Show 2 replies
1. Re: Need to change one part of disc.
Stan Jones Jul 18, 2012 3:34 PM (in response to literally_figurative)My experience, and various complaints here, is that you are asking for problems to try modifying a timeline in Encore.
I assume you brought a transcoded asset into Encore originally. I would use the "replace asset" option. Make sure that the "new" version is a different name than the none you used before. "Should" work fine.
If you used dynamic link, "revert to original" make your changes, and transcode from there.
2. Re: Need to change one part of disc.
literally_figurative Jul 18, 2012 3:37 PM (in response to Stan Jones)The problem is as it stands, the timeline is one video track and my change would make it 2. If it seems to be asking for trouble it seems I will be transcoding the entire thing then!
Sent from my BlackBerry® device from Digicel
