Hello. I've got a fleet of Windows 7 PCs running Reader X. I deploy software updates via Config Manager, and import the Adobe updates via SCUP. All my Windows 7 PCs are currently running version 10.1.1, however none of them are picking up Reader 10.1.3. The update just isn't being flagged as required... any ideas?
By the way, I did look at update path and nothing jumped out at me from there
Did you get 10.1.2 along the way?
Ben
Hello Ben, thanks for the reply.
I did have 10.1.2 offered, however the PCs did not respond to this either. Is 10.1.2 a requried upgrade step, as in do I need to have offered:
10.0.0 (base install)
...to:
10.1.1
...to:
10.1.2
...to:
10.1.3
No, it's not required, but neither is 10.1.3. Please post all the relevant info:
Ben
Hello again, sorry the tardy reply.
SCCM reqs - yes. Pretty standard setup. Flash updates roll out without any issues.
No errors - nothing happens.
Exact steps:
Receive SCUP alert
Import Adobe updates
Publish Updates
Synch SCCM Software Updates
Deploy Adobe updates (as I siad, Flash updates are fine, so I don't see this as a SCUP problem).
That said, I deleted the Adobe updates from Config Manager, and then redeployed them as part of the standard monthly release. This time I received around 2100 installs and 3200 not required (this is about right for Adobe X), whereas before I was getting double figures for installs and mostly Not Required.
Perhaps I had received a bad update, or maybe something went wrong with the SCUP to SCCM import/packaging.
Anyway, all sorted... thank you for the response.
Hi RashC,
I think I have a similar problem: SCCM 2007R3 and SCUP 2011 plus Windows 7 clients.
Flash and Windows updates roll out without any problems, but Adobe Reader X and Acrobat X updates is marked as "not required".
The Win7 clients have Reader X 10.1.2 installed from the OSD task sequence, but it doesnt get updated to neither 10.1.3 nor 10.1.4.
I have imorted the updates from Adobe in SCUP, published Reader X 10.1.[3-4] updates with full content, run Sync in SCCM, deployed Reader update - just as I do with Flash.
Therefore I am curios about what you mean by "deleted the Adobe updates from Config Manager" and then got it to work - what exactly did you do?
Thanks a lot in advance.
