1 Reply Latest reply on Jul 23, 2012 10:16 AM by Charlie Arehart
    Installing the Server Configuration
    community help Level 1
        • 1. Re:  Installing the Server Configuration
          Charlie Arehart Adobe Community Professional & MVP
          This isn't critical, but it would be could to get corrected.
          In the discussion of the built-in web server above, the code fragment for the XML entry (to be commented or uncommented, to disable/enable the built-in web server) mistakenly shows the PROTOCOL attribute having a value of
          org.apache.coyote.http11.Http11NioProtocol. While that is indeed a valid value, the value that comes in a default CF10 configuration is instead org.apache.coyote.http11.Http11Protocol. It just seems that perhaps this doc was written at a time when that other Tomcat connector was being considered.
          The doc should be changed to reflect the correct "current" connector protocol that's used in default configuration of CF10.
