Existing type layer replaced by text with other type layer's text upon changing text properties
Jun 06, 2012 Jun 06, 2012
Okay, this is weird.
I have a type layer with some text in it (a headline, let's say). I click on the layer, I click on the Character Panel, and first thing I see is the color in the Panel is not the color of the font in the layer.
I then click on any Panel property, and the text in this layer is replaced by text from another layer in my document ( a paragraph layer, let's say), but the color is not the same as the layer the text came from.
Seems like a glitch, but I don't know how else to diagnose it.
22.6K
Adobe
replies 124 Replies 124
What version of photoshop and operating system?
A screenshot might help us better understand what's happening.
- Having the same problems, Looks like there might have been the same problems or similar in the "Beta Version of CS6" and the problem has been carried over to the Release Version.
- Certainly makes it very hard to work / productivity goes out the window
- Just like the Beta once it appears in CS6 and you try opening it in CS5 it carries the problem across
Using - CS6 Extended (Mac)
Jun 07, 2012 Jun 07, 2012
This is PS from CS6 on Windows 7.
There's not much to show, but it's the act of editing a text layer property which causes the switch.  It's intermittent.
It seems like this is not an entirely unknown issue, but it is a bug.
Added to this issue: I just changed my document's image size (Image > Image Size...) and upon refresh almost all my type layers reverted to some other ttpe layers text!
Now that's a bug!
- Can someone give us an idea (ball park) of when this might be rectified (e.g. it might not be until our next dot release) or are we better of using CS5 if we are plannig using text layers in photoshop
Ta
Jun 13, 2012 Jun 13, 2012
By the way, one interesting thing I see that prompts a question: Up to now I had thought that the problem had been reported only by people saving PSD files from Macs, yet I see in the screen grabs shown that D.Estabrook is on a PC...  Was a Mac ever involved in editing that PSD file, D.Estabrook?
-Noel
Contributor ,
My file has only been edited on my workstation (I'm on Win7 x64 as noted above). One other factor that may relate the two platforms: Suitcase Fusion font manager. Perhaps something related to font activation for Adobe Suite applications? I run Suitcase Fusion 4 and the cartoon fonts were in temporary status, which I later set to permanent status.
Guru ,
Has the file ever gone back and forth between CS5 and CS6?
Contributor ,
I don't think so before the text layer problem cropped up. I'm editing the file now in CS5, but I've been working almost exclusively with PS CS6 since I installed the public preview. I can't be certain, however.
The Suitcase Fusion update says that PS CS6 doesn't allow automatic font activation - as opposed to the rest of the Suite. The update claims CS6 compatibility with this update, with PS CS6 auto font activation in a future revision.
Guru ,
I've see it on my setup without Suitcase.
Adobe Employee ,
BJN3,
When you said you're "editing the file now in CS5", are you saying you took a file that was failing in CS6, and opened it in CS5 and not seeing the problem?
With regard to resizing (and related to the question I just asked), let me comment a bit on what people are seeing.
When you open a PSD with text layers, the file contains rasterized versions of the text layers, and that's what you see; you're not seeing the "actual" text, you're seeing a raster image of the text. Until something triggers a re-rasterization of a text layer, that will remain unchanged.
When you click the text to edit a text layer, or you resize the document, the text layer must be re-rasterized, and that's when the bogus text will appear. In all liklihood, the text within the text layer was corrupt in the file when you opened it, but you don't see it until you perform some action that triggers a redraw. This is why Chris commented that the corruption probably occured long before you actually see the problem.
We are working to identify the cause of this problem, but at this point we cannot reproduce the steps that cause it, or know when it happens, so the more information you can provide us, the better. We apologize for this, and do want to get this resolved as quickly as possible.
Paul
Contributor ,
I made a duplicate file to work on in CS5 and saved the failing one in case Adobe Support wanted a copy.
The corrupted file exhibits the same buggy behavior in CS5.
To be able to work on the file, I went ahead and started editing each text layer, then I moved them around and resized them per the original layout. I haven't experienced this problem except via CS6, so I'm doing the production work in CS5 in hope that I can finish it up without a recurrence of the problem.
-BJ
We need to get a copy of the failing file, and the older non-failing file.
Contributor ,
Jun 14, 2012 Jun 14, 2012
Hi Chris,
I have earlier versions of the illustration. One has three text layers that are still behaving (58 MB). Another earlier version with six text layers (71 MB) exhibits the problem, but this file triggers this message when I open it:
If I click No, the layers look okay but they do the musical chair thing on a per-layer basis if I edit a layer. If I click Update, the file opens with all the text jumped to the next layer's location coordinates and relative font size.
The most recent (71 MB) file with the broken layer behavior doesn't trigger the above message. It opens with the text looking fine, but editing the layer shows the cross-linked layer text problem. Perhaps that message is supressed because I clicked no and resaved the file? I don't know for certain if I did that, just a guess.
I can provide any or all of the above files, let me know how you like large files delivered.
And for any of the files with the latent cross-linked layer problem, resizing the image causes the same changes to all the layers as editing them individually will.
BJ
PS: I can rasterize the layers with latent cross-link behavior and they rasterize as displayed.
Again, we need the good (before opening in CS6) and after (corrupts when changed) files.
You can mail them to ccox (at) adobe (dot) com and I'll forward them to the type engineers.
If they're too big to email, contact me and we'll work something out.
Contributor ,
I'm pretty sure that my files don't have a snapshot of the magic moment. In spare moments I'm trying to capture the moment in amber, building a new file with text layers, doing what I do, and saving a new file each time I do something. No luck sighting the Textsquatch yet.
Mostly I need the file from BEFORE you see the corruption.  Once the data is corrupt, it's too late for us to figure out how it got corrupted.
The duplicate file used in CS5 should help.
Jun 15, 2012 Jun 15, 2012
I'm also having this problem, I have an untouched CS5 file if needed (33 MB)
Creative Cloud
iMac 2.7 GHz Intel Core i5, 12 GB RAM
OSX 10.7.4
One font with error and in use in PS document at time "Grenoble" (see screeshot below)
File being used with MediaLabs Sitegrinder 3.5.6 s_319
Sure, send it my way. (or email so we can work out how to get it to me via Dropbox, Google Drive, yousendit, etc.)
ok Chris, I'd need your email.
See post #23.
sending now via largefilesasap.com
I'm off to the bar to cure my very frustrated brain
Till then I'm back to using CS5
I wish a bar could cure all the problems I'm tracking...
But it does sound like it might at least help on a Friday afternoon.
Thanks for the files!
The file was always on a PC and always in CS6.
-Thanks.
