This question was posted in response to the following article: http://help.adobe.com/en_US/robohelp/robohtml/WSE06DA00F-6FE0-4822-9636-315A6136E522.html
Hello,
I encountered a problem with spell checking feature of Robohelp 9. I had to deliver my webhelp to client, i tried spell check option to find out spelling errors in the project, clicking the "Ignore All" for the writer terms or words, in middle of this task, by mistake i pressed "Ignore All" button for 3 to 5 misspelt words, so i closed spell check dialog and try to run it again to capture those 3 to 5 misspelt words, but Robohelp started checking from the last entry it had checked, After completing spell check for the whole project, i again tried running spell check to capture those misspelt words, but it displayed a message stating that Robohelp has completed spell check for the whole project.
So i think
Robohelp does not consider those ignored words in the past, so there should be an option to check ignored words so the user get a chance go back and retrive them
there should be a button, such as "back" or "undo" so the user can go back or undo their actions.
Achyut Walke
Hi there
If you have mistakenly added a word to the Ignore list, you are able to clear it. Click Tools > Spelling Options > Ignored Words tab. Select the word and click Delete and you should be good to go for spell check flagging it again.
Cheers... Rick
Submit your wishlist requests to https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform - the more requests they get on a specific issue, the more likely it is to be built.
