1 2 Previous Next 48 Replies Latest reply on Jul 31, 2012 12:02 PM by Noel Carboni
    External solid state drive for scratch disk?
    carolgunn
      After doing everything i can find to optimize my hardware/software for doing 3D animation in Ps Ext CS6. I still cannot render an animation to video using the Ray Traced Final setting. (Ray Traced Draft, no problem.) The last time I tried (after repairing disk permissions), at least Ps did not crash and give me the same old crash report (Exception Type:  EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x00000007a0020000). This time I just got an error msg that my request could not be completed. (Progress?) Checking Activity Monitor, I could see that my available RAM, which was 13 GB when I started the render was now less than 1 GB (761 MB).
      So, I have come to the conclusion that my 16 GB of RAM and 300 GB available for virtual memory on my HD is not enough for rendering the type of 3D animation I am trying to do. Would you agree? Also, I have read it is not good to use the same HD your program is installed on for a scratch disk, so I am considering getting an external solid state drive to use as a scratch disk.
      Whaddaya think? Does this sound like a good solution for me?
      --Carol Gunn
      Gunn Graphics
        • 1. Re: External solid state drive for scratch disk?
          Brett N Adobe Employee
          In theory, it should help. Just make sure you have a good fast connection between the drive and the computer. USB3 should be good.
          • 2. Re: External solid state drive for scratch disk?
            the_wine_snob Level 9
            Welcome to the forum.
            You might get a lot of great info from this ARTICLE. While it was written with Adobe Premiere Pro in mind, much of what you wish to do, is parallel to the Video work that both PrPro and After Effects do.
            Also, I would post to the Adobe Premiere Hardware Forum with specific questions, as there are a dozen real hardware gurus there, who spec. and build systems for some high-end video and animation houses. They can give you some very useful answers.
            Good luck,
            Hunt
            • 3. Re: External solid state drive for scratch disk?
              Curt Y Level 7
              Did a little research and this seem to spell out the connection speed quite well.
              "Bottom line seems to be that a good SATA II (3.0 Gb/s) HDD will often achieve a 70 to 100 MB/s long-term average transfer rate.  I don't know for sure what older IDE drives can do, but I know it is less. For an external HDD connected by USB2 (a slower interface than SATA), the rate is more like 30 to 35 MB/s (USB3 is faster, close to SATA II rates). Firewire 400 is a little slower than SATA II, and Firewire 800 (uncommon on PC's but on many Mac's) may be faster than SATA II. IF your external HDD is a SATA II and connected by a good eSATA port to your machine, it probably will exhibit a speed close to an internal SATA II drive."
              What I get from this is the speed is increasing as you go from USB -USB2 - SATA - Firewire 400 - USB3 - SATA II - Firewire 800.
              • 4. Re: External solid state drive for scratch disk?
                Noel Carboni Level 8
                I need to ask...  Why external?  Is it a laptop?
                What's your budget?
                -Noel
                • 5. Re: External solid state drive for scratch disk?
                  pf22 Level 2
                  USB3 is faster than Firewire 800, but Thunderbolt, well established now in the Mac world, with the exception of the Mac Pro tower, and being adopted, agonizingly slowly, in the Windows world, is fastest of all, as well as allowing the daisy-chaining of devices, as Firewire does.
                  • 6. Re: External solid state drive for scratch disk?
                    Lundberg02 Level 3
                    Don't be so sure about Thunderbolt. The disk  and/or adapter has to be ready for it or you won't get anything better than SATA II and maybe not that. My eSATAs aren't much faster than FW800 yhrough my Tbolt adapter.
                    • 7. Re: External solid state drive for scratch disk?
                      pf22 Level 2
                      You're right Lundberg, I should have made the point that to gain the full performance of the Thunderbolt port, you need to be using Thunderbolt enabled accessories; drives, monitors etc.
                      About the only manufacturer out there at the moment offering a broad range of Thunderbolt desktop drives is LaCie.
                      • 8. Re: External solid state drive for scratch disk?
                        Lundberg02 Level 3
                        You can't get much out of LaCie tech support about actual speeds. They either don't know, don't test, or won't confirm.
                        • 9. Re: External solid state drive for scratch disk?
                          pf22 Level 2
                          This is published on their site, and for what it's worth I saw a demonstration where the rep transferred a 16GB movie file from a Thunderbolt drive to a MacBook Pro in under 1 minute!
                          Regardless of what numbers/specs are published, that's pretty impressive real-world performance in my book!
                          • 10. Re: External solid state drive for scratch disk?
                            Trevor.Dennis Adobe Community Professional (Moderator)
                            I have four USB3 external drives, and love them. They are almost as fast as a 7k2 rpm SATA drive, and have their own PSU. The only problem I've had was that when I started using them, my main board did not support USB3, so I had to use a PCI card. This was fine until I got the second drive, which the card did not recognise.  I forgot how I got past the problem now though.
                            My current MB still only has two USB3 slots on the rear panel, plus a third on the front of the case, which is pretty short sighted IMO (it was only obtained at the beginning of this year).  So I still have to use the PCI card.
                            • 11. Re: External solid state drive for scratch disk?
                              I'm not a Mac user, but my experience may be helpful / interesting...
                              I wanted to mention that I have recently been through an exercise on my PC workstation where I built a RAID 0 array out of four 480 GB SSD drives, controlled by a PCIe (x8) RAID controller.  This nearly 2 TB volume is now my system drive and virtually everything is pointed there (including Photoshop scratch).
                              This volume has 1.7 gigabytes/second sustained throughput capacity with sequential reads/writes, though based on Resource Monitor, I haven't seen Photoshop actually read/write much more than 300 or 400 megabytes/second, but it's possible it does so and Resource Monitor's sample window of 1 second just doesn't show it accurately.  Whatever's going on, no waiting.  Photomerges that used to take 3 minutes now take 11 seconds.  I literally cannot tell when Photoshop "goes virtual" and accesses its scratch files and/or does auto-saves. It just stays responsive.
                              I do have 5 TB of other storage on (spinning) HDDs in the system, but I don't regularly access it in minute to minute operations and those drives usually stay spun down by Windows' power-saving features.
                              I learned all I could, made parts choices, then jumped in with both feet.  Actually doing the job and subsequently using and managing the setup (quite successfully) afterward taught me more.  As with anything new, there's a learning curve, and I can see that I was smart in some ways and lucky in others.
                              Things I've learned:
                              • A modern SSD with SATA3 connection can saturate the link with sustained throughput of 550 megabytes/second or more (and zero seek time).  This stresses the SATA3 controllers and cables, so good hardware's a must.
                              • RAID 0 essentially adds up space and speed.  In my case my 4 drive array maxes out performance because my PCIe buss / processors / RAM simply can't handle the data any faster.
                              • The only downside I see to using RAID 0 is some additional risk of failure (i.e,. if you have 4 drives, the risk is 4 times as high).  I do nightly backups to an external USB drive, but so far in 3 months I have had no hiccups whatsoever.  It's been rock solid.
                              • Modern SSDs with SandForce internal controllers can take heavy write loads over time without worry about "wearing out" the drives, because they do "wear leveling".  This was a real consideration up to a year or two ago and early adopters had to take special measures to relocate volatile data elsewhere.  No more - the idea of using them for scratch and data as well as OS files is now quite valid.
                              • SSDs work best if you overprovision (i.e., when the dust settles and everything's installed/running, you should have a lot of free space, which is not a bad idea in general anyway).  I have 1 TB of free space.  Of course, this is still more expensive than spinning HDDs, but you get what you pay for in performance.
                              • SSDs work best if you leave the system power on when you're not using them.  This gives them time to do internal maintenance, such as erasing flash blocks no longer in use, preparing them for next use.
                              • Since SSDs are very sophisticated in their internal storage management, and stress the communications links to the max, there can be incompatibilities you might not expect, and weird things can happen.  I learned that the particular brand I bought (OCZ Vertex 3) get along nicely with the particular brand of RAID controller I bought (HighPoint 2720SGL).  Fortunately no weird things have happened to me, but the forums do reveal people reporting lockups and crashes.
                              • Having everything (system files, temp, scratch, data areas, photo library, etc.) all on the SSD array means that everything you do is as fast as possible.  System responsiveness becomes unbelievably fluid and smooth.  No lines, no waiting!  It's like getting a computer 2 generations newer.
                              • Though I'd never really thought of it as a problem, the elimination of the small seeking sounds of electromechanical hard drives is very nice.
                              • The SSD drives are small (laptop sized) and use almost no power (1.something watts), so they don't get hot and can be stuffed in a small space inside your computer.  In my case I have 4 drives in the space of an optical drive bay.
                              I have a feeling an arrangement like this can apply to a Mac system as well, though I'm not privy to the specifics.  I'm sure someone else out there has done it and documented it online somewhere.
                              -Noel
                              • 12. Re: External solid state drive for scratch disk?
                                carolgunn Level 1
                                Thanks, Brett. The sales guy at OWC told me the cable can be a bottleneck, but I have Firewire 800, so I think that whould work well enough for me.
                                • 13. Re: External solid state drive for scratch disk?
                                  carolgunn Level 1
                                  Noel, It has to be external because a second internal hard drive can't be aded to my mid-2010 iMac 27". Budget? aarrgghh!! I am looking at OWC's Mercury external SSDs and quibbling between the $120 GB for $200 and the 240 GB for $300. I am just a small (one-person) company, but I do want to get into 3D anuimation and video editing, so I guess I am just gonna have to put on my big girl panties and shell out some (more) cash! Why do you ask--did you have any recommendations?
                                  • 14. Re: External solid state drive for scratch disk?
                                    carolgunn Level 1
                                    Thanks, Bill. I do plan to move over to Premiere and After Efffects when/if i ever get these animations to render!  I will check out that forum.
                                    • 15. Re: External solid state drive for scratch disk?
                                      carolgunn Level 1
                                      Curt, thanks for that info. I do have Firewire 800, so that is good to know. Small diferences in speed should not make too much diference as this would be the kind of thing i would set to run overnight.
                                      • 16. Re: External solid state drive for scratch disk?
                                        Lundberg02 Level 3
                                        External SSD through FW800?  No no no. No benefit. Way too slow for your 3D.
                                        • 17. Re: External solid state drive for scratch disk?
                                          I am not doing much creation of 3D (usually hire that done by a 3D animation artist), but for SD Video, I edit to/from FW-800 externals, and the speed has been more than satisfactory. I could not work from USB 2.0, or FW-400, but the FW-800's (even without the ideal scheme for performance) had worked well. Using eSATA is even better, and all of my newer externals offer that. For HD Video, I use a RAID array, and those are eSATA, and work well.
                                          I have not used USB 3.0's, but about 6 mos. ago, the real-world benchmarks that I saw, were not that impressive.
                                          Good luck,
                                          Hunt
                                          • 18. Re: External solid state drive for scratch disk?
                                            Lundberg02 Level 3
                                            If you want to spend huge amounts of money, do what Noel did.
                                            SSDs are fast if your task has a lot of read/writes, but data throughput depends on the drive bus in your computer and the drive bus in your ext drive. If they are both SATA II you will get a bit less than half the speed through an eSATA connection. I don't know if there are any SATA III SSDs or whether they have eSATA connections or Tbolt or USB 3, but don't expect magic.
                                            • 19. Re: External solid state drive for scratch disk?
                                              For what I do, I have not felt the need for SSD's. I have three RAID arrays with WD Caviar Blacks, as well as 5 other non-RAID disks in my workstation. The current generation of SSD's have come down in price, and have gone up in capacity, but the write functions and life-span are still in question. If I were to use one, it would only be for the boot disk. Next generation? I will have to see how those benchmark.
                                              Hunt
                                              • 20. Re: External solid state drive for scratch disk?
                                                carolgunn Level 1
                                                Lundberg02, I am not expecting magic--I don't care if the render takes all night, I just don't want Ps to crash every time i try to render with the Ray Traced Final setting. (Ray Traced Draft--no prob.) From an Adobe Help file on optimizing performance in Ps CS6: "To gain the greatest benefit from an SSD, use it as the scratch disk. Using it as a scratch disk gives you significant performance improvements if you have images that don’t fit entirely in RAM. For example, swapping tiles between RAM and an SSD is much faster than swapping between RAM and a hard disk." That is what I think is crashing Ps every time--my image, as they say, just doensnt fit inot the 13 GB of available RAM and 330 GB on my internal HD that is available for scratch disk. As this (rendering 3D animations and video) would be the kind of thing i would do infrequently and could set to run overnight, speed is not really the issue. Or is it? Do you mean that the slowness of reading/writing to the internal HD could be causing the crashes?
                                                • 21. Re: External solid state drive for scratch disk?
                                                  carolgunn Level 1
                                                  Bill, (I wish these replies would show up under what I am replying to--or am I just doing this wrong?) What do you do? I don't know if you can see my reply to Lundberg02, so i will copy and paste (with a litle added) here: "Installing Photoshop on a solid-state disk (SSD) allows Photoshop to launch fast, probably in less than a second. But that speedier startup is the only time savings you experience. That’s the only time when much data is read from the SSD. To gain the greatest benefit from an SSD, use it as the scratch disk. Using it as a scratch disk gives you significant performance improvements if you have images that don’t fit entirely in RAM. For example, swapping tiles between RAM and an SSD is much faster than swapping between RAM and a hard disk." And i think that is what is happening to me--when rendering, my images don't fit in the available RAM + HD scratch space. I suppose I could jsut get a big ol' regular old hard drive rather than a SSD drive to use for extra scratch space?
                                                  • 22. Re: External solid state drive for scratch disk?
                                                    carolgunn Level 1
                                                    I just tried an experiment to get some more data in trying to determine if my crashes are indeed being caused by the fact that my images don't fit into the 13 GB of available RAM + 330 GB available on my HD for scratch space. So I set my external backup drive to be the primary scratch disk (500 GB available) and my internal HD (330 GB available) as the secondary for a total of 830 GB of available scratch disk space. It rendered for about an hour, then crashed, giving me less than 1 second of video (the animation is 6 seconds long.) You can see it here: http://youtu.be/lm1bMY37pAQ
                                                    The full version, which rendered just fine at the Ray Traced Draft setting, is here: http://www.youtube.com/watch?v=zY9e0At1ki8&feature=plcp
                                                    So I don't think this bodes well for me getting a 120 GB SSD to use for scratch, since I had the same crash with an additional 500 GB of scratch. OR--would the SSD work better as a scratch disk since it is faster?
                                                    Message was edited by: carolgunn. Forgot to mention, the external drive I was using is USB 2.0. And I am on a 27" iMac, running OSX.7.4.
                                                    Message was edited by: carolgunn. When it crashes the program (ps CS6) I get a crash report that says: "Exception Type:  EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000" (altho, never before was that number all zeros). If anyone can shed any light on that, please do so!
                                                    • 23. Re: External solid state drive for scratch disk?
                                                      Level 7
                                                      We'd need to see the full crash report to know what might be happening.
                                                      • 24. Re: External solid state drive for scratch disk?
                                                        carolgunn Level 1
                                                        Chris, here is the most recent one from right after I added the additional scratch drive. Thanks for taking a look at it!
                                                        Process:         Adobe Photoshop CS6 [248]
                                                        Path:            /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                                                        Identifier:      com.adobe.Photoshop
                                                        Version:         13.0.0 (20120315.r.428)
                                                        Code Type:       X86-64 (Native)
                                                        Parent Process:  launchd [141]
                                                        Date/Time:       2012-07-18 18:04:30.265 -0500
                                                        OS Version:      Mac OS X 10.7.4 (11E53)
                                                        Report Version:  9
                                                        Interval Since Last Report:          613984 sec
                                                        Crashes Since Last Report:           12
                                                        Per-App Interval Since Last Report:  504276 sec
                                                        Per-App Crashes Since Last Report:   8
                                                        Anonymous UUID:                      F02966FE-DF7D-4A9A-A5CE-621DA787C84D
                                                        Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                                                        VM Regions Near 0:
                                                            __TEXT                 0000000100000000-000000010333d000 [ 51.2M] r-x/rwx SM=COW  /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                                                        Application Specific Information:
                                                        objc[248]: garbage collection is OFF
                                                        Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                                                        0   Photoshop3DEngine                       0x000000015d87fc46 main + 904550
                                                        1   Photoshop3DEngine                       0x000000015d83de9d main + 634813
                                                        2   Photoshop3DEngine                       0x000000015d83decc main + 634860
                                                        3   Photoshop3DEngine                       0x000000015d846688 main + 669608
                                                        4   Photoshop3DEngine                       0x000000015d7fa8f9 main + 358937
                                                        5   Photoshop3DEngine                       0x000000015d7fbded main + 364301
                                                        6   Photoshop3DEngine                       0x000000015d7fdc32 main + 372050
                                                        7   Photoshop3DEngine                       0x000000015d7bb200 main + 99104
                                                        8   Photoshop3DEngine                       0x000000015d7bc44e main + 103790
                                                        9   Photoshop3DEngine                       0x000000015d7bcdd4 main + 106228
                                                        10  Photoshop3DEngine                       0x000000015d7be9be main + 113374
                                                        11  Photoshop3DEngine                       0x000000015d7bfe69 main + 118665
                                                        12  Photoshop3DEngine                       0x000000015d7c083f main + 121183
                                                        13  Photoshop3DEngine                       0x000000015d7a2730 FnCachedPrecalculatedKernels::FnCachedPrecalculatedKernels() + 1692
                                                        14  Photoshop3DEngine                       0x000000015d7a2bc0 FnCachedPrecalculatedKernels::FnCachedPrecalculatedKernels() + 2860
                                                        15  Photoshop3DEngine                       0x000000015d7a2f3b main + 91
                                                        16  com.adobe.Photoshop                     0x0000000100180c19 0x100000000 + 1575961
                                                        17  com.adobe.Photoshop                     0x00000001002c2fc4 0x100000000 + 2895812
                                                        18  com.adobe.Photoshop                     0x0000000101993fd9 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18079353
                                                        19  com.adobe.Photoshop                     0x0000000101999431 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18100945
                                                        20  com.adobe.Photoshop                     0x00000001012fc8ff AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 11167647
                                                        21  com.adobe.Photoshop                     0x00000001012fc9d8 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 11167864
                                                        22  com.adobe.Photoshop                     0x00000001012fcd64 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 11168772
                                                        23  com.adobe.Photoshop                     0x00000001001a836f 0x100000000 + 1737583
                                                        24  com.adobe.Photoshop                     0x000000010028711c 0x100000000 + 2650396
                                                        25  com.adobe.Photoshop                     0x00000001002874f9 0x100000000 + 2651385
                                                        26  com.adobe.Photoshop                     0x000000010028afa3 0x100000000 + 2666403
                                                        27  com.adobe.Photoshop                     0x000000010028b289 0x100000000 + 2667145
                                                        28  com.adobe.Photoshop                     0x000000010028bc02 0x100000000 + 2669570
                                                        29  com.adobe.Photoshop                     0x00000001010c4eb3 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 8842579
                                                        30  com.adobe.Photoshop                     0x0000000101b3fe58 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 19832056
                                                        31  com.adobe.Photoshop                     0x0000000101b4166f AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 19838223
                                                        32  com.adobe.Photoshop                     0x0000000101b41b52 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 19839474
                                                        33  com.adobe.Photoshop                     0x00000001010d0706 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 8889766
                                                        34  com.adobe.Photoshop                     0x00000001009ad2fa AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 1405338
                                                        35  com.adobe.Photoshop                     0x0000000100ada4d7 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 2638711
                                                        36  com.adobe.Photoshop                     0x000000010061463e boost::system::system_error::what() const + 311358
                                                        37  com.adobe.Photoshop                     0x0000000100614674 boost::system::system_error::what() const + 311412
                                                        38  com.adobe.Photoshop                     0x00000001005b0c02 0x100000000 + 5966850
                                                        39  com.adobe.Photoshop                     0x00000001005b77ec 0x100000000 + 5994476
                                                        40  com.adobe.Photoshop                     0x00000001005ad3ae 0x100000000 + 5952430
                                                        41  com.adobe.Photoshop                     0x000000010001faa2 0x100000000 + 129698
                                                        42  com.adobe.Photoshop                     0x00000001019202d4 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17604980
                                                        43  com.apple.Foundation                    0x00007fff97b2ef40 __NSFireTimer + 102
                                                        44  com.apple.CoreFoundation                0x00007fff994e6934 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
                                                        45  com.apple.CoreFoundation                0x00007fff994e6486 __CFRunLoopDoTimer + 534
                                                        46  com.apple.CoreFoundation                0x00007fff994c6e11 __CFRunLoopRun + 1617
                                                        47  com.apple.CoreFoundation                0x00007fff994c6486 CFRunLoopRunSpecific + 230
                                                        48  com.apple.HIToolbox                     0x00007fff90d5d4d3 RunCurrentEventLoopInMode + 277
                                                        49  com.apple.HIToolbox                     0x00007fff90d646d3 ReceiveNextEventCommon + 181
                                                        50  com.apple.HIToolbox                     0x00007fff90d6460e BlockUntilNextEventMatchingListInMode + 62
                                                        51  com.apple.AppKit                        0x00007fff9276be31 _DPSNextEvent + 659
                                                        52  com.apple.AppKit                        0x00007fff9276b735 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
                                                        53  com.apple.AppKit                        0x00007fff92768071 -[NSApplication run] + 470
                                                        54  com.adobe.Photoshop                     0x0000000101920402 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17605282
                                                        55  com.adobe.Photoshop                     0x000000010192266e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17614094
                                                        56  com.adobe.Photoshop                     0x00000001005ae27c 0x100000000 + 5956220
                                                        57  com.adobe.Photoshop                     0x00000001007b074f boost::system::system_error::what() const + 1999183
                                                        58  com.adobe.Photoshop                     0x00000001007b0999 boost::system::system_error::what() const + 1999769
                                                        59  com.adobe.Photoshop                     0x000000010054b24c 0x100000000 + 5550668
                                                        Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                                                        0   libsystem_kernel.dylib                  0x00007fff9a0837e6 kevent + 10
                                                        1   libdispatch.dylib                       0x00007fff93a5f78a _dispatch_mgr_invoke + 923
                                                        2   libdispatch.dylib                       0x00007fff93a5e31a _dispatch_mgr_thread + 54
                                                        Thread 2:
                                                        0   libsystem_kernel.dylib                  0x00007fff9a082bca __psynch_cvwait + 10
                                                        1   libsystem_c.dylib                       0x00007fff924dd274 _pthread_cond_wait + 840
                                                        2   MultiProcessor Support                  0x000000010ef860f3 main + 8403
                                                        3   MultiProcessor Support                  0x000000010ef861b0 main + 8592
                                                        4   MultiProcessor Support                  0x000000010efa2f50 main + 126768
                                                        5   libsystem_c.dylib                       0x00007fff924d98bf _pthread_start + 335
                                                        6   libsystem_c.dylib                       0x00007fff924dcb75 thread_start + 13
                                                        Thread 3:
                                                        Thread 4:
                                                        Thread 5:
                                                        2   com.apple.CoreServices.CarbonCore          0x00007fff8db7da5e TSWaitOnCondition + 106
                                                        3   com.apple.CoreServices.CarbonCore          0x00007fff8db0fea6 TSWaitOnConditionTimedRelative + 127
                                                        4   com.apple.CoreServices.CarbonCore          0x00007fff8db54e81 MPWaitOnQueue + 181
                                                        5   com.adobe.ACE                           0x00000001051482c9 0x10510f000 + 234185
                                                        6   com.adobe.ACE                           0x00000001051475da 0x10510f000 + 230874
                                                        7   com.apple.CoreServices.CarbonCore          0x00007fff8db55ce6 PrivateMPEntryPoint + 58
                                                        8   libsystem_c.dylib                       0x00007fff924d98bf _pthread_start + 335
                                                        9   libsystem_c.dylib                       0x00007fff924dcb75 thread_start + 13
                                                        Thread 6:
                                                        Thread 7:
                                                        Thread 8:
                                                        0   libsystem_kernel.dylib                  0x00007fff9a082e42 __semwait_signal + 10
                                                        1   libsystem_c.dylib                       0x00007fff9248fdea nanosleep + 164
                                                        2   com.adobe.PSAutomate                    0x00000001170f29cb ScObjects::Thread::sleep(unsigned int) + 59
                                                        3   com.adobe.PSAutomate                    0x00000001170d87c9 ScObjects::BridgeTalkThread::run() + 169
                                                        4   com.adobe.PSAutomate                    0x00000001170f2d36 ScObjects::Thread::go(void*) + 166
                                                        Thread 9:
                                                        2   com.adobe.ape.engine                    0x000000011809ac0d APXGetHostAPI + 2516093
                                                        3   com.adobe.ape.engine                    0x0000000117e48ec1 APXGetHostAPI + 83761
                                                        4   com.adobe.ape.engine                    0x000000011809acd1 APXGetHostAPI + 2516289
                                                        5   com.adobe.ape.engine                    0x000000011809ad4a APXGetHostAPI + 2516410
                                                        6   com.adobe.ape.engine                    0x000000011809ae79 APXGetHostAPI + 2516713
                                                        7   libsystem_c.dylib                       0x00007fff924d98bf _pthread_start + 335
                                                        8   libsystem_c.dylib                       0x00007fff924dcb75 thread_start + 13
                                                        Thread 10:
                                                        Thread 11:
                                                        Thread 12:
                                                        Thread 13:
                                                        0   libsystem_kernel.dylib                  0x00007fff9a08167a mach_msg_trap + 10
                                                        1   libsystem_kernel.dylib                  0x00007fff9a080d71 mach_msg + 73
                                                        2   com.apple.CoreFoundation                0x00007fff994be50c __CFRunLoopServiceMachPort + 188
                                                        3   com.apple.CoreFoundation                0x00007fff994c6c74 __CFRunLoopRun + 1204
                                                        4   com.apple.CoreFoundation                0x00007fff994c6486 CFRunLoopRunSpecific + 230
                                                        5   com.apple.CoreMediaIO                   0x00007fff96cd4fe9 CMIO::DAL::RunLoop::OwnThread(void*) + 159
                                                        6   com.apple.CoreMediaIO                   0x00007fff96ccb15a CAPThread::Entry(CAPThread*) + 98
                                                        Thread 14:
                                                        1   libsystem_c.dylib                       0x00007fff924dd2a6 _pthread_cond_wait + 890
                                                        2   com.adobe.ape.engine                    0x000000011809abd0 APXGetHostAPI + 2516032
                                                        3   com.adobe.ape.engine                    0x00000001180b2ddb APXGetHostAPI + 2614859
                                                        Thread 15:
                                                        3   com.adobe.ape.engine                    0x000000011822d2c3 APXGetHostAPI + 4164403
                                                        Thread 16:
                                                        0   libsystem_kernel.dylib                  0x00007fff9a082d7a __recvfrom + 10
                                                        1   ServiceManager-Launcher.dylib           0x0000000117ccd5ec Invoke + 45721
                                                        2   ServiceManager-Launcher.dylib           0x0000000117ccc813 Invoke + 42176
                                                        3   ServiceManager-Launcher.dylib           0x0000000117ccbbe0 Invoke + 39053
                                                        4   ServiceManager-Launcher.dylib           0x0000000117ccbc66 Invoke + 39187
                                                        5   ServiceManager-Launcher.dylib           0x0000000117cc730f Invoke + 20412
                                                        6   ServiceManager-Launcher.dylib           0x0000000117cc7616 Invoke + 21187
                                                        7   ServiceManager-Launcher.dylib           0x0000000117cc7cd7 Invoke + 22916
                                                        8   ServiceManager-Launcher.dylib           0x0000000117cc7f41 Invoke + 23534
                                                        9   ServiceManager-Launcher.dylib           0x0000000117cca61d Invoke + 33482
                                                        10  ServiceManager-Launcher.dylib           0x0000000117cca775 Invoke + 33826
                                                        11  ServiceManager-Launcher.dylib           0x0000000117ccafb2 Invoke + 35935
                                                        12  ServiceManager-Launcher.dylib           0x0000000117ccb0ad Invoke + 36186
                                                        13  ServiceManager-Launcher.dylib           0x0000000117cbdd6b Login + 480
                                                        14  ServiceManager-Launcher.dylib           0x0000000117cc17ad Login + 15394
                                                        15  ServiceManager-Launcher.dylib           0x0000000117ccb412 Invoke + 37055
                                                        16  ServiceManager-Launcher.dylib           0x0000000117ccd253 Invoke + 44800
                                                        17  libsystem_c.dylib                       0x00007fff924d98bf _pthread_start + 335
                                                        18  libsystem_c.dylib                       0x00007fff924dcb75 thread_start + 13
                                                        Thread 17:
                                                        2   libtbb.dylib                            0x00000001039ce010 tbb::internal::rml::private_worker::thread_routine(void*) + 416
                                                        3   libsystem_c.dylib                       0x00007fff924d98bf _pthread_start + 335
                                                        4   libsystem_c.dylib                       0x00007fff924dcb75 thread_start + 13
                                                        Thread 18:
                                                        Thread 19:
                                                        Thread 20:
                                                        Thread 21:: com.apple.CFSocket.private
                                                        0   libsystem_kernel.dylib                  0x00007fff9a082df2 __select + 10
                                                        1   com.apple.CoreFoundation                0x00007fff9950fc8b __CFSocketManager + 1355
                                                        2   libsystem_c.dylib                       0x00007fff924d98bf _pthread_start + 335
                                                        3   libsystem_c.dylib                       0x00007fff924dcb75 thread_start + 13
                                                        Thread 22:
                                                        2   com.adobe.Photoshop                     0x00000001019d4dfb AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18345115
                                                        3   com.adobe.Photoshop                     0x00000001019d4ee2 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18345346
                                                        4   com.adobe.Photoshop                     0x00000001019d2d95 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18336821
                                                        5   com.adobe.Photoshop                     0x0000000101958160 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17833984
                                                        6   libsystem_c.dylib                       0x00007fff924d98bf _pthread_start + 335
                                                        7   libsystem_c.dylib                       0x00007fff924dcb75 thread_start + 13
                                                        Thread 23:
                                                        2   Photoshop3DEngine                       0x000000015d8c61e4 main + 1192708
                                                        Thread 24:
                                                        Thread 25:
                                                        Thread 26:
                                                        Thread 27:
                                                        5   com.adobe.dvacore.framework             0x000000016cc1c1e1 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 193
                                                        6   com.adobe.dvacore.framework             0x000000016cc038b3 boost::function0<void>::operator()() const + 51
                                                        7   com.adobe.dvacore.framework             0x000000016cc122f3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
                                                        8   com.adobe.boost_threads.framework          0x0000000151191f25 thread_proxy + 133
                                                        9   libsystem_c.dylib                       0x00007fff924d98bf _pthread_start + 335
                                                        10  libsystem_c.dylib                       0x00007fff924dcb75 thread_start + 13
                                                        Thread 28:
                                                        Thread 29:
                                                        1   com.adobe.dvatransport.framework          0x0000000169edf5b3 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 243
                                                        2   com.adobe.dvatransport.framework          0x0000000169eeb27b boost::asio::detail::task_io_service::run(boost::system::error_code&) + 555
                                                        3   com.adobe.dvatransport.framework          0x0000000169ed3ab5 SkyConnectionEnv::MainLoop() + 117
                                                        4   com.adobe.dvatransport.framework          0x0000000169ed3b19 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
                                                        5   com.adobe.boost_threads.framework          0x0000000151191f25 thread_proxy + 133
                                                        Thread 30:
                                                        2   com.adobe.dvatransport.framework          0x0000000169eeb4df boost::asio::detail::task_io_service::run(boost::system::error_code&) + 1167
                                                        3   com.adobe.dvatransport.framework          0x0000000169eebacd boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 61
                                                        4   com.adobe.dvatransport.framework          0x0000000169eddd99 boost_asio_detail_posix_thread_function + 25
                                                        Thread 31:
                                                        Thread 32:
                                                        Thread 33:
                                                        Thread 34:
                                                        Thread 35:: com.apple.appkit-heartbeat
                                                        2   libsystem_c.dylib                       0x00007fff9248fbb5 usleep + 53
                                                        3   com.apple.AppKit                        0x00007fff929a04d3 -[NSUIHeartBeat _heartBeatThread:] + 1727
                                                        4   com.apple.Foundation                    0x00007fff97b3172a -[NSThread main] + 68
                                                        5   com.apple.Foundation                    0x00007fff97b316a2 __NSThread__main__ + 1575
                                                        Thread 36:
                                                        2   com.apple.CoreServices.CarbonCore          0x00007fff8db0fec4 TSWaitOnConditionTimedRelative + 157
                                                        3   com.apple.CoreServices.CarbonCore          0x00007fff8db0fc9b TSWaitOnSemaphoreCommon + 358
                                                        4   com.apple.CoreServices.CarbonCore          0x00007fff8db436d6 AsyncFileThread(void*) + 219
                                                        Thread 37:
                                                        0   libsystem_kernel.dylib                  0x00007fff9a083192 __workq_kernreturn + 10
                                                        1   libsystem_c.dylib                       0x00007fff924db594 _pthread_wqthread + 758
                                                        2   libsystem_c.dylib                       0x00007fff924dcb85 start_wqthread + 13
                                                        Thread 0 crashed with X86 Thread State (64-bit):
                                                          rax: 0x0000000000000028  rbx: 0x0000000000000000  rcx: 0x0000000000000000  rdx: 0x000000015da73630
                                                          rdi: 0x0000000106bafa00  rsi: 0x0000000168600000  rbp: 0x00007fff5fbba590  rsp: 0x00007fff5fbba570
                                                           r8: 0x0000000000000000   r9: 0x00000001686e6d10  r10: 0x000000008edc8fbd  r11: 0x0000000000db47a0
                                                          r12: 0x0000000000000000  r13: 0x000000015dacc830  r14: 0x00000001686e6cc8  r15: 0x0000000117df5100
                                                          rip: 0x000000015d87fc46  rfl: 0x0000000000010246  cr2: 0x0000000000000000
                                                        Logical CPU: 0
                                                        Binary Images:
                                                               0x100000000 -        0x10333cfff +com.adobe.Photoshop (13.0.0 - 20120315.r.428) <6A87A703-3170-CA73-8C77-35C282C4E264> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                                                               0x1039bf000 -        0x1039ebff7 +libtbb.dylib (??? - ???) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbb.dylib
                                                               0x103a02000 -        0x103a10ff3 +libtbbmalloc.dylib (??? - ???) <CB038B96-2999-5EB1-E26A-7720A7A8F8CD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbbmalloc.dylib
                                                               0x103a24000 -        0x103a2bfff  org.twain.dsm (1.9.5 - 1.9.5) <D3C111E6-AAE8-3267-B760-1529D0917170> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                                                               0x103a33000 -        0x103a4dff7 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                                               0x103a56000 -        0x103a5cfff  com.apple.agl (3.2.0 - AGL-3.2.0) <AB0B5D3F-BA2A-3366-830A-EF9258C18276> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                                               0x103a63000 -        0x103c71fff +com.adobe.owl (AdobeOwl version 4.0.93 - 4.0.93) <CB035C4D-044D-4004-C887-814F944E62ED> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                                                               0x103cb2000 -        0x1040f8ff7 +com.adobe.MPS (AdobeMPS 5.8.0.19463 - 5.8.0.19463) <8A4BA3B2-6F6A-3958-ABDE-C3E8F21373B0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                                                               0x104174000 -        0x1044cdff7 +com.adobe.AGM (AdobeAGM 4.26.17.19243 - 4.26.17.19243) <E96C804B-158B-D4A2-9A64-482F9ADC29D0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                                               0x104536000 -        0x104897fef +com.adobe.CoolType (AdobeCoolType 5.10.31.19243 - 5.10.31.19243) <8BFF14FB-AA14-1CBF-C2A3-715363B5A841> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                                               0x1048e4000 -        0x10490cff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <9BDD08A8-2DD8-A570-7A7B-EDAA7097D61B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                                               0x104913000 -        0x10493ffff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636) <488DF1F7-A643-5168-706A-498A0322A87E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
                                                               0x104962000 -        0x104aafff7 +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <FFA48E0A-A17C-A04F-AE20-6815EB944DEA> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                                               0x104b23000 -        0x104b92fef +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <924155A9-D00E-B862-C490-5099BA70B978> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                                                               0x104bb9000 -        0x104c12fff +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <BC353D4E-1AE2-3FB5-D3EE-81A09C0C4328> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
                                                               0x104cb2000 -        0x104d39ff7 +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <5FCA15B4-F721-09C3-B412-1F86D9D7DE9E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
                                                               0x104d9e000 -        0x104db9ff7 +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <BB7B342A-8CBC-4B73-58A2-9B062F590EBC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                                                               0x104dd3000 -        0x105010fff +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <6839CFB1-74EE-B205-7D82-ABC5428E0810> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                                                               0x10510f000 -        0x105288fff +com.adobe.ACE (AdobeACE 2.19.18.19243 - 2.19.18.19243) <7F28B188-1D1B-20C9-BBB9-B74FCC12ECAD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                                               0x10529b000 -        0x1052bafff +com.adobe.BIB (AdobeBIB 1.2.02.19243 - 1.2.02.19243) <B7D7EE28-D604-2989-B099-62AEF4885C21> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                                               0x1052c1000 -        0x1053a5fe7 +com.adobe.amtlib (amtlib 6.0.0.75 - 6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                                               0x1053b6000 -        0x10547bfff +com.adobe.JP2K (2.0.0 - 2.0.0.18562) <B14B096C-AA23-BA8F-E3AE-8DB102F9D161> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                                                               0x1054c8000 -        0x1054ccff7 +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                                               0x1054d2000 -        0x105550fff +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 66.145433) <5C63613F-6BDE-1C29-D3FD-9D292F9ADB12> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                                                               0x105561000 -        0x1055c1ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <B475CD07-1024-560D-5BFE-2A6FCE63925C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                                                               0x1055cb000 -        0x105b23fef +com.nvidia.cg (2.2.0006 - ???) /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/Cg.framework/Cg
                                                               0x106180000 -        0x1061eefef +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                                               0x106242000 -        0x106267ffe +adobepdfsettings (??? - ???) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/adobepdfsettings
                                                               0x1062a2000 -        0x1062a6ff7 +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                                               0x1062ac000 -        0x10645cfef +com.adobe.PlugPlug (3.0.0.383 - 3.0.0.383) <908DBB12-D2AC-1844-BD2A-F1C483424917> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                                                               0x106513000 -        0x106533fff +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <DC3301F2-FC6E-70C7-3927-B0DD024210D6> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ocl.framework/Versions/A/aif_ocl
                                                               0x10654d000 -        0x10660afff +com.adobe.AdobeExtendScript (ExtendScript 4.2.12 - 4.2.12.18602) <0957DFA6-0593-CE4B-8638-00F32113B07B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                                                               0x106654000 -        0x106702fef +com.adobe.AdobeScCore (ScCore 4.2.12 - 4.2.12.18602) <9CEE95E5-2FC6-5E58-02A4-138EA6F8D894> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                                                               0x10673f000 -        0x106839fe7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <C7652AF2-56D7-8AF8-A207-0BDEDDFF0BEC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                                                               0x1068dd000 -        0x106b26fe7 +com.adobe.linguistic.LinguisticManager (6.0.0 - 17206) <301AAE8E-BA78-230E-9500-FCCA204B49CB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                                                               0x106ba9000 -        0x106ba9fff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <C23BF0A1-7E6D-35EF-85FE-651EE2C13D53> /usr/lib/libmx.A.dylib
                                                               0x106de5000 -        0x106de7fff  com.apple.textencoding.unicode (2.4 - 2.4) <FD4695F4-6110-36C6-AC06-86453E30FF6E> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                                               0x108ce9000 -        0x108cf8ff7  libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <D30A4333-0953-394D-BB26-739937ED0BD8> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                                                               0x108fb8000 -        0x108fd3fff  libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <59FCE9C0-27E6-34CE-89E5-3A83B843B36C> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                                                               0x108fd8000 -        0x108ff9fff  libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <25FF31F5-9D1E-35EB-8085-F0AC25C38DAC> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                                                               0x10a9ac000 -        0x10a9beff7  libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <66A3625A-6918-3C14-8DF3-2F4924C389EA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                                                               0x10a9c2000 -        0x10a9c3ff7  libCyrillicConverter.dylib (54.0.0 - compatibility 1.0.0) <C8D0607A-A668-36EE-AF03-866BD04B5611> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                                                               0x10aa4d000 -        0x10aa4dfff +Enable Async IO (??? - ???) <F56F1FB2-9CF1-19A8-0D14-885A652B19B7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
                                                               0x10cb9f000 -        0x10cbe5fe7 +com.adobe.pip (??? - 6.0.0.1654) <3576D8F9-E2F9-6EB8-6684-C2FE6B0A3731> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                                                               0x10cbf2000 -        0x10cbf5fff +FastCore (??? - ???) <29AAF151-6CC4-28C5-68B8-0F6600A20435> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
                                                               0x10ef41000 -        0x10efc6fff +MultiProcessor Support (??? - ???) <467BB668-E9DD-60F4-CAAD-768A98174734> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                                                               0x10f100000 -        0x10f16cfff +MMXCore (??? - ???) <B9B6C7FB-CE56-8F6F-664E-DFCBBC5E3ADE> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
                                                               0x10f4c6000 -        0x10f4f4ff7  GLRendererFloat (??? - ???) <E33704BC-AA25-3279-A585-ABC6B3176D3E> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                                                               0x110683000 -        0x11081cfff  GLEngine (??? - ???) <61484217-C41D-3A65-86BD-397ACC0D069F> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                                                               0x110850000 -        0x110949fff  libGLProgrammability.dylib (??? - ???) <7396EE13-5FA6-3E78-88D0-2502CFE79A97> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                                                               0x11096f000 -        0x110c37ff7  com.apple.ATIRadeonX3000GLDriver (7.18.18 - 7.1.8) <337EB117-0CB0-3C9E-AEE8-76BCB3CB9371> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLD river
                                                               0x1122d3000 -        0x1122d3ff5 +cl_kernels (??? - ???) <A18B85EF-CB20-4441-88A4-47B2F87D694B> cl_kernels
                                                               0x1122e4000 -        0x1122e8fff  com.apple.audio.AudioIPCPlugIn (1.2.2 - 1.2.2) <F94D690D-3196-3B01-B798-09708367D28D> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                                                               0x1162f5000 -        0x1162fafff  com.apple.audio.AppleHDAHALPlugIn (2.2.0 - 2.2.0f3) <4EC4981B-68AE-357E-960F-3D4603A61E9F> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                                                               0x1168df000 -        0x1168f2ff7 +MeasurementCore (??? - ???) <2E842E3B-9E4D-6D59-7E5B-A01979288E4B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/Mea surementCore
                                                               0x116fae000 -        0x117209ff7 +com.adobe.PSAutomate (13.0 - 13.0) <6EE89DAF-28E8-B15F-1C4B-18D8D19F6452> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Scri ptingSupport
                                                               0x11731b000 -        0x11740cfff +com.adobe.AdbeScriptUIFlex (ScriptUIFlex 6.2.29 - 6.2.29.18602) <2BD3388F-976E-0B1C-55DB-B97A5AF95724> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdbeScriptUIFlex.framework/Versions/A/AdbeScriptUIFlex
                                                               0x117490000 -        0x11750afef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                                                               0x117519000 -        0x11753fff7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <79E11A18-8AF4-2515-59F7-4CBE161BF020> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                                                               0x117c83000 -        0x117cadff7  com.apple.cmio.DAL.VDC_4 (212.0 - 3199.1.1) <143A9719-FB00-3476-9863-F4D9E3769A42> /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/MacOS/VDC
                                                               0x117cb8000 -        0x117ce3fff +ServiceManager-Launcher.dylib (389.0.0 - compatibility 2.5.0) <7AE35754-3413-206D-4B92-579AAA25B4F8> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
                                                               0x117cfe000 -        0x117cfeffd +cl_kernels (??? - ???) <C7DA2CBF-F994-4A93-990C-6F54AB30D1CE> cl_kernels
                                                               0x117e00000 -        0x118d85fd7 +com.adobe.ape.engine (3.3.8.19346 - 3.3.8.19346) <5E188E32-37F7-4E0B-0674-E8D16B60074F> /Library/Application Support/Adobe/*/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS/adbea peengine
                                                               0x118fd2000 -        0x1190b5fff  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <358B5B40-43B2-3F92-9FD3-DAA68806E1FF> /usr/lib/libcrypto.0.9.7.dylib
                                                               0x1195e9000 -        0x1195effef  libcldcpuengine.dylib (1.50.69 - compatibility 1.0.0) <303313AD-2D57-37A5-922B-3194C5DCD007> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
                                                               0x12b7bd000 -        0x12b803fff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/updaternotifications.framework/Versions/A/UpdaterNotification s
                                                               0x12b8a0000 -        0x12ba44ff7 +u3d (??? - ???) <B0F34E45-8B65-0F60-57D7-9B40E67F31B4> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/File Formats/U3D.plugin/Contents/MacOS/u3d
                                                               0x12ba62000 -        0x12baacfff  com.apple.glut (3.4.9 - GLUT-3.4.9) <D24E54A5-82F2-3A0E-AD00-683D0B4A865E> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
                                                               0x12c5f6000 -        0x12c5f9ff7  libCoreFSCache.dylib (??? - ???) <70D5EB80-24F5-3837-9302-EBD4CFCE5CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                                                               0x14fb63000 -        0x14fb6fff7 +com.adobe.boost_signals.framework (6.0.0 - 6.0.0.0) <D91CD69E-D477-A693-2CB4-CF3C07060958> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                                                               0x14fb88000 -        0x14fb90fff +com.adobe.boost_date_time.framework (6.0.0 - 6.0.0.0) <1087C7B8-0584-9E8C-7F69-7F2C8DD7C6FD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                                                               0x14fbd5000 -        0x14fbd6fff +com.adobe.boost_system.framework (6.0.0 - 6.0.0.0) <B8252337-41FD-999E-15F3-9F6D3C87AE3D> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                                                               0x151081000 -        0x151082ffc +cl_kernels (??? - ???) <17434303-E3CC-4252-BF47-E5281A916FD2> cl_kernels
                                                               0x15118f000 -        0x15119bfff +com.adobe.boost_threads.framework (6.0.0 - 6.0.0.0) <F5939D5C-7281-3337-354D-534EBE0CB434> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                                                               0x1512aa000 -        0x1512abff3 +cl_kernels (??? - ???) <60C57D33-BCF7-4E35-A4CC-AD6DA56B035B> cl_kernels
                                                               0x15d79e000 -        0x15da6fff7 +Photoshop3DEngine (??? - ???) <C4B9A3F4-750C-3B28-8EE9-F110960D734F> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/3D Engines/Photoshop3DEngine.plugin/Contents/MacOS/Photoshop3DEngine
                                                               0x166146000 -        0x166173ff7 +com.adobe.dvamediatypes.framework (6.0.0 - 6.0.0.0) <28567590-269D-5BE0-72B5-0CFD7D2405C6> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                                                               0x169b28000 -        0x169b50ff7 +com.adobe.dvaunittesting.framework (6.0.0 - 6.0.0.0) <8284BDA6-98A0-EDD3-BD53-DF6C20306F15> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                                                               0x169eb7000 -        0x169f17fff +com.adobe.dvatransport.framework (6.0.0 - 6.0.0.0) <CFFA02DF-01D5-72D6-5F62-14DD50375A89> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                                                               0x169f99000 -        0x169fddfff +com.adobe.dvamarshal.framework (6.0.0 - 6.0.0.0) <C09F4AD8-9F27-9D80-691E-B894832F5B83> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                                                               0x16a06d000 -        0x16a112ff7 +com.adobe.dvaaudiodevice.framework (6.0.0 - 6.0.0.0) <9A679BBE-8E5B-52F0-E734-27214B048AD3> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                                                               0x16c782000 -        0x16c90dff7 +com.adobe.mediacoreif.framework (6.0.0 - 6.0.0.0) <2A8D7169-E2DD-ED34-91AB-DB015DDCAA90> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/mediacoreif.framework/mediacoreif
                                                               0x16cb35000 -        0x16cd08fff +com.adobe.dvacore.framework (6.0.0 - 6.0.0.0) <741CA228-A4C0-46D7-EAE5-7B27A8830365> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                                               0x16cf97000 -        0x16d1d5fff +com.adobe.dynamiclink.framework (6.0.0 - 6.0.0.0) <EFBA7CE2-62B1-908B-8628-C835891855C2> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                                                               0x16d3ce000 -        0x16d4b7ff7 +com.adobe.dvaplayer.framework (6.0.0 - 6.0.0.0) <134D77DD-5C3B-7FA6-75E0-CF17CBB904A3> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                                                               0x16df0e000 -        0x16dfa1ff7  unorm8_bgra.dylib (1.50.69 - compatibility 1.0.0) <5FB796A4-1AD0-3B4D-AA83-F8A46E039224> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
                                                               0x16e383000 -        0x16e416ff7  unorm8_argb.dylib (1.50.69 - compatibility 1.0.0) <62C3F70B-9B04-39BD-BE29-582A1DE89A90> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_argb.dylib
                                                               0x16ff2d000 -        0x16ffddfe7 + (??? - ???) <3DC0B893-3983-14AD-9701-295239CCFAA5>
                                                               0x170549000 -        0x1708defe7 +com.adobe.standard.multiplugin (13.0 - 13.0) <E5601AB2-C390-AD03-9620-056F117DE6E8> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Filters/Standard Multiplugin.plugin/Contents/MacOS/Standard Multiplugin
                                                            0x7fff67e64000 -     0x7fff67e98baf  dyld (195.6 - ???) <C58DAD8A-4B00-3676-8637-93D6FDE73147> /usr/lib/dyld
                                                            0x7fff8d3aa000 -     0x7fff8d4b1fe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <EE02BB01-64C9-304D-9719-A35F5CD6D04C> /usr/lib/libsqlite3.dylib
                                                            0x7fff8d4bf000 -     0x7fff8d4c3fff  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
                                                            0x7fff8d4c4000 -     0x7fff8d51bfff  com.apple.Suggestions (1.1 - 85.1) <DE511C42-D2F2-309C-80EE-53862245DE22> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
                                                            0x7fff8d577000 -     0x7fff8d5f2ff7  com.apple.print.framework.PrintCore (7.1 - 366.3) <C5F39A82-0E77-3AD6-906A-20DD2EE8D374> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                                            0x7fff8d5f3000 -     0x7fff8d610ff7  com.apple.openscripting (1.3.3 - ???) <BDCCCBA9-F440-30BD-8378-FAB5AF685A5D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                                            0x7fff8d714000 -     0x7fff8d714fff  com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                                            0x7fff8d718000 -     0x7fff8d71bfff  com.apple.AppleSystemInfo (1.0 - 1) <111B6F69-3FBD-3860-BCF8-1DF02D9BED28> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                                                            0x7fff8d71c000 -     0x7fff8d8bbff7  com.apple.QuartzCore (1.7 - 270.4) <97E20A5F-652B-3E85-8C46-DCB777248ECD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                                            0x7fff8d8bc000 -     0x7fff8d8e5fff  com.apple.CoreVideo (1.7 - 70.3) <9A9D4058-9935-3B0A-B1A6-27EB78D02249> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                                            0x7fff8da9f000 -     0x7fff8dab6fff  com.apple.CFOpenDirectory (10.7 - 146) <BBB7C97E-7B46-3286-9128-32B5D16B5CBE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                                            0x7fff8dacc000 -     0x7fff8dde8fff  com.apple.CoreServices.CarbonCore (960.24 - 960.24) <6F99A26B-788F-37B9-860F-508906EC06D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                                            0x7fff8e06c000 -     0x7fff8e16efff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <AFBB22B7-07AE-3F2E-B88C-70BEEBFB8A86> /usr/lib/libxml2.2.dylib
                                                            0x7fff8e16f000 -     0x7fff8e16ffff  com.apple.ApplicationServices (41 - 41) <89B6AD5B-5C75-3E83-8C2B-AA7F4C55E400> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                                            0x7fff8e1d7000 -     0x7fff8e2e4fff  libJP2.dylib (??? - ???) <5BE8CFA7-00C2-3BDE-BC20-5FF6DC18B415> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
                                                            0x7fff8e2e5000 -     0x7fff8e68efef  com.apple.MediaToolbox (1.0 - 705.78) <A4DF8258-0CB9-3244-BF12-3AD02B1952B0> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                                            0x7fff8e68f000 -     0x7fff8e694fff  libcache.dylib (47.0.0 - compatibility 1.0.0) <1571C3AB-BCB2-38CD-B3B2-C5FC3F927C6A> /usr/lib/system/libcache.dylib
                                                            0x7fff8e6d8000 -     0x7fff8eb0bff7  com.apple.VideoToolbox (1.0 - 705.78) <7F115540-88CF-3087-951A-7073F7D58F4D> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                                            0x7fff8eb0e000 -     0x7fff8ed38fe7  com.apple.CoreData (104.1 - 358.14) <6BB64605-8DA7-337D-A2AB-A3346A421CBD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                                            0x7fff8ed39000 -     0x7fff8ed4bff7  libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
                                                            0x7fff8ed4c000 -     0x7fff8ed52fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                                            0x7fff8ed53000 -     0x7fff8ed92fff  com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                                            0x7fff8ed93000 -     0x7fff8eda1fff  com.apple.NetAuth (3.2 - 3.2) <F0D60E34-37A9-308D-B44E-E3450906173A> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                                            0x7fff8eda2000 -     0x7fff8edbffff  libxpc.dylib (77.19.0 - compatibility 1.0.0) <9F57891B-D7EF-3050-BEDD-21E7C6668248> /usr/lib/system/libxpc.dylib
                                                            0x7fff8edc0000 -     0x7fff8ee65fff  com.apple.ink.framework (1.4 - 110) <F93B76B3-E57C-3805-B20D-03717A3F91DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                                            0x7fff8ee66000 -     0x7fff8ee6aff7  com.apple.CommonPanels (1.2.5 - 94) <37C6540B-F8D1-355A-806C-F93D8FB522AB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                                            0x7fff8ee88000 -     0x7fff8ee8cfff  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <2B1215A0-1B43-39C3-B4F4-392D71D08FFA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                                                            0x7fff8ee8d000 -     0x7fff8f332fff  com.apple.RawCamera.bundle (3.12.0 - 615) <10CCCC87-4A1E-3343-BF09-1C6640B56F45> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                                                            0x7fff8f333000 -     0x7fff8f42dff7  com.apple.DiskImagesFramework (10.7.4 - 331.6) <C7860B00-E1CF-3851-9A3B-9F145B7F498F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                                                            0x7fff8f42e000 -     0x7fff8f4d0fff  com.apple.securityfoundation (5.0 - 55116) <A9311EF6-B7F7-3DA5-84E8-21BC9B2C3C69> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                                            0x7fff8f4d1000 -     0x7fff8f4d7ff7  libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
                                                            0x7fff8f4d8000 -     0x7fff8f530fff  libTIFF.dylib (??? - ???) <A0FF68DE-2935-30E7-B61C-4D9D70E14AD0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                                                            0x7fff8f531000 -     0x7fff8f9f8fff  FaceCoreLight (1.4.7 - compatibility 1.0.0) <BDD0E1DE-CF33-3AF8-B33B-4D1574CCC19D> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                                                            0x7fff8f9f9000 -     0x7fff8fadde5f  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <871E688B-CF57-3BC7-80D6-F6476DFF109B> /usr/lib/libobjc.A.dylib
                                                            0x7fff8fade000 -     0x7fff8fb22ff7  com.apple.MediaKit (12 - 602) <0C2CBEDA-412F-3DDF-9C74-44114E5E0DB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                                                            0x7fff8fb23000 -     0x7fff8fba8ff7  com.apple.Heimdal (2.2 - 2.0) <FF0BD9A4-6FB0-31E3-ABFB-563FBBEC45FC> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                                            0x7fff8ff04000 -     0x7fff8ff2fff7  com.apple.CoreServicesInternal (113.17 - 113.17) <B1DF81C3-9C23-3BAE-9DE8-21EAFEEB97B8> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                                            0x7fff8ff30000 -     0x7fff90514fff  libBLAS.dylib (??? - ???) <C34F6D88-187F-33DC-8A68-C0C9D1FA36DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                                            0x7fff90521000 -     0x7fff90521fff  com.apple.Carbon (153 - 153) <16EA5662-5C2C-3267-B419-66669AE536D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                                            0x7fff90522000 -     0x7fff90658fff  com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                                            0x7fff90659000 -     0x7fff90694fff  libsystem_info.dylib (??? - ???) <35F90252-2AE1-32C5-8D34-782C614D9639> /usr/lib/system/libsystem_info.dylib
                                                            0x7fff906e2000 -     0x7fff907a9ff7  com.apple.ColorSync (4.7.4 - 4.7.4) <590AFCDA-F10E-31FE-9B01-DA5FFE74C2BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                                            0x7fff907aa000 -     0x7fff907b5ff7  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
                                                            0x7fff907df000 -     0x7fff90855fff  com.apple.CoreSymbolication (2.2 - 73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                                            0x7fff9085e000 -     0x7fff90911ff7  com.apple.CoreText (220.20.0 - ???) <0E979362-15E4-3955-BF54-B5961361D1CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                                                            0x7fff90912000 -     0x7fff90917fff  libGIF.dylib (??? - ???) <8763F67F-A881-30B6-B20E-D395B4D9FD58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                                                            0x7fff90918000 -     0x7fff90aa2ff7  com.apple.WebKit (7534.56 - 7534.56.5) <BC22A17F-A32F-3D9B-926F-091A47C4B315> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                                                            0x7fff90aa3000 -     0x7fff90ab0ff7  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <DFAB8CA8-CC9D-3F58-8C12-CE120442AACD> /usr/lib/libbz2.1.0.dylib
                                                            0x7fff90ab1000 -     0x7fff90ab3ff7  com.apple.print.framework.Print (7.4 - 247.3) <626C58D5-2841-3329-8C32-9F4A8353F3E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                                            0x7fff90ab4000 -     0x7fff90b16ff7  com.apple.Symbolication (1.3 - 91) <0945ACAF-AA0A-3D01-9960-72B51722EC1F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                                            0x7fff90b17000 -     0x7fff90b17fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                                            0x7fff90cfb000 -     0x7fff90d1ffff  com.apple.RemoteViewServices (1.4 - 44.1) <EA3837DF-A3A3-37FF-AE11-D50048D5F21A> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                                            0x7fff90d20000 -     0x7fff90d5afe7  com.apple.DebugSymbols (2.1 - 87) <ED2B177C-4146-3715-91DF-D99A8ED5449A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                                            0x7fff90d5b000 -     0x7fff91087ff7  com.apple.HIToolbox (1.9 - ???) <B7D2A06B-7BE5-3355-BF7D-8139100B9B97> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                                            0x7fff91088000 -     0x7fff914a5ff7  com.apple.SceneKit (125.3 - 125.4) <12AD6DBE-F3A3-34D6-BA01-B211BEAFD48F> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
                                                            0x7fff914fd000 -     0x7fff91e9ac9f  com.apple.CoreGraphics (1.600.0 - ???) <1DB9C92C-DFA8-36ED-B513-998134462148> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                                            0x7fff91ecc000 -     0x7fff91ee2fff  libGL.dylib (??? - ???) <6A473BF9-4D35-34C6-9F8B-86B68091A9AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                                            0x7fff91ee3000 -     0x7fff91f10ff7  com.apple.opencl (1.50.69 - 1.50.69) <57939F7D-3626-30E2-883D-8A7CCB3F8763> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                                            0x7fff91f3b000 -     0x7fff91f45ff7  liblaunch.dylib (392.38.0 - compatibility 1.0.0) <6ECB7F19-B384-32C1-8652-2463C1CF4815> /usr/lib/system/liblaunch.dylib
                                                            0x7fff91f4c000 -     0x7fff91f58fff  com.apple.DirectoryService.Framework (10.7 - 146) <38778B01-2CF6-3A33-8A7A-FE016774B24C> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                                                            0x7fff91f59000 -     0x7fff91fb9fff  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <3A7521E6-5510-3FA7-AB65-79693A7A5839> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                                            0x7fff91fba000 -     0x7fff91ffbfff  com.apple.QD (3.40 - ???) <47674D2C-BE88-388E-B1B0-03F08BFFE5FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                                            0x7fff92001000 -     0x7fff9204aff7  com.apple.framework.CoreWLAN (2.1.2 - 212.2) <5E421E2D-50EA-340E-A5EE-C848DD6FC34F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                                                            0x7fff9204b000 -     0x7fff921a4fff  com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <0AD8197C-1BA9-30CD-98F1-4CA2C6559BA8> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                                            0x7fff921a5000 -     0x7fff921d5ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <3FC86118-7553-38F7-8916-B329D2E94476> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                                            0x7fff921d6000 -     0x7fff922e2fff  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <3A8E1F89-5E26-3C8B-B538-81F5D61DBF8A> /usr/lib/libcrypto.0.9.8.dylib
                                                            0x7fff922f8000 -     0x7fff9233efff  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <2C442396-1006-3765-92D2-60869D4641CE> /usr/lib/libcurl.4.dylib
                                                            0x7fff9233f000 -     0x7fff92458fff  com.apple.DesktopServices (1.6.3 - 1.6.3) <20812ECE-CACC-3D44-8108-025EF6B45C14> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                                            0x7fff92459000 -     0x7fff92460ff7  com.apple.CommerceCore (1.0 - 17) <3894FE48-EDCE-30E9-9796-E2F959D92704> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                                            0x7fff92461000 -     0x7fff9246cff7  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <6540EAF2-E3BF-3D2E-B4C1-F106180D6F20> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                                            0x7fff9246d000 -     0x7fff92482fff  com.apple.FileSync.framework (6.0.1 - 502.2) <65A5CD1B-766D-33F8-8AC1-0984499838E9> /System/Library/PrivateFrameworks/FileSync.framework/Versions/A/FileSync
                                                            0x7fff9248b000 -     0x7fff92568fef  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
                                                            0x7fff92569000 -     0x7fff9266efff  libFontParser.dylib (??? - ???) <759645F2-8CB1-358C-AF41-BA3797CD0F60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                                            0x7fff9268b000 -     0x7fff9269dff7  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
                                                            0x7fff926e5000 -     0x7fff926ebfff  IOSurface (??? - ???) <77C6757B-D357-3E34-9424-48F962B5CC9C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                                            0x7fff926ec000 -     0x7fff92762fff  com.apple.ISSupport (1.9.8 - 56) <2BEEF162-893F-356C-BD4E-8668F044A917> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
                                                            0x7fff92763000 -     0x7fff93369ff7  com.apple.AppKit (6.7.3 - 1138.47) <CAF5783F-F80B-30E7-929F-BBA6D96C5C44> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                                            0x7fff9336a000 -     0x7fff93404ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                                            0x7fff93459000 -     0x7fff93499fff  libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
                                                            0x7fff9349a000 -     0x7fff934acff7  libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
                                                            0x7fff934ad000 -     0x7fff93720fff  com.apple.CoreImage (7.98 - 1.0.1) <73485E4E-1407-3913-AB3C-B54986A3E01C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                                                            0x7fff93721000 -     0x7fff93923fff  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <38CD6ED3-C8E4-3CCD-89AC-9C3198803101> /usr/lib/libicucore.A.dylib
                                                            0x7fff93924000 -     0x7fff9392fff7  com.apple.DisplayServicesFW (2.5.4 - 323.3) <5E7F7A88-9313-3C31-87BD-80F3361DA338> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                                                            0x7fff9396e000 -     0x7fff93a58fff  com.apple.backup.framework (1.3.3 - 1.3.3) <6C49FBCF-D6AF-3351-BBBF-A98A622CA517> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                                                            0x7fff93a59000 -     0x7fff93a5bfff  com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                                            0x7fff93a5c000 -     0x7fff93a6afff  libdispatch.dylib (187.9.0 - compatibility 1.0.0) <1D5BE322-A9B9-3BCE-8FAC-076FB07CF54A> /usr/lib/system/libdispatch.dylib
                                                            0x7fff93a6b000 -     0x7fff93bd2fff  com.apple.CFNetwork (520.4.3 - 520.4.3) <31D7A595-375E-341A-8E97-21E73CC62E4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                                                            0x7fff93bd3000 -     0x7fff93c2fff7  com.apple.HIServices (1.21 - ???) <9645CFA8-63BE-3A0D-A636-56D9827E6C8C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                                            0x7fff93d28000 -     0x7fff93e06fff  com.apple.DiscRecording (6.0.4 - 6040.4.1) <E6D5835F-EE3C-3814-A2EE-6962B5570EF1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                                                            0x7fff93e15000 -     0x7fff93e1bfff  libmacho.dylib (800.0.0 - compatibility 1.0.0) <165514D7-1BFA-38EF-A151-676DCD21FB64> /usr/lib/system/libmacho.dylib
                                                            0x7fff93e5b000 -     0x7fff93e71ff7  com.apple.ImageCapture (7.0.1 - 7.0.1) <BF4EC1CC-C998-3529-A69F-765774C66A6F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                                            0x7fff93f7d000 -     0x7fff9429ffe7  com.apple.JavaScriptCore (7534.56 - 7534.56.6) <675725F8-37C4-3B80-ADB0-7B6AE908A908> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                                            0x7fff942a0000 -     0x7fff94fd7fff  com.apple.WebCore (7534.56 - 7534.56.5) <4E63291C-539E-32E3-8B1C-EA8E546B3159> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                                                            0x7fff94fd8000 -     0x7fff94fddfff  com.apple.OpenDirectory (10.7 - 146) <7960A302-F9AC-3F72-838E-3A382032DCA6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                                            0x7fff94fee000 -     0x7fff95041fff  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <E3FE9B47-2276-3316-B2D2-85784AD2D9B3> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                                            0x7fff95042000 -     0x7fff95047ff7  libsystem_network.dylib (??? - ???) <5DE7024E-1D2D-34A2-80F4-08326331A75B> /usr/lib/system/libsystem_network.dylib
                                                            0x7fff95048000 -     0x7fff95056ff7  com.apple.AppleFSCompression (37 - 1.0) <61113C2F-564C-3E6C-918C-3179980D599F> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                                                            0x7fff95061000 -     0x7fff950beff7  com.apple.QuickLookFramework (3.2 - 500.16) <46017A4B-9E2B-329C-A8D9-2C11DE6C1A47> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                                                            0x7fff950bf000 -     0x7fff950ecfe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <DA79E5BA-BBA3-3768-AAD8-B34BA877EF03> /usr/lib/libSystem.B.dylib
                                                            0x7fff9515c000 -     0x7fff951c4ff7  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <C6703B2E-62F2-37C4-A4DE-28AF9C81CB44> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                                            0x7fff951c5000 -     0x7fff951dafff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                                            0x7fff951db000 -     0x7fff951e1fff  libGFXShared.dylib (??? - ???) <8A61FA67-EB3C-319D-AE3C-64936FB26BAC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                                            0x7fff95256000 -     0x7fff9527cfff  com.apple.framework.familycontrols (3.0 - 300) <93828BC1-3D83-3A93-99A5-F0E7951AFC6C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                                            0x7fff9527d000 -     0x7fff9527efff  libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
                                                            0x7fff95280000 -     0x7fff952abfff  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <7D3CDB0A-840F-3856-8F84-B4A50E66431B> /usr/lib/libpcre.0.dylib
                                                            0x7fff952ac000 -     0x7fff95a40fef  com.apple.CoreAUC (6.16.11 - 6.16.11) <3D40FEA5-AFE7-3752-A52E-D0F80304320A> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                                                            0x7fff95a41000 -     0x7fff95a74ff7  com.apple.GSS (2.2 - 2.0) <971395D0-B9D0-3FDE-B23F-6F9D0A2FB95F> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                                            0x7fff95a75000 -     0x7fff95b16ff7  com.apple.LaunchServices (480.33 - 480.33) <45EF2044-3396-3910-9B5B-C8F7777D5F56> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                                            0x7fff95b17000 -     0x7fff95b1aff7  com.apple.securityhi (4.0 - 1) <D0ABB03B-CEF9-39E0-A139-AA9484DBBC07> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                                            0x7fff95b1b000 -     0x7fff95e6efff  com.apple.FinderKit (1.0.3 - 1.0.3) <D0BF82AD-69D6-3190-804C-6CF061BA22EF> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
                                                            0x7fff95e6f000 -     0x7fff95e86fff  com.apple.MultitouchSupport.framework (231.4 - 231.4) <10A978D1-8781-33F0-BE45-60C9171F7278> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                                            0x7fff95e87000 -     0x7fff95ed9ff7  libGLU.dylib (??? - ???) <E2EF0336-3A5F-3532-AEB0-6CCF04851B72> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                                            0x7fff95eda000 -     0x7fff95edbfff  libunc.dylib (24.0.0 - compatibility 1.0.0) <337960EE-0A85-3DD0-A760-7134CF4C0AFF> /usr/lib/system/libunc.dylib
                                                            0x7fff95f59000 -     0x7fff95f59fff  com.apple.Cocoa (6.6 - ???) <7EC4D759-B2A6-3A99-AC75-809FED1500C6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                                            0x7fff95f5f000 -     0x7fff95f88fff  com.apple.datadetectors (3.3 - 172.6) <4C5A759B-7CB7-3C0E-8C50-DC2CCE92F5F7> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                                                            0x7fff95f89000 -     0x7fff95fa5fff  com.apple.frameworks.preferencepanes (15.0 - 15.0) <A1ABA9DB-2C8A-3C96-976A-21E63194F7B2> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
                                                            0x7fff95fa6000 -     0x7fff95fbaff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                                            0x7fff95fbb000 -     0x7fff95ff4fe7  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <79AAEC98-1258-3DA4-B1C0-4120049D390B> /usr/lib/libssl.0.9.8.dylib
                                                            0x7fff95ff5000 -     0x7fff95ff8fff  libCoreVMClient.dylib (??? - ???) <934D0D11-C34F-3C06-A352-21BB8FFE9774> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                                            0x7fff96038000 -     0x7fff9603dfff  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
                                                            0x7fff9603e000 -     0x7fff962b3ff7  com.apple.imageKit (2.1.2 - 1.0) <5BAA52A9-F359-31E4-8109-74EBCEB626B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                                                            0x7fff962b8000 -     0x7fff9639cfff  com.apple.CoreServices.OSServices (478.46 - 478.46) <70BEE269-8F4D-3FDC-B1AD-A591C0CB37E5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                                            0x7fff9639d000 -     0x7fff963e1ff7  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <22B2A10A-34B5-3787-88C9-B2722FE79504> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                                            0x7fff963e2000 -     0x7fff963ebff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
                                                            0x7fff963ec000 -     0x7fff96413fff  com.apple.framework.internetaccounts (1.2 - 3) <483427CA-8140-355D-B668-78F5A5F1A1D6> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
                                                            0x7fff96414000 -     0x7fff96415fff  liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
                                                            0x7fff9645c000 -     0x7fff964e0ff7  com.apple.ApplicationServices.ATS (317.11.0 - ???) <082DEAFE-8A93-3AF2-B4E5-30012E725929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                                            0x7fff964e1000 -     0x7fff96574ff7  com.apple.PDFKit (2.6.3 - 2.6.3) <49BF9CDC-E902-3CAC-9C04-3302545907D5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                                                            0x7fff96575000 -     0x7fff96584ff7  libxar-nossl.dylib (??? - ???) <A6ABBFB9-E4ED-38AD-BBBB-F9958B9CEFB5> /usr/lib/libxar-nossl.dylib
                                                            0x7fff966bb000 -     0x7fff96724fff  com.apple.coreui (1.2.2 - 165.10) <F427BF39-3E01-3DC6-A63D-BFC50FE6C72E> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                                            0x7fff96751000 -     0x7fff967c7fff  libc++.1.dylib (28.1.0 - compatibility 1.0.0) <DA22E4D6-7F20-3BEA-9B89-2FBA735C2EE1> /usr/lib/libc++.1.dylib
                                                            0x7fff96980000 -     0x7fff96987fff  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <0AB51EE2-E914-358C-AC19-47BC024BDAE7> /usr/lib/system/libcopyfile.dylib
                                                            0x7fff9698a000 -     0x7fff96b14fff  com.apple.QTKit (7.7.1 - 2330) <4B5363D4-4854-342F-8B95-DE6559075B46> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                                            0x7fff96b15000 -     0x7fff96b1bff7  com.apple.phonenumbers (1.0 - 47) <BC6C2FE2-99C0-3AD6-AA9C-C88780FFFCCF> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                                                            0x7fff96b7e000 -     0x7fff96bd2fff  libFontRegistry.dylib (??? - ???) <822DD341-C735-36C9-9521-E8E98807D09D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                                            0x7fff96bd3000 -     0x7fff96cc8fff  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
                                                            0x7fff96cc9000 -     0x7fff96d1aff7  com.apple.CoreMediaIO (212.0 - 3199.1.1) <D8C364AF-A1E8-3215-ABF5-188B50A80B18> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                                                            0x7fff96d24000 -     0x7fff96d25ff7  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <739E6C83-AA52-3C6C-A680-B37FE2888A04> /usr/lib/system/libremovefile.dylib
                                                            0x7fff96d26000 -     0x7fff96d4afff  com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                                            0x7fff96d4b000 -     0x7fff96d6afff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <0635C52D-DD53-3721-A488-4C6E95607A74> /usr/lib/libresolv.9.dylib
                                                            0x7fff96d6b000 -     0x7fff96dabff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <5328C0AB-F169-3786-A3EC-9E82E960CAAF> /usr/lib/libcups.2.dylib
                                                            0x7fff96dc1000 -     0x7fff96df0fff  com.apple.shortcut (2.1 - 2.1) <43C186C0-6B0F-39FA-976A-C307CC410495> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                                                            0x7fff96df1000 -     0x7fff96dffff7  libkxld.dylib (??? - ???) <C2FC894F-3716-32C3-967E-6AD5E2697045> /usr/lib/system/libkxld.dylib
                                                            0x7fff96e00000 -     0x7fff96e5aff7  com.apple.ImageCaptureCore (3.0.3 - 3.0.3) <12C722EE-3A13-3937-ABDF-EDC922F4C299> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                                                            0x7fff96e5b000 -     0x7fff96e6bff7  com.apple.opengl (1.7.7 - 1.7.7) <0CA11278-746C-353A-923B-BCC0047190C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                                            0x7fff96e6c000 -     0x7fff96e6dfff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
                                                            0x7fff975a7000 -     0x7fff975d0ff7  com.apple.framework.Apple80211 (7.2.1 - 721.3) <4BA49D6F-373B-3F4E-A2B3-453C2ED66318> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                                                            0x7fff975dc000 -     0x7fff97900fff  com.apple.AddressBook.framework (6.1.2 - 1090) <65FE6A36-F3F8-37FE-8B88-50F20F278779> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                                                            0x7fff97908000 -     0x7fff97928fff  libPng.dylib (??? - ???) <F4D84592-C450-3076-88E9-8E6517C7EF33> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                                                            0x7fff97929000 -     0x7fff97951fff  com.apple.PerformanceAnalysis (1.11 - 11) <8D4C6382-DD92-37A2-BCFC-E89951320848> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                                            0x7fff9796b000 -     0x7fff979a9fff  com.apple.bom (11.0 - 183) <F300B9EC-995E-33A7-9175-9F07D4B68F16> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                                                            0x7fff979aa000 -     0x7fff97a15ff7  com.apple.framework.IOKit (2.0 - ???) <6C604894-7F61-3130-8499-20791D14577F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                                            0x7fff97a16000 -     0x7fff97a62ff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <0A7F1982-B4EA-3424-A0C7-FE46C6224F03> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                                            0x7fff97a71000 -     0x7fff97a9afff  libJPEG.dylib (??? - ???) <64D079F9-256A-323B-A837-84628B172F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                                                            0x7fff97a9b000 -     0x7fff97ad0fff  com.apple.securityinterface (5.0 - 55022.4) <09EC371E-0B6E-3849-A6C9-F8E9DB17BBCD> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                                                            0x7fff97ad1000 -     0x7fff97ad6fff  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
                                                            0x7fff97ad7000 -     0x7fff97df0fff  com.apple.Foundation (6.7.2 - 833.25) <22AAC369-B63C-3C55-8AC6-C3ECBA44DA7B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                                            0x7fff97df1000 -     0x7fff97df1fff  com.apple.quartzframework (1.5 - 1.5) <2C13AE76-C86B-3D48-A583-121689190F74> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                                                            0x7fff97e2f000 -     0x7fff97ef6ff7  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <7E2E109C-A438-3EDC-A6EB-3EF634A1B28B> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
                                                            0x7fff97ef7000 -     0x7fff97efafff  libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                                                            0x7fff97efb000 -     0x7fff97f6efff  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
                                                            0x7fff97f8e000 -     0x7fff97f8efff  com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                                            0x7fff97f8f000 -     0x7fff97f90ff7  libsystem_sandbox.dylib (??? - ???) <96D38E74-F18F-3CCB-A20B-E8E3ADC4E166> /usr/lib/system/libsystem_sandbox.dylib
                                                            0x7fff97f91000 -     0x7fff97fbefff  com.apple.quartzfilters (1.7.0 - 1.7.0) <CE1EDD58-7273-38F9-AD33-871A8BA7ABF3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                                                            0x7fff97fbf000 -     0x7fff97fdbff7  com.apple.GenerationalStorage (1.0 - 126.1) <509F52ED-E54B-3FEF-B3C2-759387B826E6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                                            0x7fff97fdc000 -     0x7fff97fddff7  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
                                                            0x7fff97fde000 -     0x7fff98020ff7  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <BB770C22-8C57-365A-8716-4A3C36AE7BFB> /usr/lib/system/libcommonCrypto.dylib
                                                            0x7fff98021000 -     0x7fff98121fff  com.apple.QuickLookUIFramework (3.2 - 500.16) <0BACF8C4-5A7B-31EE-B4AA-3CCF8615C9A8> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                                                            0x7fff98122000 -     0x7fff98124fff  libquarantine.dylib (36.6.0 - compatibility 1.0.0) <0EBF714B-4B69-3E1F-9A7D-6BBC2AACB310> /usr/lib/system/libquarantine.dylib
                                                            0x7fff98125000 -     0x7fff98129fff  libdyld.dylib (195.6.0 - compatibility 1.0.0) <FFC59565-64BD-3B37-90A4-E2C3A422CFC1> /usr/lib/system/libdyld.dylib
                                                            0x7fff9812a000 -     0x7fff9813dff7  libCRFSuite.dylib (??? - ???) <0B76941F-218E-30C8-B6DE-E15919F8DBEB> /usr/lib/libCRFSuite.dylib
                                                            0x7fff98179000 -     0x7fff981c0ff7  com.apple.CoreMedia (1.0 - 705.78) <F6EA2328-FD3E-3057-80C7-C9845837F863> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                                                            0x7fff981c1000 -     0x7fff984aaff7  com.apple.security (7.0 - 55148.1) <E9C46204-1336-3D90-BC67-5162FC7079D2> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                                            0x7fff984ab000 -     0x7fff984e6fff  com.apple.LDAPFramework (3.2 - 120.2) <A2675243-9122-308D-A5C8-9C1C4FE7639D> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                                                            0x7fff984e7000 -     0x7fff98526ff7  libGLImage.dylib (??? - ???) <49BB4404-68F1-3839-A5C9-983405B59F52> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                                            0x7fff98550000 -     0x7fff98557fff  libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <B3F07872-63B1-3AAF-A313-9B2886822C58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
                                                            0x7fff98558000 -     0x7fff98558fff  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
                                                            0x7fff98559000 -     0x7fff985efff7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <642D8D54-F9F5-3FBB-A96C-EEFE94C6278B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                                            0x7fff985f0000 -     0x7fff98660fff  com.apple.datadetectorscore (3.0 - 179.4) <9C01D16F-75A9-3BDD-B91A-F0F32261A2E7> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                                            0x7fff98661000 -     0x7fff9866ffff  com.apple.HelpData (2.1.2 - 72.2) <363E36C5-F7C0-34A6-83D3-97C8FB6511F0> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                                                            0x7fff98702000 -     0x7fff98970ff7  com.apple.QuartzComposer (5.0 - 236.7) <D556126B-3D67-3E37-82E0-D06532DE0C89> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                                                            0x7fff9904d000 -     0x7fff9904dfff  com.apple.Accelerate (1.7 - Accelerate 1.7) <82DDF6F5-FBC3-323D-B71D-CF7ABC5CF568> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                                            0x7fff9904e000 -     0x7fff9947bfff  libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                                            0x7fff9948e000 -     0x7fff99662ff7  com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                                            0x7fff99872000 -     0x7fff99904ff7  com.apple.CorePDF (3.1 - 3.1) <F81F99A9-7FF6-3A6A-92C7-78C76BA35777> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                                                            0x7fff99905000 -     0x7fff99908fff  com.apple.help (1.3.2 - 42) <BF14DE49-F7E8-336F-81FB-BBDF2DB3AC09> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                                            0x7fff99909000 -     0x7fff99916fff  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <528BAA66-C38C-3093-84B5-92A7832CE7BC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                                            0x7fff99917000 -     0x7fff99942ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
                                                            0x7fff99dd8000 -     0x7fff99e2cff7  com.apple.ScalableUserInterface (1.0 - 1) <33563775-C662-313D-B7FA-3D575A9F3D41> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                                                            0x7fff99e2d000 -     0x7fff99f2aff7  com.apple.avfoundation (2.0 - 180.40) <ED3DCB15-7E88-34FD-9E56-4ECAD10A6E7E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                                                            0x7fff99f8c000 -     0x7fff9a06bff7  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <FFA7532B-336A-3F0B-9AB9-2A35B56ED887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                                                            0x7fff9a06c000 -     0x7fff9a08cfff  libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <1DDC0B0F-DB2A-34D6-895D-E5B2B5618946> /usr/lib/system/libsystem_kernel.dylib
                                                            0x7fff9a08d000 -     0x7fff9a098fff  com.apple.CommonAuth (2.2 - 2.0) <77E6F0D0-85B6-30B5-B99C-F57104DD2EBA> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                                            0x7fff9a099000 -     0x7fff9a0e7fff  libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
                                                            0x7fff9a0e8000 -     0x7fff9a102fff  com.apple.CoreMediaAuthoring (2.0 - 891) <C7A92C52-AD9F-3CF1-86D5-C0714118935C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                                                            0x7fff9a103000 -     0x7fff9a186fef  com.apple.Metadata (10.7.0 - 627.32) <38735923-2EB5-3133-BE36-BDD65A7E47DB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                                            0x7fff9a187000 -     0x7fff9a18ffff  libsystem_dnssd.dylib (??? - ???) <D9BB1F87-A42B-3CBC-9DC2-FC07FCEF0016> /usr/lib/system/libsystem_dnssd.dylib
                                                            0x7fff9a21f000 -     0x7fff9a226fff  com.apple.NetFS (4.0 - 4.0) <433EEE54-E383-3505-9154-45B909FD3AF0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                                            0x7fff9a23a000 -     0x7fff9a23afff  com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                                            0x7fff9a3a8000 -     0x7fff9a3aafff  libCVMSPluginSupport.dylib (??? - ???) <1C73D331-6F6C-3872-A011-1C41FBF49F2A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                                        External Modification Summary:
                                                          Calls made by other processes targeting this process:
                                                            task_for_pid: 16
                                                            thread_create: 0
                                                            thread_set_state: 0
                                                          Calls made by this process:
                                                            task_for_pid: 0
                                                            thread_create: 0
                                                            thread_set_state: 0
                                                          Calls made by all processes on this machine:
                                                            task_for_pid: 962
                                                            thread_create: 0
                                                            thread_set_state: 0
                                                        VM Region Summary:
                                                        ReadOnly portion of Libraries: Total=364.5M resident=210.2M(58%) swapped_out_or_unallocated=154.4M(42%)
                                                        Writable regions: Total=13.0G written=12.2G(94%) resident=12.3G(95%) swapped_out=0K(0%) unallocated=655.5M(5%)
                                                        REGION TYPE                      VIRTUAL
                                                        ATS (font support)                 32.0M
                                                        ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
                                                        CG backing stores                  18.4M
                                                        CG image                           1072K
                                                        CG raster data                      428K
                                                        CG shared images                   3384K
                                                        CoreAnimation                         4K
                                                        CoreGraphics                         16K
                                                        CoreImage                             8K
                                                        CoreServices                       2416K
                                                        IOKit                             154.6M
                                                        IOKit (reserved)                  258.5M        reserved VM address space (unallocated)
                                                        MALLOC                             12.2G
                                                        MALLOC guard page                    48K
                                                        MALLOC_LARGE (reserved)            1192K        reserved VM address space (unallocated)
                                                        Memory tag=240                     30.5M
                                                        Memory tag=242                       12K
                                                        Memory tag=251                       64K
                                                        OpenCL                               40K
                                                        OpenGL GLSL                        1372K
                                                        OpenGL GLSL (reserved)              128K        reserved VM address space (unallocated)
                                                        STACK GUARD                        56.1M
                                                        Stack                              46.4M
                                                        VM_ALLOCATE                       246.5M
                                                        __CI_BITMAP                          80K
                                                        __DATA                             42.1M
                                                        __IMAGE                             528K
                                                        __LINKEDIT                         69.7M
                                                        __RC_CAMERAS                        244K
                                                        __TEXT                            294.9M
                                                        __UNICODE                           544K
                                                        mapped file                       112.9M
                                                        shared memory                      6924K
                                                        TOTAL                              13.5G
                                                        TOTAL, minus reserved VM space     13.3G
                                                        Model: iMac11,3, BootROM IM112.0057.B01, 4 processors, Intel Core i5, 2.8 GHz, 16 GB, SMC 1.59f2
                                                        Graphics: ATI Radeon HD 5750, ATI Radeon HD 5750, PCIe, 1024 MB
                                                        Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0000, 0x000000000000000000000000000000000000
                                                        Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0000, 0x000000000000000000000000000000000000
                                                        Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1333 MHz, 0x0000, 0x000000000000000000000000000000000000
                                                        Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1333 MHz, 0x0000, 0x000000000000000000000000000000000000
                                                        AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.64.8-P2P
                                                        Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
                                                        Network Service: Ethernet, Ethernet, en0
                                                        Serial ATA Device: SAMSUNG HD103SJ, 1 TB
                                                        Serial ATA Device: OPTIARC DVD RW AD-5680H
                                                        USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
                                                        USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
                                                        USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 5
                                                        USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfa120000 / 3
                                                        USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
                                                        USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0xfd130000 / 6
                                                        USB Device: iPod, apple_vendor_id, 0x1299, 0xfd133000 / 8
                                                        USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd131000 / 7
                                                        USB Device: Apple Keyboard, apple_vendor_id, 0x024f, 0xfd131200 / 9
                                                        USB Device: OWC Mercury Elite, 0x0926, 0x0004, 0xfd140000 / 5
                                                        USB Device: Built-in iSight, apple_vendor_id, 0x8502, 0xfd110000 / 4
                                                        USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
                                                        • 25. Re: External solid state drive for scratch disk?
                                                          the_wine_snob Level 9
                                                          I can see the person, to whom you are Replying, and if I were to switch my View of the forums from Flattened, to Threaded, could probably see things better. [Wish that there was an "on-the-fly" toggle for the View, but maybe only in my dreams?]
                                                          What do I do? Well, for the last 38 years, I was an advertising photographer, and began incorporating PS into my studio, about 20 years ago, when it was first offered for the PC. Now, my last degree was in cinematography, with work toward an MFA in film, but just fell into still work. Over the last decade, I started getting back to "film," but now it was Video. I've been using Premiere Pro, from version 1.0, and several other NLE programs, before that.
                                                          Now, 3D is not exactly like Video, but there are some strong similarities, especially at the hardware end of things. About every five years, I build a workstation with what is, at that moment in time, "state-of-the-art" equipment. I am between systems right now. I am looking closely at the current crop of SSD's, and trying to determine if, and where, they might fit into my next system (probably my last, as I am now retired).
                                                          The reason that I mentioned Harm Millaard, and linked to his most recent article on hardware, is that he spends much of his time developing real-world benchmarks and testing equipment. HIs testing is around Premiere Pro, and he has a Web site for benchmarking that program w/ hundreds of computer configurations. The benchmark can be found HERE. Part of the beauty of that site is that there is a spreadsheet with performance benchmarks, and one can look at the hardware that makes a real contribution, or poses a bottleneck. No reviewer puffery, on "theoretical" performance, but real-world, which is, after all, where we live, and work.
                                                          Again, that benchmark is using Premiere Pro, but everything is common, regarding the testing, and reporting. For your purposes, I think that you might be able to draw some conclusions on the Exporting scores, as Rendering in 3D is somewhat similar.
                                                          As Harm, Bill Gherke, and the lads from super computer builder ADK hang out in the Adobe Premiere Hardware Forum, I mentioned that to you. While your particular needs might be a bit off to the side of what most of those folk do, they can likely give you some of that "real-world" equipment experience.
                                                          Good luck,
                                                          Hunt
                                                          • 26. Re: External solid state drive for scratch disk?
                                                            Level 7
                                                            The crash has nothing to do with RAM or the scratch disk - that one is a bug in the 3D code that the 3D team is working on.
                                                            • 27. Re: External solid state drive for scratch disk?
                                                              carolgunn Level 1
                                                              Chris, not the answer I wanted, (insert smiley face) but thanks just the same. Coupla questions:
                                                              1. I have not been in this forum long, but long enough to know that if i asked when you thought the bug would be fixed, I would get your boilerplate reply. Still, is there anything you can say about that?
                                                              2. Does this bug apply to After Effects as well, or is it just Photoshop?
                                                              • 28. Re: External solid state drive for scratch disk?
        Curt Y Level 7
        Chris probably has no more idea than anyone else, as it not his baby.  But, from what I have seen it takes a long time to fix bugs.  As an example we are still on virtually the same CS6 beta version that was developed in March.  All the bugs from beta testing will hopefully be fixed, but they do it on dot realeases.  We have not seen one yet.
        • 29. Re: External solid state drive for scratch disk?
        Level 7
        Sorry, there isn't much I can say.  We can't discuss unannounced versions of software.
        This is a Photoshop specific bug.
        • 30. Re: External solid state drive for scratch disk?
        carolgunn Level 1
        That's understandable, Chris. I'll take my work over to After Effects and try my luck there. Thanks for your help.
        • 31. Re: External solid state drive for scratch disk?
        Noel Carboni Level 8
        We are all anxiously awaiting 13.0.1, and by the fact that it's not being rushed out I have a lot of hope that it's going to be very good.
        -Noel
        • 32. Re: External solid state drive for scratch disk?
        Lundberg02 Level 3
        It had better be 13.1.
        • 33. Re: External solid state drive for scratch disk?
        Level 5
        Why?  Do you want to be charged extra for it?
        Look, we've had 7.0.1, 9.0.2, 10.0.1, 11.0.2, and 12.0.4.  What makes you think they'll change that pattern?
        • 34. Re: External solid state drive for scratch disk?
        Lundberg02 Level 3
        From the comments here, it needs more than a bug fix.
        • 35. Re: External solid state drive for scratch disk?
        So you're assuming there's a limit on how much they should try to fix?
        If basic advertised funcitonality in 13.0 crashes, even if it were to take a rewrite of an entire subsytem in the application and all of Adobe's resources for half a year, the fix should still come out in 13.0.something
        It's would be irresponsible and bordering on fraud that a company should let serious customer-reported bugs go unfixed for a whole version release, even if it's an in-between version.
        -Noel
        • 36. Re: External solid state drive for scratch disk?
        carolgunn Level 1
        Chris, I've just gotta say. . .
        When I saw that Photoshop CS6 Extended would allow me to "Intuitively create 3D artwork [and] animate 3D objects", I thought that would be a great way to add pizzazz to my video project without having to shell out additional money for Premiere and/or After Effects. Ordinarily I am not an early adopter, (I like to wait til they get the bugs worked out!) but I went ahead and plunked down my $400 for the upgrade.
        To hear that my constant crashes were "a bug in the 3D code that the 3D team is working on" and the fact that that I could create and animate the 3D objects, but I could not output them was extremely discouraging. I spent a solid month of of intensive study on the specific subject of 3D animation in Ps CS6 (what a waste of time that turned out to be!) and many hours troubleshooting this problem. Most importantly, I've done quite a few hours of work creating 3D animations that cannot be rendered and therefore cannot be used, leaving me with no deliverables to my client--meaning no billable hours for me.
        So, now, after spending $400 and a solid month pulling my hair out trying to figure out why this was not working, my only choice is to spend another $360 for a year of Creative Cloud, so that I can move my project to After Effects and hope that, unlike Ps CS6, it will work as advertised.
        In all fairness, the hours and hours I spent learning 3D animation in Ps may not turn out to be a total waste as it looks like some of it may be applicable to Ae. However, I've been using Adobe software every day, all day long, for the past 25 years, and I have never had an experience this disappointing. Thanks for your help, Chris. Do let me know when there is a fix for that bug, and wish me luck with After Effects.
        • 37. Re: External solid state drive for scratch disk?
        Lundberg02 Level 3
        Sounds like 13.1 to me.
        • 38. Re: External solid state drive for scratch disk?
        carolgunn Level 1
        Chris, I understand that you cannot comment on unnanounced versions of software, but can you (or anyone at Adobe) give me some idea of when this bug will be fixed--a week? a year? I desperately need this information in order to schedule my work. I hope that by now you have read my reply to your comment, dated Jul 21, detailing the loss of time and money this bug has caused me. Adobe has my $400 for the upgrade and will be getting $360 from me for Creative Cloud since Ps does not work as advertised. And what I have got? Less than nothing! If you can give me contact info for someone who can give me, at the very least, an estimate of when this bug will be fixed, please do.
        • 39. Re: External solid state drive for scratch disk?
        Level 7
        I cannot give you an estimated time because I cannot comment on unnannounced versions.
        At this point, nobody can give you an estimated time.
        1 2 Previous Next
