I've been using fb 4.6 premium for a while and everything works fine. Then 2 days ago it started crashing every time I tried to start it up, and it always crashes when the message "loading workbench" appears at the splash screen. The .log recorded the following:
!ENTRY org.eclipse.ui 2 0 2012-06-13 18:24:12.943
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2012-06-13 18:24:12.943
!MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
!ENTRY org.eclipse.core.net 1 0 2012-06-13 18:24:13.845
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
Can anyone decipher what's going on and how to fix it? Thanks!
Please try below workaround:
Workaround:
Can you tell the OS FB installed on?
Have you tried Flash Builder pointing to a new wokspace?
I'm using OS X 10.7.4, and I've tried to change the workspace path by setting the SHOW_WORKSPACE_SELECTION_DIALOG to true in the org.eclipse.ui.ide.prefs file in order to select different workspace path, but fb still crashes.
I now suspect it has something to do with Apple's recent java update, as the same version fb on my MBP now also crashes on every startup. The crashes started to happen right after the update.
Any suggestions or workarounds? Is it possible to revert OSX's java to an earlier version?
Message was edited by: lawrencem49
I'm experiencing exactly the same problem on OSX 10.6.8.
Edited to add:
Tried to run program as admin
sudo Adobe\ Flash\ Builder\ 4.6.app/Contents/MacOS/Adobe\ Flash\ Builder\ 4.6
And got the following to terminal:
org.eclipse.m2e.logback.configuration: The org.eclipse.m2e.logback.configuration bundle was activated before the state location was initialized. Will retry after the state location is initialized.
org.eclipse.m2e.logback.configuration: Logback config file: /Flash Builder Projects/.metadata/.plugins/org.eclipse.m2e.logback.configuration/logback.1.0.0.20110607-2117.xml
org.eclipse.m2e.logback.configuration: Initializing logback
org.eclipse.m2e.logback.configuration: eclipse.consoleLog=true
!SESSION 2012-06-15 13:34:41.791 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_33
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments: -keyring /Users/myusername/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86 -keyring /Users/myusername/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.ui 2 0 2012-06-15 13:34:46.628
!SUBENTRY 1 org.eclipse.ui 2 0 2012-06-15 13:34:46.628
!ENTRY org.eclipse.core.net 1 0 2012-06-15 13:34:48.146
Exception in thread "Thread-1" org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4282)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Widget.error(Widget.java:774)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:661)
at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:611)
at org.eclipse.swt.widgets.Shell.windowWillClose(Shell.java:2261)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5445)
at org.eclipse.equinox.launcher.JNIBridge._takedown_splash(Native Method)
at org.eclipse.equinox.launcher.JNIBridge.takeDownSplash(JNIBridge.java:167)
at org.eclipse.equinox.launcher.Main.takeDownSplash(Main.java:2050)
at org.eclipse.equinox.launcher.Main$SplashHandler.run(Main.java:111)
Message was edited by: j@rkko Reinstalling with all preferences removed did not help.
Got the SAME PROBLEM. I anyone got a solution for this?
Just a question to Adobe: Is the FB 4.6 which is included in CS6 MC a different one, than the one you can download as a trial version ? Because after removing my MC and only installing this Trial Version, it is working. Reinstalling the one included in the MC did not have any effect.
I also am getting this exact same error starting from cmd line.. Anyone have any solutions yet? :-(:
!ENTRY org.eclipse.ui 2 0 2012-06-20 10:08:10.634
!SUBENTRY 1 org.eclipse.ui 2 0 2012-06-20 10:08:10.634
!ENTRY org.eclipse.core.net 1 0 2012-06-20 10:08:11.818
Is your FB part of CS6 MasterCollection ????
Yes!
Still haven't solved this.. 2 whole days with no FB6..
Lion 10.7.4
Java SE 6 1.6.0_33-b03-424
Flash Builder 6 from CS6 MasterCollection (I had installed all the updates and preferences but then did a fresh install and no dice.. same result)
This started happening after I updated Java..
If your FB is a part of CS, then uninstall the Flash Builder, and download a seperate FB installer from http://www.adobe.com/cfusion/tdrc/index.cfm?product=flash_builder
Install it as a trial, if that makes a difference you can activate it with your CS serial key.
Hi Fahad,
I'm having the same issue--Flash Builder gets to the Loading Workbench stage, then immediately exits. I'm running Mac OS 10.7.4 with FB part of CS6 Master Collection, and this began happening right after the Java update from Apple that happened on June 19.
I have tried the following:
None of these things have worked. Please advise.
Hi Fahad,
I uninstalled (removed preferences) and then installed as trial from the link and same result.. slightly more verbose message when starting from cmd line tho:
org.eclipse.m2e.logback.configuration: Logback config file: /Users/myuser/Documents/Adobe Flash Builder 4.6/.metadata/.plugins/org.eclipse.m2e.logback.configuration/logback.1.0.0.20110607-2117.xml
!SESSION 2012-06-20 17:39:32.745 -----------------------------------------------
Framework arguments: -keyring /Users/myuser/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86 -keyring /Users/myuser/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.ui 2 0 2012-06-20 17:39:34.798
!SUBENTRY 1 org.eclipse.ui 2 0 2012-06-20 17:39:34.798
!ENTRY org.eclipse.core.net 1 0 2012-06-20 17:39:35.997
Hi Fahad,
Uninstalled FB 4.6 from MC. Re-install FB 4.6 from direct download as trial. Still doesn't work. Here's the log:
Framework arguments: -keyring /Users/lawrencem/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86 -keyring /Users/lawrencem/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.ui 2 0 2012-06-21 12:36:37.451
!SUBENTRY 1 org.eclipse.ui 2 0 2012-06-21 12:36:37.451
!ENTRY org.eclipse.core.net 1 0 2012-06-21 12:36:39.189
For me, it worked.
Uninstalled CS6 MC and removed all prefs, installed the Trial FB and then reinstalled MC WITHOUT FB and iOS Support.
I am having the same problem. I have MC CS6 and Adobe Flash builder quit starting 2 day ago. Uninstalling and re-installing did not work. OS X 10.7.4.
--rayne
Where is Adobe with a solution to this?! I simply don't have time to spend an hour every morning uninstalling and reinstalling Flash Builder. These are supposedly professional tools. Why the bloody hell do they run it like it's amateur hour?
I Don't have time to uninstall all of CS6, have to keep working.. I guess I'll have to switch to the free version of FDT or IntelliJ until this is sorted out??
Anyone figured this out yet? 3 days of no FB6 and counting.. damn..
I do have the same problem. I am trying everything since 2 days, but without any success.
Uninstalling and reinstalling from the website as trial, to a different location, didn't help, too.
Flash Builder 4.6 still quits after showing the splash.
SYSTEM.LOG
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.swt.SWT.error(SWT.java:4282)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.swt.SWT.error(SWT.java:4197)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.swt.SWT.error(SWT.java:4168)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.swt.widgets.Widget.error(Widget.java:774)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.swt.widgets.Widget.dispose(Widget.java:661)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:611)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.swt.widgets.Shell.windowWillClose(Shell.java:2261)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.swt.widgets.Display.windowProc(Display.java:5445)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.equinox.launcher.JNIBridge._takedown_splash(Native Method)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.equinox.launcher.JNIBridge.takeDownSplash(JNIBridge.java:167)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.equinox.launcher.Main.takeDownSplash(Main.java:2050)
Jul 23 10:14:29 mario [0x0-0x30030].org.eclipse.eclipse[583]: at org.eclipse.equinox.launcher.Main$SplashHandler.run(Main.java:111)
I am losing a lot of time. Even worse, I can't continue to work on important projects.
System:
OS X 10.7.4
Adobe Master Collection CS6
Flash Builder 4.6 (dead now)
It startet out of the blue. I did not install any updates. Flash Builder just stopped working one day.
There is only one thing that I can imagine that may have had an impact. I made a backup with Time Machine. That day the problem occured. Anyone with a similar situation?
After several restarts, installing and uninstalling trial from website and FB from CS6 … finally:
FB 4.6 works as expected.
I have no clue why, but I'm just happy to be able to work again.
Good luck to the rest of you (nerved users)!
@Adobe: Please, fix it! Thx.
If I uninstall and reinstall (takes just over an hour) it will run again but only once. If I close the program I will have to reinstall it before it will run again.
I just spent over and hour and a half on the phone with adobe technical support. They offer no solutions and tell me I must pay for a technical support contract before they will discuss it with me any further.
This is an outrage. SImply paying for the software should be enough for it to work. Given the number of people across the net complaining about this exact same thing it is obviously a problem with FB.
So how about it Adobe when will you fix this obvious bug? Why should there be one price for the software, and a second price for it to actually work?
Hi Darth,rayne
Please provide us the amt3.log file and oobelib.log file. They are in /tmp folder. If you couldnot attach here, please mail me at mchoudhaATadobeDOTcom
-Mugdha
Hi All,
I am posting script for collecting OOBE specific log on mac below.
#!/bin/bash
echo "OOBE Logs will be collected in OOBELogs folder created on Desktop"
cd ~/Desktop/
mkdir OOBELogs
cd OOBELogs
mkdir Logs
cd logs
cp /tmp/oobelib.log oobelib.log
cp /tmp/swtag.log swtag.log
cp /tmp/amt3.log amt3.log
cp /tmp/aul.log aul.log
cp /tmp/OOBE.log OOBE.log
cp /library/logs/Adobe/Installers/*.* .
cp -r ~/Library/Logs/PDApp.log PDApp.log
cd ..
cp -r "/library/Application Support/Adobe/adobe pcd/" ./PCD/
cp -r "/library/Application Support/Adobe/caps/" ./CAPS
cp -r "/library/Application Support/Adobe/PCF/" ./PCF
cp -r "/library/Application Support/Adobe/SLCache/" ./SLCache
cp -r ~/Library/Application\ Support/Adobe/AAMUpdater/ ./AAMUpdater/
system_profiler >SystemInformation.txt
cd ../
tar -cvf OOBELogs.tgz OOBELogs
/Users/labuser/Library/Logs
Please follow below mentioned steps to use it
1. Open the terminal and change the working directory to Desktop using 'cd' command
2. Then enter vi logcollector.command on terminal.
3. Copy and paste the above written script. Further press Esc key then :wq for saving and quitting.
4. logcollector.command will be created on the desktop. Please run it. "OOBELogs" folder will be created on desktop. It contains all the logs.
Please attach those logs here in forum or mail me at mchoudhaATadobeDOTcom after compressing
Have a look at the known issues of Flash Builder on Mac
http://helpx.adobe.com/x-productkb/global/known-issues-mac-os-10.html
As mentioned there, have you tried it by installing 32 bit JVM?
I have 32 bit and 64 bit JVM installed..
