Locked
1
Document setup bleed lines absent
Jul 24, 2012 Jul 24, 2012
I'm setting up the bleed on a set of InDesign CS5.5 documents. When I go to File: Document Setup: More Options, and set the bleed to .125 in, I don't see the little red bleed guide line outside my document outline. I've gone to InDesign: Preferences: Guides and Pasteboard, where I found there is an entry for the bleed guide. I can make guides just fine, I just can't get the bleed guide to show up on my pasteboard anymore.
All clues welcome.
Thanks.
--jody.
How to
111.9K
Community Expert , Jul 24, 2012 Jul 24, 2012
You see other guides, but not the bleed guide?
Can you show us a screen shot?
Guide previews were turned off. I was able to turn them back on, and thus can now see the bleed guides.
Sep 06, 2012 Sep 06, 2012
Having the same problem.  Where is the "guide previews" setting?  What did you do to turn them back on?  Anything special?  thanx!
The show/hide guides commands have moved around a bit from versiontoe version, I think, but they shoud still be someplace in the View Menu whatever version you might have. They will not be visible, however, in Preview mode (the pasteboard will also disappear).
Excellent!! Thanx!! CS5.5 BTW
Apr 02, 2020 Apr 02, 2020
Helped me in 2020 (:
Contributor ,
Let's start here:
Do you have the pasteboard area on (hit: w)
If it does not show, you may need to trash your preferences.
Participant ,
Jan 23, 2014 Jan 23, 2014
to show guides (bleed, margins) hit ctrl+ ; for windows (you could have mentioned that)
Jul 11, 2014 Jul 11, 2014
One good reply, thanks
Sep 01, 2015 Sep 01, 2015
Excellent reply Brother.\m/
Participant ,
Mar 27, 2017 Mar 27, 2017
ID CC 2017 is creating this problem. My guides are not hidden, they simply are not showing.
Aug 17, 2017 Aug 17, 2017
This was helpful, however didn't solve my problem. I had to go to View > Screen Mode > Normal
Nov 06, 2017 Nov 06, 2017
I had this problem too; using the latest version ID CC 2018.  I found that if my bleed AND slug were set to the same value, the guide color would show for the slug....therefore I thought my bleed lines(set to fiery red in my preferences) were not showing up.  I changed the bleed amount..and magically my red bleed lines appeared
