Merge two query results
Guest
Nov 14, 2006 Nov 14, 2006
Is it possible to merge 2 query results?
I have a function that returns a querey result.
< CFSET temp = query1>
<CFSET FNCTransfers = temp>
Now I want to change the query to return a merged query result
<CFSET temp2 = query2>
Is it possible to merge the two results?
Some thing like this (I know that it cannot be done like this)
<CFSET FNCTransfers = temp1 & temp2>
Maby it should be a union and query of query?
Advanced techniques
670
LEGEND , Nov 14, 2006 Nov 14, 2006
UNION could be the way to go. the query results will have to match up
between the 2 queries (field data types need to match for both queries)
<cfquery name="qryMergedQueries" dbtype="query">
SELECT * FROM query1
UNION
SELECT * FROM query2
</cfquery>
You will most likely find trying to use Query of Query very problematic. I reccommend that you actually write a SQL statement to do the union at the DB end.
I know that it seems a bit crappy, but i think it will help you maintain your sanity.
The best way to achieve your goal depends on what it is. Your question is very general.
UNION
</cfquery>
Guest
I had two different queryes getting internal transgers in a company and external transfers in/out of a company and then I would show a merged list of this two results.
The two queryes vere very complex and therfore I would not merge the two queryes into one query.
The query of query aproach worked very well.
Sep 27, 2021 Sep 27, 2021
Merging pag.ibig contribution
Documentation
