4 Replies Latest reply: Jul 27, 2012 9:08 PM by theBigBoppa RSS
    Game Problem
    theBigBoppa
      Hello,
      I'm trying to make an enemy in a game stop from regularly walking back and forth, when the player object gets in a certain range. And when the player object gets back out of range, I want the enemy to continue walking back and forth, but it's not happnin'.
      The enemy object stops when the player gets in range but when the player goes back out of range then he does not continue back to walking back and forth. I can't figure out what the problem is, I traced the boolean property to see if it's is false when the player gets back out of range and it confirms "false", meaning he is out of range but the enemy does not go back to walking back and forth. Here is the code.........
      public function update(alienEn1:Object):void
                                              trace(main.player.xPos,main.player.yPos,alienEn1.origX,alienEn1.origY ,alienEn1.stopNShoot);
                                      onPlatform(alienEn1);
                                              if (((main.player.yPos-58) >= (alienEn1.origY -30)) && ((main.player.yPos-58) <=                               (alienEn1.origY +30))
        (main.player.xPos >= (alienEn1.origX - 120)) && (main.player.xPos <=                               (alienEn1.origX + 120))) {
                                                        alienEn1.stopNShoot = true;
        }else{
                                                        alienEn1.stopNShoot = false;
                                              if (alienEn1.stopNShoot == false){
                                                        if(alienEn1._xPos <= (alienEn1.origX - 100))
        alienEn1.moveLeft = false;
        alienEn1.moveRight = true;
                                              if(alienEn1._xPos >= (alienEn1.origX + 100))
        alienEn1.moveLeft = true;
        alienEn1.moveRight = false;
                                              }else if (alienEn1.stopNShoot == true){
                                                        if(main.player.xPos <  alienEn1._xPos ){
        alienEn1.imageStandRt.visible = false;
        alienEn1.imageWalkRt.visible = false;
        alienEn1.imageStandLft.visible = true;
        alienEn1.imageWalkLft.visible = false;
        alienEn1.imageWalkLft.animationLoop = true;
        alienEn1.imageWalkLft.updateCurrentTile();
        alienEn1.imageWalkLft.renderCurrentTile(true);
                                                        if(main.player.xPos >  alienEn1._xPos ){
        alienEn1.imageStandRt.visible = true;
        alienEn1.imageStandLft.visible = false;
                          public function onPlatform(alienEn1:Object):void
                                    verticalChange = alienEn1.dy + main.gravity;
                                    if (verticalChange > 25.0){ verticalChange = 25.0;}
                                    alienEn1.dy += main.gravity;
                                    if (alienEn1.moveLeft) {
                                              // walk left
                                              horizontalChange = -alienEn1.walkSpeed;
                                              alienEn1.imageWalkLft.visible = true;
                                    } else if (alienEn1.moveRight) {
                                              // walk right
                                              horizontalChange = alienEn1.walkSpeed;
                                              alienEn1.imageWalkRt.visible = true;
                                              alienEn1.imageWalkRt.animationLoop = true;
                                              alienEn1.imageWalkRt.updateCurrentTile();
                                              alienEn1.imageWalkRt.renderCurrentTile(true);
                                    }else{
                                              horizontalChange = 0;
                                    var newY:Number = alienEn1._yPos + verticalChange;
                                    var newX:Number = alienEn1._xPos + horizontalChange;
                                              // loop through all fixed objects to see if character has landed
                                    for(var q:int=0;q< main.fixedObjects.length;q++) {
                                              if ((alienEn1._xPos > main.fixedObjects[q].leftside-60) && (alienEn1._xPos <                          main.fixedObjects[q].rightside-40)) {
                                                        if ((alienEn1._yPos <= main.fixedObjects[q].topside-40) && (newY >                          main.fixedObjects[q].topside-40)) {
        newY = main.fixedObjects[q].topside-40;
        break;
                                              alienEn1._xPos = newX;
                                              alienEn1._yPos = newY;
                                              alienEn1.imageStandRt.x = alienEn1._xPos;
                                              alienEn1.imageStandRt.y = alienEn1._yPos;
                                              alienEn1.imageWalkRt.x = alienEn1._xPos;
                                              alienEn1.imageWalkRt.y = alienEn1._yPos;
                                              alienEn1.imageStandLft.x = alienEn1._xPos;
                                              alienEn1.imageStandLft.y = alienEn1._yPos;
                                              alienEn1.imageWalkLft.x = alienEn1._xPos;
                                              alienEn1.imageWalkLft.y = alienEn1._yPos;
      I hope this isn't too hard to read, I think the problem would be in the update(); function but I can't figure out the problem. If anyone can see what the problem is please let me know.
      Thanks a lot
        • 1. Re: Game Problem
          Ned Murphy ACP/MVP
          Yes, it is pretty hard to read, especially without knowing what different elements of the code represent.  If you can highlight the code that is relevant and explain which parts of it are used for determining whether something should move and which parts are supposed to result in movement vs stopping it could help.
          • 2. Re: Game Problem
            theBigBoppa Community Member
                                                    trace(main.player.xPos,main.player.yPos,alienEn1. origX,alienEn1.origY,alienEn1.stopNShoot);
            //THE FOLLOWING CALLS THE FUNCTION BELOW THIS CURRENT UPDATE FUNCTION.....
            //THIS CONDITIONAL CHECKS IF THE PLAYER IS IN RANGE OF THE ENEMY, IF THE PLAYER IS IN RANGE THE aliienEn1.stopNShoot IS SET TO TRUE....IF NOT IN RANGE, ITS SET TO FALSE...
        }else{
            // THE FOLLOWING CHECKS IF alienEn1.stopNShoot IS FALSE, IF IT IS THEN IT SETS THE BOOLEAN PROPERTIES AS TO WHETHER THE ALIEN SHOULD MARCH LEFT OR RIGHT....
            //THE FOLLOWING CHECKS IF THE alienEn1.stopNShoot BOOLEAN IS TRUE, IF SO THEN IT MAKES THE ALIEN STOP AND FACE THE PLAYER
        alienEn1.imageWalkLft.updateCurrentTile ();
        alienEn1.imageWalkLft.renderCurrentTile (true);
            //THE FOLLOWING CHECKS IF THE BOOLEAN alienEn1.moveLeft IS TRUE, IF SO IT MAKES THE ANIMATION RUN AND MOVES THE ENEMY TO THE LEFT
                                                    // walk left
            //THE FOLLOWING DOES THE SAME THING AS PREVIOUS BUT MOVES ENEMY TO THE LEFT
                                                    // walk right
                                          }else{
            //THE FOLLOWING JUST CHECKS TO SEE IF ENEMY HAS HIT THE PLATFORM
        break;
            //SETS THE X AND Y PROPERTIES OF THE ALIEN IMAGE TO THE CALCULATED X AND Y POSITIONS CALCULATED ABOVE...
            THANK YOU
            • 3. Re: Game Problem
              Ned Murphy ACP/MVP
              This will be a great opportunity for you to learn how to use the trace function to see what the status of different things and see where they disagree with what you believe they should be.
              If the problem lies in the object not moving when it should be, then trace the values that would make that true and see if they agree.  If they agree, then check the details of the values that dictate motion changes and see if they are changing.
              If traces are too difficult to follow, use textfields that update with the values you are interested in tracking.
              • 4. Re: Game Problem
                ok thanks
