Assigning Advanced Action on Slide Entry
Guest
Jul 24, 2012 Jul 24, 2012
Hi folks,
Is there anyway to assign/execute an advanced action upon a slide entry, without having to click a click box or other similar action?
I created a practice exercise, in which the user performs several steps in a software app. Each step is worth an amount of points, 4 if done without a hint or help, 2 is only hint or help is used, and 0 points if the user uses both hint and help.   There is a summary page that tells the user their score, and I want to use different feedback, depending on the score.
After the last step performed by the user, the summary page displays, but I want the score and corresponding feedback to appear automatically, witout any user interaction.  Can this be done?
Thanks in advance..
Steve
Advanced
830
Community Expert , Jul 24, 2012 Jul 24, 2012
Perhaps my presentation (DevLearn 11) or the webinar (available on Demand) I gave a while ago would be interesting to you? Could give you the links.
There are several kind of events that can trigger advanced actions:
  • Slide events for normal slides: both on Enter and on Exit, see the Properties panel, Action accordion. I do not recommend using the On Exit event unless you are sure that the last frame of the slide will indeed be visited, which is not the case if you have an interactive object that j
  • Slide events for normal slides: both on Enter and on Exit, see the Properties panel, Action accordion. I do not recommend using the On Exit event unless you are sure that the last frame of the slide will indeed be visited, which is not the case if you have an interactive object that jumps to somewhere in the project.
  • On Enter event for Question slides; they do not have an On Exit event, because that is replaced by Success/Last attempt events, depending on the correctness of the answer
  • Success/Failure events for interactive objects (Button, Click Box, Text Entry Box)
  • Rollover and On Click event for slidelet
So in your case, create the 'calculation' advanced action on Entering the score page.
Lilybiri
Guest
Jul 25, 2012 Jul 25, 2012
Hi Lilybiri
Your advice was spot on…
I now have exactly the function I need.
Steve
Is your question answered?
Guest
Yes. Thank you so much.
Jul 26, 2012 Jul 26, 2012
Thread is still marked as unanswered, that is why I asked what you were still expecting from other users?
Help resources
