Hello,
First off sorry I'm not to familier with Audition. What I am trying to do is export a bunch of clips from Premier Pro to Audition to take out background noise. I know how to do that, but is there a way I can fix one of the clips in Audition and simply "copy & paste" the grouped effects to all the other clips? This way I don't have to go into each clip and make the adjustments. Thank you
If you can record a 'favourite' which will do all of the processing you want, then you can apply it to a group of files using Batch Process, which you'll find in the Edit menu.
