Show 4 replies
1. Re: Geen line appears at bottom of MP4s at 720x486
joe bloe premiere Jul 27, 2012 9:12 AM (in response to dstack1014) -
2. Re: Geen line appears at bottom of MP4s at 720x486
JSS1138 Jul 27, 2012 9:13 AM (in response to dstack1014)our programs specs requires 720x486
That's unfortunate, because that is almost certainly the cause of the green line.
MPEG codecs work best when the dimensions are evenly divisible by 8. I bet if you went to 488 or 480, that line would go away.
3. Re: Geen line appears at bottom of MP4s at 720x486
dstack1014 Jul 27, 2012 10:14 AM (in response to joe bloe premiere)Ok, I tried cropping the sides and I get the same results except then I have black verticle lines on both sides. I also tried nesting the sequence into a sequence that is 486... and there's no difference once it's rendered.
4. Re: Geen line appears at bottom of MP4s at 720x486
dstack1014 Jul 27, 2012 10:18 AM (in response to JSS1138)Rendering at 488 did actually work to get rid of the green line so I'll ask the station if they would accept it that way. I'll let you know.
