3 Replies Latest reply: Aug 3, 2012 12:11 PM by GMG RSS
    adobe audition cs6 stops exporting mixdown at 50%
    GMG Community Member
      AA CS6 will stop exporting a mixdown at 49% sometimes 50%.  Any suggestions?   I have been using AA for a few years now and this is the first time I have had this issue.
        • 1. Re: adobe audition cs6 stops exporting mixdown at 50%
          SuiteSpot Community Member
          I would do the obvious things like check disk space etc but I would also try removing vsts one at a time maybe there is a rogue vst?
          You could also try freezing tracks one at a time before exporting the mix to see if you can narrow down the offending track - if that is the problem.
          Just a thought....
          • 2. Re: adobe audition cs6 stops exporting mixdown at 50%
            MusicConductor Community Member
            If you're on a 32-bit OS, you also might be running out of RAM (and SuiteSpot's advice is related to that).
            I have definitely encountered mixdown export issues with AA CS6 in this regard.
            • 3. Re: adobe audition cs6 stops exporting mixdown at 50%
              No, it's not a ram issue, 64 bit with 16 gig and over 600 gig free space.  I think I have it narrowed down to being a VST problem.
              Are any of the VSTs included with audition known to cause issues on Macs?  The only other VSTs I use with audition are some of the Izotope's.
              I really hope it isn't a issue with them because I use them on every project.
              I have transfered the project file and all of the recordings over to my Windows machine and everything loaded up perfect, and the export worked.
              I'll let you know if I find the root of the problem.
