I downloaded the Flash Builder 4.5 Premium trial and packaged it up with Application Manager Enterprise 2 (I included my serial number, unselected AIR for Apple iOS, and let it apply the 4.5.1 patch). When running the resulting package, I get the message:
"The FlashBuilder executable launcher was unable to locate its companion shared library."
I see that three times, and then the installer seems to finish. I need this resolved, though, as I'm packaged an unattended installer, and this message seems to stop the install process until it's told "OK" the three times.
I rolled this again, this time leaving AIR in and not adding the update. I get the same message, three times.
I encountered the same prompt too, so how did you solve it, Mr jnojr ?
I encountered also a problem with starting up Flash builder premium 4.6.
Adobe Flash builder unfortunately searces for a eclipse plugin in the following directory.
C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\eclipse\plugins\com.adobe.flexbuilder.ui_4.6.1.335153/welcom/index.html?firstLaunch=false&edition=prem&version=460…
I guess the program can't find the startup page, but it already is loaded. Could it be that the program is looking for a deleted file, which I did.
Look forward to hear some solution.
Ed Boon
visioned.nl
I'm experiencing the same problem as visioned, but I'm on a Mac. I believe this is the first time I've attempted to open Flash Builder 4.6 since I upgraded my laptop a couple of weeks ago. Do I have to reinstall Flash Builder, or is there some file I can replace or link I can fix?
