1. Re: CS2 file opens in CS5.5 with inaddressable spaces
BobLevine Jul 22, 2012 2:23 PM (in response to cyberbaffled)Please post a screenshot. I have no idea what inaddressable spaces are.
Bob
2. Re: CS2 file opens in CS5.5 with inaddressable spaces
cyberbaffled Jul 22, 2012 3:42 PM (in response to BobLevine)What I mean by "inaddressable" spaces is large white-space in a block of text. It's as if the empty space after a paragraph had been set to be inches wide.
3. Re: CS2 file opens in CS5.5 with inaddressable spaces
P Spier Jul 22, 2012 3:46 PM (in response to cyberbaffled)What is the vertical justification setting in the text frame options?
4. Re: CS2 file opens in CS5.5 with inaddressable spaces
cyberbaffled Jul 22, 2012 4:28 PM (in response to P Spier)Align: top Paragraph Spacing Limit: grayed out
5. Re: CS2 file opens in CS5.5 with inaddressable spaces
cyberbaffled Jul 22, 2012 4:31 PM (in response to cyberbaffled)Incidently, I'll add this fact. The ID CS2 file saves as CS5.5 without any distortions such as I've described. However, when I attempt to change that resulting saved text, huge white-space ellipsie immediately form.
6. Re: CS2 file opens in CS5.5 with inaddressable spaces
P Spier Jul 22, 2012 5:08 PM (in response to cyberbaffled)If you still have CS2 available, export the file to .inx and try opeing that in CS5, otherwise export to .idml from CS5 and open that.
7. Re: CS2 file opens in CS5.5 with inaddressable spaces
cyberbaffled Jul 22, 2012 9:25 PM (in response to P Spier)Thanks greatly for the idea. Tomorrow, 7-23, I'll try to resurrect my CS 2 and attempt the two procedures.
8. Re: CS2 file opens in CS5.5 with inaddressable spaces
cyberbaffled Jul 25, 2012 10:24 AM (in response to P Spier)I installed my ancient CS2 Indesign and when I attempt to open a file created seven years ago therewith I'm prompted that a variety of snap-ons are missing. I've copied screen shots of the prompts below. Where can I find these snap-ons? I only installed CS2 Indesign. If I'd have installed everything, would that have picked up the missing snap-ons? I'm posting this issue in this forum as an independent question. If you don't know the answer maybe Bob Levine will. The second image below is a scroll view from which I've only copied the top of the scroll.
9. Re: CS2 file opens in CS5.5 with inaddressable spaces
BobLevine Jul 25, 2012 10:36 AM (in response to cyberbaffled)Those ARE NOT CS2 files. The worldready composer was introduced in CS4.
Bob
