15 Replies Latest reply on Jul 21, 2012 8:01 PM by Rob Hecker2
    How Important is Code?
    bobsoriginal
      This question seems relevant. Ask how important code is to a coder and you'd get a completely different answer than if you asked the lowly graphic desinger, who gets laid off immediately after a project,- while the coder/ engineer gets the job security. The question is How Important IS Graphic Design in a code environment, (dictated by the Adobe interface)? Has design become so limited that training will now encompass coding for designers? That's the wrong side of the brain to train if you are a talented graphic designer. Ask a coder to design and you'll see the difference.
      I do have a strong willingness to learn but don't make my head explode. Make an interface that works to unravel mysteries more than what's offered in 5.5 Creative Suite. There's too much missing. Jargon abounds. Flash was a designer's dream before the Adobe strangle-hold. And what IS an Evangelist? Religiion in code? Code isn't poetry, it's a vessel for it. Visual placement of objects and animations make sense to a visual designer. Let's face it, Dreamweaver is a nightmare for a desginer trained in Flash. HTML 5 and CSS3 are alien concepts to designers. I'm taking major down-time to just try and lean simple aspects of the code. I personally like the simplicity of the Draw AP Div but it's too rigid. Improve that!
      Structure, syntax and other jargon has replaced great graphic design in the new world of Adobe's interfaces. I'd like to see a better interface to adapt and learn the code. I know it changes constantly but the animations that could be done simply in Flash are now requested in CSS3 and HTML5...it's a head explosion for this graphic designer. I miss Flash. Makes me want to go back to photography. It's very frustrating
        • 1. Re: How Important is Code?
          osgood_ Level 8
          Its very hard to cross the bridge from graphic design to web design, been there, done it and am only marginally successful. The probem is the web is a whole different medium and those that have come from a dtp background would be wise to effectively retrain if they go down the web route. Isolate what you know about garphic design into a box when you're working on web projects. Obviously you'll have some understanding of visual appeal which should help but designing for web pages needs to be approached very differently as the pages are 'living'. What I mean by 'living' is that they will take on a life of their own dependent on what device or browser setting the end user has set up. Your pages must take this into consideration to be as flexible as possible.
          Coding is very important if you want to take control of placement of your elements, without it you'll be like a fish out of water. The web is very exciting and offers much much more than a static dtp page. To me graphic design is almost akin now to a 'childs coloring in book' compared with the degree of skill you need to produce acceptable web page design.
          Yes its frustrating but you either have the desire to learn it or you don't. The most frustrating element is actually working with graphic designers, many of which have little appreciation or understanding of web development.
          • 2. Re: How Important is Code?
            bobsoriginal Level 1
            Coding as religion. The gospel according to Adobe's "Evangelists"? Follow willingly or go to hell. The questiion was irellevant (to a coder).I put up my two cents as asked...
            A 12 year-old degree would be said to be too dated- for good  job and only advanced coders deserve the good work. That's the take. Weed out all that are not up to Adobe's standards...or the supreme codemaster's expecations. Send em all back to school. I like school. My request to Adobe's "Evangelisim" would be to make the interface more stable and visually user-friendly- like Flash. Visual aids/ arts and design are good- code is alien. Unless you hold the keys to the kingdom with your code degree. Keep the code- put in better designer features and modlules for easier depoyment in rich media. Real artists either got no respect and starve or are over paid. Grapic design has become a cookie cutter for a coder. There's your coloring book. Originality will suffer and often die due to the new evangelism. I've not ever called my work evangelistic. I'm too modest. However, I am an artist, aspiring to learn...
            • 3. Re: How Important is Code?
              mytaxsite.co.uk Level 6
              Good start.  Talk less and do more coding and you will succeed.  It is often said that an empty tin makes the most noise.
              Good luck.
              • 4. Re: How Important is Code?
                Rob Hecker2 Adobe Community Professional & MVP
                It's common for one person to write code while someone else creates the design, another person writes the marketing material, etc. When you work on small scale projects where you have to wear more than one hat, well, that's just the way it goes with small operations.
                The person who makes the creative drawings for an opera set is not the same person who makes the technical drawings for the same set, though there is a great deal of overlap in their skill sets and they may both work with  Autocad or Inventor. Likewise, the web interface designer is usually not the same person who writes the business logic for the website.
                The most successful web graphic designers are those who understand the technical strengths and weaknesses of the web environment, how a webpage is different from a print piece, and how to communicate and deliver a design to the coder.  In an era no so far in the past, designers had to involve themselves in many of the technical aspects of the printing process. You could not be a successful designer if you were not intimately familiar with print technology.
                Adobe is not responsible for the fact that websites result from code and that someone has to write that  code. With Dreamweaver, Adobe gives non-technically inclined designers a set of tools for designing web pages, however, there is no escaping code.
                . . .but HTML/CSS isn't rocket science. It's not all that hard to learn, and if you are going to build web pages, then it's indispensible knowledge.
                • 5. Re: How Important is Code?
                  I used Draw AP Div to get around the alien code css. Finally had to grab on and what a difficult ride- even with DW and the tutorials. Draw AP Div is forgiving and you move it around and presto, you've got a website done a lot quicker than with the tiring and tedious code. That kind of designing is fun...or was.
                  • 6. Re: How Important is Code?
                    John Waller Adobe Community Professional & MVP
                    Forgiving in Design View perhaps but not the end results in the browsers.
                    You forgot to mention it's an easily broken website which can produce unexpected results on different devices due to the inherent behaviour and limitations of APDivs.
                    Layouts without relying on APDivs are more robust and just as easy to achieve and manipulate with a little HTML/CSS knowledge and good tools.
                    • 7. Re: How Important is Code?
                      No way. CSS is a bear by any standards. You've got lots of expertise if you
                      can do it fast. It's tedious. I've spent the entire day trying to figure
                      out why an image won't center. Is it really that important to me?
                      • 8. Re: How Important is Code?
                        I think just about anyone should be able to get a very good grasp of HTML and CSS in a week of study. They are both very limited in what they do, and they lack the complexity of programming languages like javascript, PHP, etc.
                        • 9. Re: How Important is Code?
                          Honestly? Were you just looking for a target with this thread? Don't get me
                          started. Six weeks now and I'm still struggling with it. duh. Your attitude
                          reminds me of the scenario of a stranger asking for directions from locals
                          and the last phrase "you can't miss it"
                          • 10. Re: How Important is Code?
                            You're obviously very visually inclined but CSS is certainly not that difficult to learn. Perhaps you're allowing it to get on top of you?
                            It's plain text, human readable markup with a few rules attached. Occasionally the methods and results are seemingly counter-intuitive but that's been true for me with desktop publishing software (such as InDesign) too.
                            There are plenty of tools, templates and frameworks (free and commercial) to help you produce robust and attractive CSS layouts quickly.
                            • 11. Re: How Important is Code?
                              Bobs, I realize that what's easy for one person is difficult for another, and that many people don't have an affinity for technically detailed material.
                              What I am saying is that when you look up the hill, it may look dauting, but from the top of the hill, you realize how very small it is. If you were complaining about how difficult Java or C++ are to learn, that would be a different story.
                              The truth is that even if you are having trouble getting your mind around CSS, once you get over your block, I think you will realize that it wasn't such a big deal afterall.
                              • 12. Re: How Important is Code?
                                BenPleysier Adobe Community Professional & MVP
                                This reminds me of my time in the work force many many moons ago. Working as an engineer in a domestic refrigeration production plant, our designer would come with a new design, visually pleasing, beautiful handles and practical interior. It was my task to make the thing work, pass ISO standards, produce high energy star ratings, design moulds, jigs and fixtures and ensure minimal production costs.
                                Although we had frequent discussions, the designer did not interfere with my work, nor did I interfere with his work; he designed and I made it work.
                                There is a parallel with the production of web sites. I am a hopeless designer although I do my best; I am good at web development. Although designers can bridge the gap between designing and development, the reality is that they will not.
                                Web development is not dictated by Adobe, nor is it dictated by the W3C group. There are more influential powers at work, the suppliers of the browser!
                                It is they that dictate the markup, the style rules and the server side script. Poor Adobe is trying constantly to keep up with browser development and in some cases they have even anticipated what is to come.
                                But to get back to your point, there is a lot of work involved in developing a modern web site. Think blogs, data feeds, content management, shopping carts, payment gateways, data storage, e-mail systems etc, etc.
                                There is a common Dutch saying: "Schoenmaker, blijf bij je leest", or translated "Cobbler, stay with your last"
                                Gramps
                                • 13. Re: How Important is Code?
                                  MurraySummers Level 8
                                  And in the case of this quote, "last" refers to the shoe leather!
                                  Without at least a rudimentary understanding of code (HTML and CSS), you will never succeed in web development.  Never.  Your designs will break unexpectedly, and you will spend untold frustrating hours trying to get some pixel-perfect arrangement on the screen, only to find that some other browser displays it differently.  To think otherwise is delusion....
                                  • 14. Re: How Important is Code?
                                    Well said. I'd done many of those tasks...etc etc...right...coma inducing complexities abound. Too tiring to even try to write it all down. In 2000, when I got my MM degree, I interned for a MM company that was doing work for the Navy through Raetheon. Miltary and governmental work has all the money (go figure). I went to my first brainstorming session with the SME (subject matter experts) and engineers all at a table. I listened quietly to all the thoughts on presentation, with ideas on each principle that needed to be addressed from a graphic standpoint. My asset is crativity. When I was encouraged to speak my mind, I was shot down on every idea by the engineers- saying it couldn't be done. To prove my point, that week I proved that all my ideas were worthy. All 5 ideas were presentable in Flash. Each idea, though critiqued within the political atmosphere (Dilbert mentality), were accepted and deployed.
                                    I liked the way that code and gui were separated into two departments within multimedia business models- 12 years ago. As a web designer, you must be able to pick the client's brain and broadcast the knowledge of his trade effectively, creatively, dramaticly and professionally. Then there's all the alternative methods of web presentations that must be addressed (mentioned above)... Pickin brains is the fun fun part. You learn and achive success by your translation of the data into a pleasing media format. I found myself again, now, after a long break from the complexities referred to above, with the website design hat back on again. No one was using CSS 12 years ago (I didn't have time to learn it, I had to learn ASP and other technologies). Today I remain independent- minus the office politics. I miss the team- player segregatiion of engineers and graphic designers. Life was easier then, with less stress. Dependence on the code side of my brain has atrophied some. My expertise in Flash had made me more valuable because of it's code related goodies and the incredible animations / presentations. I was called a guru (another religious connotation) NOT. Years later, after trying on different hats of networking, surveillance cameras, T-shirt design and printing, and a few website designs- here I am again asking myself if I have the mental stamina to do the code. To make it fun is the first task. I've not found the right way to do that yet. I went out and got 3 jobs and then got back aboard. To complete my first shopping cart project on time, I had to revert to some of the old school tactics.(draw ap div) ....then I had to go back and redo it. This code is a killer. Specialize in one thing...code may not be it for me. The importance looms.
                                    • 15. Re: How Important is Code?
                                      I think even Hunter S. Thompson would call your last rambling post strange.
                                      Best of luck to you in your endeavors.
