Hi all
I am trying to import a flash swf animation into captivate 5.5. I figured it should be straight forward by going Insert > Animation, but the animation doesn't do what it is meant to. I think this is because the swf file is associated with a number of images, audios and an xml file. I thought if I got all the files into the Captivate library it might work, but I've only been able to import the images and audio not the xml file (Import > XML tells me Captivate can't import xml). I'm not sure what to do to get the animation playing.
Any responses appreciated.
Thanks Peter
Hi Peter,
Importing an animation that has certain required files like graphics and aurido and XMl scattered would not work if each broght sepeartely to library, what is assumed while you do Insert--Animation is that the animation has all the required components embedded in itself.
seo, you can check of the source file can be modified to produce a single flash file that has all required assets embedded in itself.
Anjaneai
