Good Morning Everyone,
I tried to create JSON using webapp list layout. My list layout looks like:
{"item_logoagenzia":"{tag_logo agenzia_value}", "item_description":"{tag_description, 100}"}
That only renders the characters, that is the nature of using the ,100 not JSON problem either. Make a multiline custom field if you want a chunk of text and wrap it in your own p.
Issues your showing are not JSON format, just way things work.
That is just scripting.
You either have to regexp to break out or you use " ' so if quotes are inside then you use single outside.
Take when you set the HTML of an element in jquery as an example...
$(".something").html('<div Id="thisid"><\div>'):
Thanks Liam but the problem is not only with double qoutes if some one input a paragraph tag webapp's descriptiong area ... {tag_description, 100} renders it as linebreak and it also cuased to make JSON invalid.
