Error #1034: Type Coercion failed: cannot convert "http://wvsokids.org/the-music/elements-of-music/melody.html" to com.musicalbuildingblocks.MoreInfo.
    at MusicalBuildingBlocks_fla::form_mc_21/frame10()
    at flash.display::MovieClip/gotoAndStop()
    at com::NextPage/nextSection()"
I've placed the following on the parent movieclip's timeline:
MoreInfo("http://wvsokids.org/the-music/elements-of-music/melody.html");
MoreInfo.as
package com.musicalbuildingblocks
    import flash.display.MovieClip;
    import flash.events.MouseEvent;
    import flash.net.navigateToURL;
    import flash.net.URLRequest;
    public class MoreInfo extends MovieClip
        public var myURL:String;
        public function MoreInfo(urlS:String):void
            myURL = urlS;
            this.buttonMode = true;
            addEventListener(MouseEvent.CLICK, onClick);
        private function onClick(e:MouseEvent):void
            navigateToURL(new URLRequest(myURL), "_blank");
            trace(myURL);
use:
var mInfo:MoreInfo=new MoreInfo("http://wvsokids.org/the-music/elements-of-music/melody.html");
Thank you for responding. What exacty does "MoreInfo=new MoreInfo" do?
I used the above code and I'm now receiving this error:
ArgumentError: Error #1063: Argument count mismatch on com.musicalbuildingblocks::MoreInfo(). Expected 1, got 0.
    at flash.display::Sprite/constructChildren()
    at flash.display::Sprite()
    at flash.display::MovieClip()
    at MusicalBuildingBlocks_fla::form_mc_21()
    at com.musicalbuildingblocks::MusicalBuildingBlocks/clickHandler()
it creates a MoreInfo instance which is how your MoreInfo class is designed to be used.
the line of code i suggested would not trigger that error if used with the MoreInfo class you showed.
