I have a text field that gets populated dynamically. If the populated text doesn't fit in the text field, the text gets resized. HTML tags work correctly in the dynamically populated text, but only if the text doesn't get resized. HTML tags are completely ignored in resized text. Any ideas?
Code to format the text field:
import flash.text.TextFormat;
import flash.text.Font;
function setDesc(str:String):void{
var fmtD:TextFormat;
var cfmtD:TextFormat = this.desc_txt.getTextFormat()==null ? this.desc_text.defaultTextFormat : this.desc_txt.getTextFormat();
var sizeD:int = 22;
desc_txt.htmlText = str;
while (sizeD>10 && sizeD<23 && desc_txt.textHeight>255){
sizeD--;
fmtD = new TextFormat(descFont.fontName,sizeD,0x000000,false,false,false);
desc_txt.htmlText str;
desc_txt.setTextFormat(fmtD);
Code to populate the text field:
function openDialog(e:MouseEvent){
dialog_window.doOpen();
switch(e.currentTarget.name){
case "btn_structure":
dialog_window.setTitle("Title #1 Goes Here");
dialog_window.setDesc("Topic description goes here.");
break;
case "btn_services":
dialog_window.setTitle("Title #2 Goes Here");
dialog_window.setDesc("<b>Topic</b> description goes <i>here</i>.");
break;
The message you sent requires that you verify that you
are a real live human being and not a spam source.
To complete this verification, simply reply to this message and leave
the subject line intact or click the link below:
http://www.solutionvix.com/cgi-sys/bxd.cgi?a=jeferson@solutionvix.com&id=b9rQp4Knw4ilGW7h1cmwr-1343061234
The headers of the message sent from your address are shown below:
From forums@adobe.com Mon Jul 23 11:33:54 2012
Received: from mail.sgaur.hosted.jivesoftware.com (:6927 helo=mx-out4.sgvm2hosted.jiveland.com)
by lagonda.websitewelcome.com with esmtps (TLSv1:AES256-SHA:256)
(Exim 4.77)
(envelope-from <forums@adobe.com>)
id 1StLZy-0008WD-EN
for jeferson@solutionvix.com; Mon, 23 Jul 2012 11:33:54 -0500
Received: from adobe-vm-wa05.sgvm2hosted.jiveland.com (unknown )
by mx-out4.sgvm2hosted.jiveland.com (Postfix) with ESMTP id 0921E600049
for <jeferson@solutionvix.com>; Mon, 23 Jul 2012 10:33:53 -0600 (MDT)
Date: Mon, 23 Jul 2012 10:33:52 -0600
I wrote this and it works, maybe this will help:
var txt:TextField = new TextField();
txt.width = stage.stageWidth;
txt.height = stage.stageHeight;
txt.multiline = true;
var format:TextFormat = new TextFormat();
format.size = 20;
txt.defaultTextFormat = format;
addChild(txt);
var str:String = "here <br> <b> are </b> <br> some <br> html <br> <i> tags </i>";
txt.htmlText = str;
//stop the script here and the font size is 20.
function resizeText(o:TextField, size:int):void
var newFormat:TextFormat = new TextFormat();
newFormat.size = size;
o.setTextFormat(newFormat);
resizeText(txt, 12);
//stop the script here and the font size is 12.
Solution found on another forum:
var desc_txt:TextField = new TextField(); addChild(desc_txt);
var sizeD:uint=22;
fmtD = new TextForm(descFont.fontName,sizeD,0x000000,false,false,false);
desc_txt.width=455.50;
desc_txt.height=263;
desc_txt.x=17.50;
desc_txt.y=61.20;
desc_txt.wordWrap=true;
desc_txt.defaultTextFormat=fmtD;
desc_txt.htmlText=str;
while(sizeD>10 && sizeD<23 && desc_txt.textHeight>255){
sizeD--;
fmtD=new TextFormat(descFont.fontName,sizeD,0x000000,false,false,false);
desc_txt.htmlText=str:
