33 Replies Latest reply on Oct 6, 2015 4:20 AM by peterv40396918
    PS CS6 action save for web error
    venkatl
      In Photoshop CS6 actions when we save the image as JPEG through save for web it doesn't work when we run it, instead it runs and saves the image as HTML, i guess some error in it. I tried it again and again but it doesn't remember my save for web settings and saves the images as HTML.
        • 1. Re: PS CS6 action save for web error
          c.pfaffenbichler Level 9
          And if you rename the files afterwards?
          • 2. Re: PS CS6 action save for web error
            venkatl Level 1
            If I rename the HTML extension to JPG then the pictures shows, So I tried again to check what extension its taking and I found the format selected as "Images Only" then also its generating HTML extension for the JPEG images.
            I guess its a bug.
            • 3. Re: PS CS6 action save for web error
              JJMack Most Valuable Participant
              Can you save the Action set and upload it to someplace we can download it and look at the actions something may be recorded badly.
              • 4. Re: PS CS6 action save for web error
                venkatl Level 1
                Hi JJMack
                I have saved the action set at the following URL please download and check.
                https://www.yousendit.com/download/QlVqUWVvNHZubHljZDhUQw
                • 5. Re: PS CS6 action save for web error
                  It a new bug in CS6 though when you recorded the action you saved jpeg images to you desktop and you only entered file names onto the save for web action steps the action recorder recorded name.html.  I replaced you save for web steps on my machine for my desktop and CS6 recorded  name.html.  I then did the same with CS5 though I only entered names CS5 recorded name.jpg.
                  If you expand the export steps tou will see the hard coded file names and extention
                  An action like this will always save the same files it can not be batch because you recorded Path and Names in the save for web steps.  The .html files saved on with CS6 are actually jpeg files and if you rename them hrom name.html to name.jpg you can use them,
                  Set: cropping
                            Action: story sizes
                                      Levels
                                                Preset Kind: Custom
                                                Adjustment: levels adjustment list
                                                levels adjustment
                                                Channel: composite channel
                                                Input: 0, 245
                                                Gamma: 1.14
                                      Image Size
                                                Width: 660 pixels
                                                With Scale Styles
                                                With Constrain Proportions
                                                Interpolation: bicubic automatic
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                In: C:\Users\venkatr\Desktop\
                                                Custom File Name:  “_660.html”   <----CS6 problem  recording - CS5 records "_660.jpg on my machine
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                Quality Modification Channel Strength: 0
                                                Without Quality Channel Text Layers
                                                Without Quality Channel Vector Layers
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                Without Embed ICC Profile
                                                With Matte
                                                Matte Color Red: 255
                                                Matte Color Green: 255
                                                Matte Color Blue: 255
                                                Without Save HTML File
                                                With Save Image Files
                                                Slices: All Slices
                                                Color Handling: Convert to sRGB
                                                Metadata: None
                                                Without Output XHTML
                                                With Include Comments
                                                With Always Add Alt Attribute
                                                With Always Quote Attributes
                                                Without Close All Tags
                                                With Include Zero Margins on Body Tag
                                                HTML Tags Case: Lowercase
                                                HTML Attribute Case: Lowercase
                                                HTML Indent: -1
                                                HTML Line Endings: Automatic
                                                <unknown>
                                                Without Generate CSS
                                                Empty Cells: GIF, IMG WH
                                                TD WH: Auto
                                                Vertical Spacer Cells: Auto (Bottom/Right)
                                                Horizontal Spacer Cells: Auto (Bottom/Right)
                                                Slice Name Components: Filename Component list
                                                Filename Component
                                                Filename Component Type: doc. name
                                                Filename Component
                                                Filename Component Type: underscore
                                                Filename Component
                                                Filename Component Type: layer name or slice no.
                                                Filename Component
                                                Filename Component Type: none
                                                Filename Component
                                                Filename Component
                                                Without View As Background
                                                Background Image Path:  “”
                                                Background Color Type: Matte
                                                File Name Components: Filename Component list
                                                Filename Component
                                                Filename Component Type: slice name
                                                Filename Component
                                                Filename Component Type: hyphen
                                                Filename Component
                                                Filename Component Type: trigger name
                                                Filename Component
                                                Filename Component
                                                Filename Component Type: rollover state
                                                Filename Component
                                                ...3 More
                                                Without Mac OS 9 Filename Compatibility
                                                With Windows Filename Compatibility
                                                With Unix Filename Compatibility
                                                With Use Images Subfolder
                                                With Copy Background Image when Saving
                                                Images Subfolder Path:  “images”
                                      Select previous history state
                                      Crop
                                                To: rectangle
                                                Top: 111.4 pixels
                                                Left: 142.2 pixels
                                                Bottom: 2342.6 pixels
                                                Right: 3613.1 pixels
                                                Angle: 0°
                                                Without Delete Cropped Pixels
                                                <unknown>
                                                Target Width: 350 pixels
                                                Target Height: 225 pixels
                                                Target Resolution: 0 per inch
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                Custom File Name:  “_350.html”
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                With Matte
                                                Slices: All Slices
                                                Metadata: None
                                                HTML Indent: -1
                                                <unknown>
                                                TD WH: Auto
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                ...3 More
                                      Crop
                                                To: rectangle
                                                Top: 0 pixels
                                                Left: 529.1 pixels
                                                Bottom: 2730 pixels
                                                Right: 2869.1 pixels
                                                Angle: 0°
                                                <unknown>
                                                Target Width: 300 pixels
                                                Target Height: 350 pixels
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                Custom File Name:  “_300.html”
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                With Matte
                                                Slices: All Slices
                                                Metadata: None
                                                HTML Indent: -1
                                                <unknown>
                                                TD WH: Auto
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                ...3 More
                                      Crop
                                                To: rectangle
                                                Top: 136.5 pixels
                                                Left: 325.7 pixels
                                                Bottom: 2359.2 pixels
                                                Right: 3295.2 pixels
                                                Angle: 0°
                                                <unknown>
                                                Target Width: 167 pixels
                                                Target Height: 125 pixels
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                Custom File Name:  “_167.html”
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                With Matte
                                                Slices: All Slices
                                                Metadata: None
                                                HTML Indent: -1
                                                <unknown>
                                                TD WH: Auto
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                ...3 More
                                      Crop
                                                To: rectangle
                                                Top: 225.1 pixels
                                                Left: 1318.4 pixels
                                                Bottom: 1858.5 pixels
                                                Right: 3496.2 pixels
                                                Angle: 0°
                                                <unknown>
                                                Target Width: 88 pixels
                                                Target Height: 66 pixels
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                Custom File Name:  “_88.html”
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                With Matte
                                                Slices: All Slices
                                                Metadata: None
