Possible:Booleans in Arrays?
Jul 18, 2012 Jul 18, 2012
I would like to use an array to A)define the Boolean state of a group of variables and B) check those variables. I have tried a bunch of different methods of doing this but get a bunch of different errors. Is this actually something that's possible? What would sample code look like?
ActionScript
1.0K
Advocate ,
definately possible, several different ways of doing no different to anything else really
post code and errors for specific help
var i:int = -1
var boolArray:Array = [true, false, 3>2, true, false, false, i == -2, true];
trace("4th bool: " + boolArray[3])
if (boolArray[2])
          trace("3rd bool is true");
else
          trace("3rd bool is false");
Let's say I have this array:
var buttons:Array=[button1, button2,button3]
Instead of doing this for each index:
var button1:Boolean=false
I would like to do something like this:
buttons:Boolean=false
Then I would like to be able to do something like this for conditional:
if (buttons=true){trace ("true")}
Advocate ,
then you can just use buttons = false;
and
if (buttons == true) {trace("true")}
(note using single = is an assigment not an equality)
here is another demo that might help
package
          import flash.display.Sprite;
          public class Main extends Sprite
                    private var buttons:Array;
                    public function Main()
                              buttons = new Array();
                              setUpButtons(6);
                              testButtons();
                    private function testButtons():void
                              for (var i:int = 0; i < buttons.length; i++)
                                        if (buttons)
                                                  trace("button " + i + " is true");
                                        else
                                                  trace("button " + i + " is false");
                    private function setUpButtons(len:int):void
                              for (var i:int = 0; i < len; i++)
                                        buttons = false;
Ok, I've been playing around with this and it looks like you have to define the contents of the array as a variable first, then define the contents as a variable.
Advocate ,
Jul 19, 2012 Jul 19, 2012
that will work but is not the case if you want to paste your code here I can get it to work without the variables first
Thanks. This is the code:
var button1, button2,button3;
var buttons:Array=[button1, button2,button3];
for (var i:uint=0;i<buttons.length; i++)
buttons=false;
for (var j:uint=0;j<buttons.length; j++)
if (buttons!=true){trace()}
