Toggle function
Participant ,
Jul 24, 2012 Jul 24, 2012
I am using one interface the stage size is 1067 x 600 inside that by using one movieclip am loading the animation files the animation file size is 972.2 x 516.1.i am using one toggle button, when i click toggle button only the animation should be visible that should be in full screen.can any one tell me how to do that.
ActionScript
1.4K
Contributor ,
You can resize your loaded animated file to stage size as follows:
loader.contentLoaderInfo.addEventListener(Event.COMPLETE,loadComplete);      //Here loader is an instance of Loader to load the animated file.
function loadComplete(e:Event):void
     loader.content.your animated content.width = 1067;
     loader.content.your animated content.height = 600;
                              or
     e.currentTarget.content.your animated content.width = 1067;
     e.currentTarget.content.your animated content.height = 600;
//Here your animated content means, animated content should be placed on a particular movieclip which has provided by name. You can access that movieclip by
getChildByName("name") in the place of your animated content in the above code.
Participant ,
I am not able to access the moviclip name
Contributor ,
loader.content means application's main timeline. Once check you have any parent objects for that movieclip. and also check where you place the movieclip according to the main timeline.
Participant ,
my movieclip is in main timeline that i placed in the top right corner of the stage
Contributor ,
Jul 25, 2012 Jul 25, 2012
use
DisplayObject(loader.content).your movieclip instance name
Participant ,
still i am getting the same error
Contributor ,
what is that error?
Participant ,
Scene 1, Layer 'Layer 2', Frame 1, Line 291119: Access of possibly undefined property container through a reference with static type flash.display:DisplayObject.
here container is the moviclip name
Contributor ,
If you really place it on the stage and give it an instance name, the above code is working fine.
Once check with trace statement
trace(loader.content.movieclipname);
If it is undefined means check with your file.
I have one doubt. Here your animation file means, you are trying to load an swf file which contains animation or something else?
If my guess is right (if it is swf)  the above code is apt for your program.
