Hello.
I recently purchased a Dell Inspiron 15R special edition laptop, and was provided with a copy of Adobe Premier Elements 9. However, whenever I attempt to use PRE, it asks me to select my country/region.
Normally, this would not be an issue, but the country/region selector drop down menu is completely blank and does not change when I click on it.
Is there a way I could fix this problem?
Thank you.
It might possibly have something to do with your DPI setting. If you go to Start>Control Panels>Display and select the Set custom text size what is it set too? Please try setting it for 100% and see if you continue to face the same difficulty.
Thank you so much, Jeff. I tried setting the font size at 100% and the problem was resolved.
Excellent thank you for the update Qsawatsky!
Interesting - I had a similar issue with Elements 10. I was told by Adobe Support to:
It worked!
