Cross references corrupted after placing Word document into an InDesign document
davehaigh Aug 3, 2012 6:52 AMI am placing a word document which contains cross references to headers and captions/figures within the document. They seem to be fine and function correctly in the Word document, however, after I place this word doc into my InDesign doc, I take a look at the cross references panel and notice that the cross references have been corrupted. It is wrapping the wrong portions of text from the cross reference destinations. See screenshot for a visual of how the cross references are malformed. For example the 7th cross reference in the list should say Framework Details, not "Framework Detai
InDesign Cross References Panel - showing malformed bits of text
Another visual of this issue can be seen if I view the text frame in Story Editor view, see below. You can see that the cross reference source tags (blue arrow like symbols) are wrapped around the wrong portions of text. The blue tags shoud be wrapped around Framework Details and 52
InDesign Story Editor
You can see below as to why I think the cross references are fine in the Word doc, you can see the same cross reference I used in the example above in the word doc and it is wrapping the correct portion of text:
Word - showing cross reference is formed corerctly
Why is this not being maintained after placing this file into InDesign?
Also I am not performing any cross reference updates after I import, this problem occurs immediately after the place of the doc.
Why would InDesign be having difficulty in importing these cross references? I have set up a simple test Word document with cross references to headers and figures in and they have imported fine. What could be wrong with this other particular word doc that would be causing this "corruption" of cross references? This is not only causing my cross references to break visually and lack the update capability but also I cannot export the InDesign doc to an ePub as it keeps crashing. I believe from my reading on the web that if there is only one broken cross reference source i.e. the cross reference destination that it is trying to link to is missing, then the export to epub will fail. So this is causing a massive headache for me at the minute.
Is there anything I could be looking at in the Word doc to try and figure out why the porblem is occuring in the first place?
If anyone has any tips or a possible solution to this I would really appreciate it. Even better if someone knows the reason why this is happening I can tackle it from the source and prevent it happening time and time again.
Thanks, Dave
