9 Replies Latest reply: Aug 2, 2012 12:14 PM by Dan Bracuk RSS
    Create CSV file from a query?
    sakonnetweb Community Member
      Greetings
      I am attempting to create a csv file from a query that would pop up for downloading.
      I found this code:
      <!--- Create the file with column headers. It is crucial that you have all the outputted text on one line with no spaces between the comma and the next column header.--->
      <cffile action="write"
      file="C:\TEMP\Analysis.csv"
      output="Assigned Technician,Received Date,Received Time,Priority,Due Date,User Name,User Office,Assigned Date,Assigned Time,Completed Date,Completed Time,Hours to Complete,Description"
      addnewline="yes">
      <!--- Output the contents of the qryResults query ---> <cfoutput> <cfloop query="qryResults">
      <!--- Append (Insert) the contents of the query into the already created CSV file. Make sure that you keep all the output on one line exactly like the column header--->
      <cffile action="append"
      output= "#(tech_lname)#, #TRIM(queue_dte)#, #TRIM(queue_tme)#,  #TRIM(queue_priority)#, #TRIM(due_dte#, #TRIM(user_name)#,  #TRIM(office_name)#, #TRIM(assign_date)#, #TRIM(assign_time)#, #TRIM(repair_dte)#, #TRIM(repair_time)#, # TRIM(repair_ttc)#, #Left(q_description,128)#"
      addnewline="yes">
      </cfloop>
      </cfoutput>
      <!--- This will pop up the file for downloading. You can open it in excel or any other text editing software. --->
      <cflocation url="#your.url#/Analysis.csv">
      Something is wrong with the query.
      Here's the error:
      Invalid CFML construct found on line 135 at column 105.
      ColdFusion was looking at the following text:
      The CFML compiler was processing:
      An expression beginning with TRIM, on line 135, etc.
      135 : output= "#(tech_lname)#
      Any help would be appreciated....
      Thanks in advance
      Norman
