1. Re: Find/Replace Coding to Formatting
Arnis Gubins Feb 6, 2012 8:25 AM (in response to Kenneth Benson)Ken,
Unfoturnately, the Find/Change in FM hasn't changed that much so you can't do GREP replacement.
FM still lets you import (actually, you just use the FM Open command) MML tagged files and for simple content structures, this may suffice.
Another route to consider perhaps might be to create a structured application in FM, if your content is already tagged (saves the intermediate steps converting to paratags).
However, the "better way" to accomplish what you want is to use the Miramo Personal Edition for "database publishing" from your own tagged mark-up. It's available as a freebie version for use on FM desktop versions. See: http://www.miramox.com
2. Re: Find/Replace Coding to Formatting
Error7103 Feb 6, 2012 9:48 AM (in response to Kenneth Benson)> I tried Saving to MIF, but it looks very complicated.
It is, and it isn't. We have one hack that generates MIF directly from a spreadsheet (LibreOffice Calc). A couple of minutes saves countless hours of typing.
Data is loaded into one sheet, and another contains the MIF for a complete Frame document, with all the data in a Frame table, and with cross-reference markers already present.
You only have to learn enough MIF to isolate everything above the first row, after the last, and how to code rows and cells. The premable and postamble can be pasted into one spreadsheet cell each (if you eliminate the #comments).
The active row lines and cells need the <Row and <Cell markups, of course, plus whatever else you need (like Character Formats).
Copy-all from the MIF generating sheet into plaintext.mif, open in Frame.
If MML can handle the job, it would be worth a look first. I may have done ours as a MIF hack due to some Marker limitation in MML (or perhaps just because I had prior MIF hacking experience - I started out coding it as a Python program that generated MIF - spreadsheet was trivial by comparison).
3. Re: Find/Replace Coding to Formatting
Kenneth Benson Jul 30, 2012 5:30 PM (in response to Error7103)Hi Arnis
This is a very simple content structure. There are about 1300 pages. Each page has four instances of an overline within text. I've been playing with MML, and I've figured out how to use <!DefineTag paratagname> in an include file with <tagname> in front of the appropriate paragraph.
So I can do paragraph tags. But I don't see a way to do character tags, and the MML reference doesn't seem to mention them.
Is there something like <!DefineCharTag charactertagname>? It seems like there should be, and it's what I really need. The paragraph tags are easy with or without automation. But hand tagging those little overlines 5200 times is crazy.
Ken Benson
4. Re: Find/Replace Coding to Formatting
Kenneth Benson Jul 30, 2012 5:47 PM (in response to Kenneth Benson)I did figure out how to use <!DefineFont to bring in my overlines as underlines (MML doesn't do overlines?). I can then Find/Replace the underline formatting for my overline character tag. This should work, but pulling the character tag in with the paragraph tags would be neater . . .
Ken Benson
