"You may be lucky and never have another problem." Yeah
right, and the Pope will be preaching at the Synagogue in future.
You and Colum are both right. Word is easy to use but that is
in the context of using for its intended purpose, producing
documents. When it comes to producing HTML it is in a class of its
own for causing problems. If you save a Word document in HTML
format and then open it in something that counts the lines, there
will be a given number of lines. Put that code through something
that removes the unnecessary garbage and you will have an
unbelievably smaller number of lines, but still with the capability
of messing up your output.
If it your requirements are straightforward, then it may work
for you but remember this post if you do hit problems.
Take a look at some of the topics on my site if you want
further information on this.
Please don't think we are trying to knock what you are doing.
We are trying to help by pointing out that your chosen method is
likely to cause problems.
