4 Replies Latest reply: Aug 2, 2012 5:07 AM by Harm Millaard RSS
    Stalling in Preview
    minigrace Community Member
      When I am previewing a project is plays about half a second at a time before stalling. The same project will play perfectly fine on the computers at school and rendering it in premier pro won't work. However, once rendered fully out of premier it plays fully. Is this common and what am I doing wrong?
        • 1. Re: Stalling in Preview
          Harm Millaard Community Member
          This is common on underspecced computers that simply lack the hardware for the codec in use, but you forgot to give all those details, so this is only guessing.
          • 2. Re: Stalling in Preview
            Model Name:          iMac
              Model Identifier:          iMac11,2
              Processor Name:          Intel Core i3
              Processor Speed:          3.06 GHz
              Number Of Processors:          1
              Total Number Of Cores:          2
              L2 Cache (per core):          256 KB
              L3 Cache:          4 MB
              Memory:          4 GB
              Processor Interconnect Speed:          5.86 GT/s
              Boot ROM Version:          IM112.0057.B00
              SMC Version (system):          1.64f5
              Serial Number (system):          W8045MJKDAS
              Hardware UUID:          CD8E4225-56B1-5836-B9C4-09E89CB4EC1A
            If any of that helps at all^
            • 4. Re: Stalling in Preview
              Again guessing, you are using a more complex codec than SD DV.
              SD DV on an iMAC with only an i3 dual core CPU, only 4 GB memory, a single hard disk and an AMD video card should run marginally acceptable, anything more complex is just not doable. Such an iMAC is at least 20 - 40 times slower than a good desktop and if you feed it too complex codecs, it is simply overwhelmed.
